Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree3Likes
Old 06-14-2013, 06:05 AM   #556
Bill K's Avatar
Alright, im pretty unhappy with the performance of this ESC.
Ran some suggestions that were recommended for use here on this forum, and nothing was really competetive enough to use, or even to consider to use racing in a state championship.
I then clocked everything up. Had the Boost timing on option 9, activation on option 10, turbo on obtion 3 and motor timing on 40deg, and it spanked. The motor reached a total of 90deg celcius, but this can be controlled with heatsink and fan ect.
I then drove this on with other cars running tekin and Speed Passion esc's, and still, they were faster down the straight, out of the corners, when I was taking the best raceline possible for almost the full session. Although I managed to keep them behind me, I was still threatened by their faster more competetive cars.
So... What now?
Honestly.
Bill K is offline   Reply With Quote
Old 06-14-2013, 06:15 AM   #557
Trader Rating: 15 (100%+)
Originally Posted by Bubonic-X View Post
can the flow handle 1s operation. why did the sxx do 1s but the flow I'm not sure
You will need either a voltage booster or a receiver pack to use the Flow in any 1s cars. I run KO radio gear and have had great luck with a 2s lipo receiver pack. A normal life receiver pack will work just fine as well.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 06-14-2013, 08:09 AM   #558
JustWill75's Avatar
Send a message via AIM to JustWill75
I run blinky 17.5 TC, do I need to go to 5.0 to get the full potential of my Flow Works? Or Blinky mode is just blinky you don't need 5.0 unless you are running boost.
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
Old 06-14-2013, 08:24 AM   #559
Default blinky mode
Ive been told blinky is blinky which ever version of software you use makes no difference to power or performance.
RCvetran is offline   Reply With Quote
Old 06-14-2013, 08:50 AM   #560
gearhead_22's Avatar
Send a message via AIM to gearhead_22
this is the track the the sweep challange will be held at on the 28&29 of june I will be running tc mod there with an lrp 8.5 or a 5.5 with the lrp flow. can some one give me a setup for the flow?
+ YouTube Video
serpent 977WC-novarossi-748TQ
serpent S120 LTR-S411 4X-F110 fs2
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter http://rccarworld.com/............ serpent.com
Track director at RCCW.
gearhead_22 is offline   Reply With Quote
Old 06-14-2013, 11:28 AM   #561
Trader Rating: 20 (100%+)
5.5 or lower for sure out there.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 06-14-2013, 11:52 AM   #562
I ran my 8.5 last year there with the tekin rs and on one ould believe that I was running an 8.5. good feel for the in field and nice speed on the straights
Old 06-14-2013, 05:45 PM   #563
geeunit1014's Avatar
I run 6-1-1-2-2-2-0 on an LRP X20 5.0, with my motor id do about 7.3 gear up there. With your 5.5 id run 7.0. Personally I think you will be better off with the 5.5, you wont have to push it as hard and it will run cooler. I also think lower winds are smoother to drive.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 06-14-2013, 06:27 PM   #564
feizal917's Avatar
So... What now?
Honestly.
same problem here. At first I thought my speedo is defect. But a few run afterwards, using many brands motor, then I realized that nothing wrong with this speedo. Speedo is fine, only not enough power. It would be nice if the we can get more turbo and activation a litle bit earlier..
feizal917 is offline   Reply With Quote
Old 06-14-2013, 06:30 PM   #565
So... What now?
Honestly.
What motor/endbell timing? fdr? track size? etc
Mike Gee
Old 06-14-2013, 07:35 PM   #566
narcotiks's Avatar
So... What now?
Honestly.
Are you running 13.5?
Motor?
Gearing?
firmware?
What are your full speedy settings in terms of degrees, e.g boost 35 degrees etc.
