Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree3Likes
Old 08-12-2013, 02:29 PM   #646
Damon's Avatar
Originally Posted by mhavlena View Post
Gentlemen,
with above setup, I tried 6-1-1-2-2-2-0, but car would keep shutting down / resetting about half-way thru the heat.
Thus, I tired 6-1-0-0-NA-NA-0 (no boost or turbo, kinda like blinky but using V4.0 s/w. Unfortunately, the car would stop, after a short break, say 5 secs, the car would go again, almost as if the ESC was resetting itself.
Any advice would be greatly appreciated...
Thanks!
have you the motor fan attached on receiver? if yes, please attach it directly to battery, no fan on receiver with flow and mod motor!
Awesomatix A800
Awesomatix A800X
Damon is offline   Reply With Quote
Old 08-12-2013, 02:45 PM   #647
Trader Rating: 15 (100%+)
For what it is worth, I run mod 12th with a fan connected to the rx and it works great. Not sure whether the additional lipo rx pack is masking whatever issue Damon is referring to, though.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 08-16-2013, 06:34 AM   #648
Hey, guys I wanted to share some information. I figured out a simple solution for the motor temp cutoff problem with some sub/non standard motors that have a incorrect value thermistor.
The one i had problems was from Robitronic/Exceed.
The fix is simple, just cut the marked wire on a sensor cable.
You won`t have a motor temp check anymore, but most ESCs dont monitor it anyway.
Marten is offline   Reply With Quote
Old 08-16-2013, 12:10 PM   #649
What's the best way to keep the capacitor in place? My servo tape doesn't seem to be working great. It seems like it could let the cap move in a crash. Given that it's between the ESC and the belt, that could get ugly fast.
-Mike
Old 08-16-2013, 03:50 PM   #650
jag88's Avatar
-Mike
I shoe goo'd my cap to the side of the heat sink. I've run it like that in mod and have had some big hits and it hasn't moved. Clean both surfaces first.
jag88 is offline   Reply With Quote
Old 08-28-2013, 10:43 PM   #651
Hi guys
We are having our national event next week. Testing my Flow with x20 in 17.5 boosted, it looked like my turbo never activated. Here are the settings I ran. 0.5.5.8.8.5.0 with 30 deg motor insert. Was I "over timing" the motor ? Please give your suggestions please.
Yokomo BD7 fdr 6.6 . The car was strong out of the corners but that was it.
Gerrie is offline   Reply With Quote
Old 08-29-2013, 11:41 AM   #652
What rev firmware Gerrie? V1.4?
HannK is offline   Reply With Quote
Old 08-29-2013, 12:10 PM   #653
I have ver 5.0 stock firmware. One question.....is the boost slope / activation the rate at wich it applies the boost timing? Also, is there also a max amount of degrees one has to use . Example...boost timing + torque timing + turbo = 64 deg?
Old 09-01-2013, 07:13 AM   #654
Originally Posted by Gerrie View Post
Hi guys
+1 for v5 firmware
Mornedn is offline   Reply With Quote
Old 09-01-2013, 09:53 PM   #655
NR
NR's Avatar
Trader Rating: 52 (100%+)
Are there any repercussions in unsoldering the switch out of the car?
Has anyone had any issues?
Regards
Nathan
NR is offline   Reply With Quote
Old 09-02-2013, 04:11 AM   #656
Julius's Avatar
Regards
Nathan
I do not have a switch and have no issues. But i think the flow differs in the way you need to remove the switch. I think you need to leave the contact 'open' en stead of closed to have the esc 'on'
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 09-02-2013, 04:52 AM   #657
Nuno Gancho's Avatar
Hi would like to have same support for settings and gear for 13.5 boosted class and 4.5 modified class thanks.
Nuno Gancho is offline   Reply With Quote
Old 09-02-2013, 05:21 AM   #658
NR
NR's Avatar
Ok thanks for confirming, reason being, I have taken the switch off both ESC's and they work fine with the standard software, but when I updated to 3.1 for offroad, the throttle has absolutely no response, and only way to get it to work it resort back to 1.4
Old 09-02-2013, 08:30 AM   #659
Default LRP Firmware update warning!!
Sent it in to LRP and they provided me with the following warning/reset procedure when changing firmware...
As far as I know, this info is not available online and according to LRP, this is the reason why my ESC was resetting / shutting down all the time.
Was the community aware of this?
Thanks.
Mike H.
mhavlena is offline   Reply With Quote
Old 09-02-2013, 09:05 AM   #660
silden's Avatar
Thanks.
Mike H.
Yes this is in the same folder as the Firmware upgrade file.
silden is online now   Reply With Quote
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12544 10-09-2017 08:03 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
