Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree3Likes
Old 06-14-2013, 08:46 PM   #571
95lscoupe's Avatar
UWotM8
Matthew Abey
Awesomatix USA/Speedzone USA
LRP/Futaba/Middle River Russian Mafia
Awesomatixusa.com/Speedzoneusa.com
95lscoupe is offline   Reply With Quote
Old 06-14-2013, 08:59 PM   #572
narcotiks's Avatar
Not trying to be rude to the other people who posted, but, DO NOT take your gearing up to 6.5, because the motor will probably blow from over revving or be slow. As far as turning the boost back and starting from zero, its abit of a time wasting exercise since you will end up with allot of boost to be quick anyway. Like i said it's about the rev range, how much boost is applied per certain amount of rpm.
try, 38 boost, 25 angle as well,
Think that will work well also
Maybe take the can back a fraction after you test the effects of the boost and boost angle changes
Make sure you install two fans bowing on the motor before you try any of this !!!!!!!!!!
narcotiks is offline   Reply With Quote
Old 06-15-2013, 01:42 AM   #573
Default flow up grade bridge and windows 8
Tried various things and just cant get this to work with windows 8 is this a problem or me being a dope.
What windows version works best with the bridge.
RCvetran is offline   Reply With Quote
Old 06-15-2013, 03:38 AM   #574
Bill K's Avatar
Works fine on an old Windows XP Proffessional system.
Bill K is offline   Reply With Quote
Old 06-16-2013, 07:38 AM   #575
Cridd's Avatar
Trader Rating: 16 (100%+)
Does not work with Windows 8. Says it on their website. It works with XP and 7.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 06-16-2013, 10:09 AM   #576
Mike Haynes's Avatar
Technically your correct, however i have been using my lrp link on win 8 for months.
New LRP Flow Esc
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 06-16-2013, 10:22 AM   #577
Cridd's Avatar
unsupported but figured it out. 10-4.
Chris
B6D / T5M / SC5M
Old 06-17-2013, 05:52 AM   #578
JAKE LISZKA's Avatar
Hi guys,
I'm running a lrp flow works team esc with a reedy 4.0t. I need some settings for this for a 1/12 1 cell setup.
Team Associated - Reedy - Team Orion - LRP - Hobbywing - ORCA - Speed Passion - Spektrum - Ride - Savox
RAB Hobbies - Central R/C
JAKE LISZKA is offline   Reply With Quote
Old 06-17-2013, 07:19 AM   #579
gearhead_22's Avatar
Send a message via AIM to gearhead_22
got my flow back thursday and ran it this weekend and i worked perfect in my mod race.
serpent 977WC-novarossi-748TQ
serpent S120 LTR-S411 4X-F110 fs2
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter http://rccarworld.com/............ serpent.com
Track director at RCCW.
gearhead_22 is offline   Reply With Quote
Old 06-17-2013, 08:31 AM   #580
Trader Rating: 15 (100%+)
Originally Posted by JAKE LISZKA View Post
Hi guys,
I forget my exact settings, but you can try starting with someone like 4,2,0,3,3,1,0 and go from there. Up the boost settings and initial drive as per your preference. I have an LRP motor so I use torque timing and have a little more boost than the above settings.
I would also recommend looking at Keven Hebert's thread for his settings, since he is running an LRP Flow with a Reedy mod motor.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 06-18-2013, 02:37 AM   #581
Default flow blinky setting in ver 5
Just updated my Flow, have the boosted settings sussed out,but seem to be struggling with blinky settings .
Running 1s lipo could some one post the sequence of setting running 1s blinky with 13.5 in a pan car please
Old 06-18-2013, 09:55 AM   #582
feizal917's Avatar
Default Blue LED Blinking Rapidly
Pls help me!!
Why my Blue LED blinking rapidly? All LED not flashing, only Blue.
Anybody hav this problem before?
feizal917 is offline   Reply With Quote
Old 06-18-2013, 10:02 AM   #583
sosidge's Avatar
Originally Posted by feizal917 View Post
Pls help me!!
Blinky mode? Setting up Mode 3?
Old 06-18-2013, 10:14 AM   #584
feizal917's Avatar
Not in blinky mode. Battery is fully recharge. I'm using LRP x12, Mode 3 in 5 deg.
my setup is 0213810. LRP x12 13.5T. It seems like shortage of power when it happens.
Old 06-18-2013, 12:10 PM   #585
sosidge's Avatar
The shortage of power may well be because it is reverting to blinky mode because it is losing the sensor signal so check your sensor cable and sensor boards.
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12532 06-12-2017 04:14 PM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