I haven't run my flow yet but i've had a look at the settings and updated to the new firmware(stock specific), and iv'e come up with a way to calculate the rev range with different boost settings vs boost angle settings, and i've put it all in a table, happy to email it out if anyone is interested . The flow's settings can be a little confusing at first, it's not about how much boost you have but rather how it is applied over a given boost angle, but anyway, i'll be able to give you some settings to try that should work
narcotiks is offline   Reply With Quote
Old 06-14-2013, 08:15 PM   #567
Bill K's Avatar
Motor?
Gearing?
firmware?
Alright, for you, and for all those who asked about this heres what I can supply.
The motor I have been using is the thunder Power 17.5. This does not have the 'high torque' motor installed and has only had the bearings modified.
The gearing I have been using is a 48P standard, with 81T spur gear and 28T pinion gear. I was considering going down to a 27T pinion due to the high temperatures I was reaching just last night. The timing I have applied to the endbell is 40degrees. The FDR being 5.786 (Which is what other people were running aswell!)
The track I have been using can be viewed here: https://www.youtube.com/watch?v=a7tYk31ttjs
- Note that this is only to get an idea of the track. The motor and speedcontroller are completely different from what I am using now. This is racing indoor on ashphalt with usually medium to high amounts of grip.
I currently have the V5 STOCK SPECIAL firmware installed on the Flow Worksteam ESC, Here are the settings I was running on the flow and the motor the other night:
Auto Brake #0
Feel/Initial Drive #15
Torque Timing #5
Boost Timing #47
Boost Angle #35
Boost Turbo #10
FDR 5.78 (Yokomo BD7)
40 degree timing on motor (Thunder Power 17.5)
Hope this helps!
Thankyou for everything guys, I'd really love to get this ESC working at its full potential. Otherwise, I'm purchasing another brand ESC. Maybe a HW or SP. Thanks!
Old 06-14-2013, 08:25 PM   #568
I think you have too much endbell timing for running boosted (TP say ~37 is best for blinky, and generally you run less in boosted) and too much gear for that track, and consequently you are probably not winding the esc timing out all the way. I would go to 25* on the endbell, and 6.5 on the gear and then see what happens. You may actually find turning your boost timing down helps, especially if you are not getting to the turbo, which may be the case. If this helps, you could also try a more aggressive ramp as well.
I would also turn the torque timing off, to be safe. LRP say that setting should only be used with LRP motors..
Mike Gee
Old 06-14-2013, 08:26 PM   #569
95lscoupe's Avatar
Sounds like way too much end bell timing and im not aware of the flow having that high of settings you stated for boost timing and angle. Set the end bell timing at 30 deg and pull all you boost back to nothing in the esc and start adding timing angle and boost together 1/1/1 ,2/2/2 ect till you get to around 170 deg motor temp. Cant hurt to drop a tooth aswell let the flow do the work.
Matthew Abey
Awesomatix USA/Speedzone USA
LRP/Futaba/Middle River Russian Mafia
Awesomatixusa.com/Speedzoneusa.com
95lscoupe is offline   Reply With Quote
Old 06-14-2013, 08:34 PM   #570
narcotiks's Avatar
Auto Brake #0
Torque Timing #5
Boost Timing #47
Boost Angle #35
Boost Turbo #10
Hope this helps!
Hey dude,
I think your gearing is way too high for 17.5, i'm almost down that low with a 13.5! Try between 5.0 and 5.5, I think your motor is getting too hot because it is 1. over revving
2. rev range is WAY to compressed
I'm not sure on the Torque timing, isn't that only for LRP motors?
If other people are running that motor and are at 40 can timing, thats probably around where you should be, but, 40 might be that little too much timing that just adds heat and inefficiency to the equation.
Keep the turbo, motor timing, feel/initial drive, try the lower gearing first
and then try
boost: 47, angle: 30
If that is working better than before,
try
boost: 44 , angle :25
No worries man happy to help i think it's definitely a good speedy, just the settings are miss understood. If you end up giving up, get the hobbywing
Good luck!!
Yanni
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12544 10-09-2017 08:03 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
