Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree3Likes
Old 07-01-2013, 03:08 PM   #601
AE-Reedy
Originally Posted by Bill K View Post
Under boost angle and activation, how can "Boost trigger" be used instead of "Boost angle"?
Can this be changed? If so, how is this used?
The boost trigger is fixed in the software but different versions of software use different RPMs to trigger.
The Stock and Off road mod SW use 5.1k, the mod on-road uses 7.6k.
Sean Cochran is offline   Reply With Quote
Old 07-05-2013, 12:55 AM   #602
Jochim_18's Avatar
I just got the LRP Flow works ESC and I have no idea what firmware installed in the ESC. My question is what's the best firmware to use in 17.5 blinky class or it doesn't matter..
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 07-05-2013, 01:01 AM   #603
peter.'s Avatar
Update v5.0 - special Stock Only firmware
peter. is offline   Reply With Quote
Old 07-05-2013, 02:39 AM   #604
V1.4 will come as standard on the unit, as above for the best stock software use v5.0
Smartypants is offline   Reply With Quote
Old 07-06-2013, 09:40 AM   #605
Geberit's Avatar
I'm using a TP 4.5T motor gear ratio 8.0-8.3 and 20 degree motor timing with a Nosram Comet HD. I seem to have to much bottom power so it's hard to control the car in slow sections. My settings were 2-3-0-4-3-1-3. Any suggestions how to make the motor smoother in the bottom without to sacrifice the top speed?
Thanks for any advice.
Lojz
Geberit is offline   Reply With Quote
Old 07-06-2013, 11:26 AM   #606
Try Lowering modes 2,4,5
Old 07-06-2013, 05:39 PM   #607
jag88's Avatar
Is there a way to check which ver. of firmware you have on your esc. ?
Thanks.
jag88 is offline   Reply With Quote
Old 07-06-2013, 09:25 PM   #608
vr6cj's Avatar
Trader Rating: 124 (100%+)
Thanks.
yeah, if its stock untouched its 1.4v. If you have the cpu bridge it will tell u when u hook it to the puter.
If you bought used and dont have the cpu bridge then well...not really unless you know the beeps very well.
vr6cj is offline   Reply With Quote
Old 07-06-2013, 11:05 PM   #609
Jochim_18's Avatar
I know the V5.0 firmware is specific for stock racing however the changes made is for boosted class... Or this firmware will give more overall power when use in blinky..
Old 07-07-2013, 12:12 AM   #610
metalnut's Avatar
Trader Rating: 36 (100%+)
Does it make any difference to upgrade the firmware for VTA, meaning 21.5/25.5 motors?
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
Old 07-07-2013, 04:29 PM   #611
Cridd's Avatar
Trader Rating: 16 (100%+)
I think it is best to upgrade from 1.4.
3.3 is Mod class and 5.0 is for the blinky stock class.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 07-07-2013, 07:18 PM   #612
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
No need. V1.4 is very good for Blinky. V5.0 only needed if you run boost for something like a 10.5 and up. I actually downgraded from 5.0 to 1.4.
Racing4Evo is offline   Reply With Quote
Old 07-08-2013, 10:56 AM   #613
Jochim_18's Avatar
Ok thanks that's what I thought their is no advantage upgradiing to a new firware if you are only running blinky... But anyways the flow is awesome lots of rip on 17.5 blinky class and break is unreal very smooth..
Old 07-08-2013, 09:56 PM   #614
Cridd's Avatar
5.0 is made for blinky higher specs for stock.
Chris
B6D / T5M / SC5M
Old 07-08-2013, 10:57 PM   #615
Jochim_18's Avatar
Chris,
I got the new board on all my LRP SXX very similar to flow with 1.4 Version firmware and it has a lot of power on blinky class as you can tell I have been dominating the 2wd buggy class lol... 5.0 Firmware Version is specifically design for boosted class it does not give you any advantage When running blinky class..
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12535 07-24-2017 08:53 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
