Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree3Likes
Old 07-09-2013, 05:29 PM   #616
Default Flow, 13.5 x20 booss
Using a flow and 13.5 x20 motor combo what gearing and setting to use for a mid size track in boosted. Thanks
Chris kal is offline   Reply With Quote
Old 07-09-2013, 05:29 PM   #617
Default Flow, 13.5 x20 boosted settings
Old 07-09-2013, 06:05 PM   #618
defcone's Avatar
Trader Rating: 15 (100%+)
What I ran at AOC(Medium sized track on carpet):
Thunderpower 13.5t with 25deg. can timing:
0-1-5-8-9-3-0
5.8fdr, motor came off around 40-50deg, original software.
defcone is offline   Reply With Quote
Old 07-09-2013, 11:33 PM   #619
feizal917's Avatar
I ran 6.4 fdr with X12 motor, +10 deg insert
My Flow set up 0125933. About 30m straight.
Temp about 88-95 deg C.
feizal917 is offline   Reply With Quote
Old 07-11-2013, 10:16 AM   #620
Default Recommended starting setup?
touring car on-road 2S lipo
smallish, technical track
Flow Worksteam with V4.0 installed
LRP X20 4.5T
Appreciate ..thanks!!
mhavlena is offline   Reply With Quote
Old 07-13-2013, 07:55 AM   #621
Cridd's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Jochim_18 View Post
Chris,
I got the new board on all my LRP SXX very similar to flow with 1.4 Version firmware and it has a lot of power on blinky class as you can tell I have been dominating the 2wd buggy class lol... 5.0 Firmware Version is specifically design for boosted class it does not give you any advantage When running blinky class..
For sure.
I thought that it had higher values on a few of the settings compared to 1.4. Nothing that would give you more power or boost because blinky is blnky but less brake and higher initial throttle so your still blinky but get a little more punch. Initial drive or something along those lines.
For me I just need practice, software can't fix that. I am going to turn my 17.5 on engine boost down and see if I can pick up some torque.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 07-14-2013, 03:07 AM   #622
Jochim_18's Avatar
Originally Posted by Cridd View Post
For sure.
Adjusting power profile gives your more punch but you will get wheel spin.. Get the Revtech Killshot with LRP flow it's a killer combo...
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 07-14-2013, 07:57 PM   #623
LRP X20 4.5T
Gentlemen,
with above setup, I tried 6-1-1-2-2-2-0, but car would keep shutting down / resetting about half-way thru the heat.
Thus, I tired 6-1-0-0-NA-NA-0 (no boost or turbo, kinda like blinky but using V4.0 s/w. Unfortunately, the car would stop, after a short break, say 5 secs, the car would go again, almost as if the ESC was resetting itself.
Any advice would be greatly appreciated...
Thanks!
Old 07-15-2013, 01:35 AM   #624
sosidge's Avatar
Gentlemen,
Thanks!
When it stops, go down and look at the ESC. The lights will show you why the ESC has cut off.
Old 07-17-2013, 09:49 AM   #625
syndr0me's Avatar
Trader Rating: 32 (100%+)
Did we ever get an answer on whether or not it's possible to buy a replacement bottom case? I still can't solder on this ESC without sometimes melting some plastic.
syndr0me is offline   Reply With Quote
Old 07-17-2013, 09:56 AM   #626
silden's Avatar
Hi Syndrome,
I always call AE and ask for Aldo, he is in charge for any supportquestion regarding the electronics.
BTW he is very helpful.
the number is (949) 544-7500 extention 2123 .
silden is online now   Reply With Quote
Old 07-17-2013, 09:59 AM   #627
silden's Avatar
Gentlemen,
Thanks!
I had the same and it were the sensor cable, it were not plugged in fully on the spedo. It looked like but it was not.
Old 07-17-2013, 10:36 AM   #628
Trader Rating: 20 (100%+)
Gentlemen,
Thanks!
FDR?
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 07-17-2013, 02:34 PM   #629
Originally Posted by Troy Carter View Post
FDR?
OK, you got me there,....I was way over-geared, at least, that's what people are telling me....FDR = 8.0
Customer support thought that I should send it in anyway, even though I was over-geared, thus I sent it in...;(
I think that I jumped the gun on this one...
Old 07-17-2013, 02:45 PM   #630
jag88's Avatar
Has anyone reprogramed from 1.4 to 4.0 ?
Did you feel any difference on the track ?
Thanks.
jag88 is offline   Reply With Quote
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12544 10-09-2017 08:03 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
