Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 06-22-2013, 09:58 AM   #586
RC295's Avatar
Default fdr & esc setup 7.5t/flow??
need help to find fdr for my lrp x20 7.5t and setup for my flow esc. Outdoor track with +-30meter straight line with technical inside with average laps around 18-19s per lap. Outdoor temp average around 34-38 celcius during midday. ty for help
[SPONSORED BY ME, MYSELF & I]
RC295 is offline   Reply With Quote
Old 06-22-2013, 01:49 PM   #587
Cridd's Avatar
Trader Rating: 16 (100%+)
I run an 81 / 20 so 10.53 FDR. version 3.3 on lrp flow
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 06-22-2013, 06:25 PM   #588
vadersing's Avatar
Default 4.5T Mod Touring
I just bought a Flow Esc and would need some esc set up recommendations please.
Large onroad track with 40m straight
4.5T Trinity D3.5 motor
Touring car with front spool
Question, do I just use one of the preset profiles? If not, how do I set a custom recommended setting?
vadersing is offline   Reply With Quote
Old 06-23-2013, 11:31 PM   #589
nerdling's Avatar
1/10 Mod Touer 2013 ACT Titles
Motor Nosram Pure2 4.5 4dot
ESC FlowHD v4 3-1-5-8-5-3-3
Roll Out 23.25mm (assume 63mm tire)
ACT EP10 & EP12 ONR Titles, February 26th to 29thth 2016.
--XRAY--NOSRAM--PROTOFORM--MUCHMORE--
www.teamxray.com -- www.hudy.net -- www.hobbyexpress.com.au
http://www.rcracedatesaustralia.com/
nerdling is offline   Reply With Quote
Old 06-24-2013, 02:37 PM   #590
steveonamission's Avatar
Anyone any idea if you can purchase the bottom plastic case part of a flow?
If so a part number would be great.
www.fuller-paint.blogspot.com
steveonamission is offline   Reply With Quote
Old 06-25-2013, 04:56 AM   #591
Would be surprised if smd couldn't get them!
Smartypants is offline   Reply With Quote
Old 06-26-2013, 02:42 PM   #592
Skillz_B's Avatar
I just received an LRP Flow Competition ESC, and I am having second thoughts, I am only running 17.5t blinky n a B4.2 right now, but I might want to run mod in the future, how far in the future I dont know. Should I just send it back and pay the difference for the Works, or can I have it upgraded to the Works if or when I decide to run mod?
"No man for any considerable period can wear one face to himself and another to the multitude, without finally getting bewildered as to which may be the true." Nathaniel Hawthorne
Skillz_B is offline   Reply With Quote
Old 06-27-2013, 02:55 PM   #593
AE-Reedy
The competition will handle light duty mod. LRP doesn't recommend it but we tested with a 7.5t in a 2wd buggy no issue. I would not recommend running mod on-road with it though.
Sean Cochran is offline   Reply With Quote
Old 06-27-2013, 07:33 PM   #594
Mike Haynes's Avatar
Spot on Sean C. I have a comp in my 4wd buggy and it has been perfect, it does run a bit toasty though so i'd recommend the fan.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 06-28-2013, 12:35 AM   #595
Skillz_B's Avatar
Thanks guys, I am gonna keep the Comp, Stock is really competitive at our local track so I will probably stay there for a while, and by the time I am ready to run Mod a new ESC will probably be out.
Old 06-29-2013, 09:39 PM   #596
Bill K's Avatar
Is torque timing just a fancy name for the setting punch?
Bill K is offline   Reply With Quote
Old 06-29-2013, 09:54 PM   #597
geeunit1014's Avatar
No, that would be "initial drive" or feel. Torque timing actually increases bottom end power
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 06-30-2013, 12:53 AM   #598
Bill K's Avatar
So running high amounts of Initial Drive and some torque timing should give a significant amount of power out of corners ect?
Old 06-30-2013, 09:23 AM   #599
Yes, that would make it extremely aggresive on power. Personally, I dont like running a lot of initial drive, even with a blinky car, I just think its easier to drive.
Mike Gee
Old 07-01-2013, 12:45 AM   #600
Bill K's Avatar
Under boost angle and activation, how can "Boost trigger" be used instead of "Boost angle"?
Can this be changed? If so, how is this used?
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12513 02-17-2017 12:10 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 01:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 09:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 01:24 AM
