Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree3Likes
Old 06-11-2013, 02:24 AM   #541
reg
Originally Posted by Bill K View Post
Alright, Im quite fed up with this!
Under load, using my thunder power 17.5 with boost the motor stutters and will never hit boost
Does anyone have any ideas?
My gear ratio is fine, and it's driven beautifully in the past.
make sure you throttle trim is set to defalt(zero or 100) when you did the calibration,and also its still set the same.
reg is offline   Reply With Quote
Old 06-11-2013, 05:02 AM   #542
Having to send this POS off again. This time because it keeps saying the rotor is locking in position. Waste of time this speedo.
Mi4cxl is offline   Reply With Quote
Old 06-12-2013, 12:11 AM   #543
millhouse420's Avatar
Angry
I wonder if it is a wide spread problem?? I just picked up a SSX on craigslist as a backup until I get mine back from Team Associated (same problem as you)
millhouse420 is offline   Reply With Quote
Old 06-12-2013, 02:55 AM   #544
Bill K's Avatar
Alright, just for clarification.
If I have say, 30 deg motor timing, and a total of 60deg additional speedy timing (Combination of Boost and Turbo), is this an incorrect way to run the motor, and could contribute to my stuttering problems?
Would having the timing on the can at 30deg, and total speedy timing at 30deg be better?
Please explain this to me. Is is a total of 60deg timing allowed all together? Or on the speedo only.
Thanks!
Bill K is offline   Reply With Quote
Old 06-12-2013, 06:02 AM   #545
I think, you should start with 0 degree motor timing, 30 degree boost timing and 0 degree turbo timing. Than, you can increase your motor timing in 10 degree steps.
Regards,
Chris
Chris85 is offline   Reply With Quote
Old 06-12-2013, 08:46 PM   #546
can the flow handle 1s operation. why did the sxx do 1s but the flow I'm not sure
Bubonic-X is offline   Reply With Quote
Old 06-12-2013, 10:16 PM   #547
JustWill75's Avatar
Send a message via AIM to JustWill75
Me and another racer were just talking about this...... I have a Futaba 4pl and the throttle trim goes up to 120. I was under the impression from racing in VTA that you set the set the speed control with the trim at 100 and after you do that you should turn the trim up to get more speed.
Fast forward to tonight, I was told to turn the trim up to the Futaba 120 on both the brake and the throttle and then calibrate. Then tune out the brakes from there so you are not locking up the wheels.
Okay guys what's the verdict on this? Just to let you all know I'm racing in 17.5 Reddy Mach 2 with the out the box profile Flow works. (windows 8)
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
Old 06-12-2013, 10:48 PM   #548
CraigM's Avatar
Trader Rating: 34 (100%+)
Do this
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 06-12-2013, 11:10 PM   #549
SlideMasteR's Avatar
there is a limit as to how many degrees you can add to a motor, more than that and it will want to start turnign backwards ! dial your timing back to no more than a total of about 60 deg and run it again
as to setting your esc up at 100 epa and then moving the epa is not going to give you more than full throttle !!!! 100% is 100% the only thing you are making sure of by doing this is that if you have a floating endpoint on the esc, the esc will still be seeing 100% and still be boosting !
Xray T4 15' - Hobbywing V3.1 ESC - Reedy Modified Motors - Thunder Power Batteries - Protoform - Much More
SlideMasteR is offline   Reply With Quote
Old 06-12-2013, 11:39 PM   #550
defcone's Avatar
Trader Rating: 15 (100%+)
He's putting it at 120% and then calibrating, which should give u finer adjustments since you're adjusting 100% with 120 points, but I doubt this will be necessary.
defcone is offline   Reply With Quote
Old 06-13-2013, 05:01 AM   #551
Bill K's Avatar
Currently my setup consists of 10deg boost timing, and 30deg motor timing.
Will be running it tomorrow to see how it goes. I have reinstalled the stock firmware, re-calibrated the speedcrontroller and replaced the reciever.
Old 06-13-2013, 08:33 AM   #552
So JUST after purchasing a 17.5 turn thunder power, which in fact should work and has run beautifully in past, is not a good combination to use with the Flow?
Just curious, who else runs this motor and the flow? And also, what settings is everyone running for a 17.5 boosted class?
Hi Bill !
I have used the Thunder Power 17.5 / LRP Flow combo since November. And it has worked really great..
My settings at the last race was:
Auto Brake #1
Feel/Initial Drive #1
Torque Timing #0
Boost #5
Boost Angle #7
Turbo Timing #3
FDR 6.41 ( Xray T4 )
40 degree timing on motor
40mm fan in front of motor blowing backwards
This give a motor temp of about 70 degree C
Racing indoor on carpet.
// Tomas
Tomas W is offline   Reply With Quote
Old 06-13-2013, 09:04 PM   #553
Cridd's Avatar
Trader Rating: 16 (100%+)
We run 17.5 blinky. Like the 5.0 software and 3.3 for boosted.
Run a reedy motor no issues.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 06-14-2013, 12:43 AM   #554
Bill K's Avatar
Well, the 5.0 software is what I currently have installed. Hope all goes well!
Old 06-14-2013, 12:48 AM   #555
Bill K's Avatar
Originally Posted by Tomas W View Post
Hi Bill !
Auto Brake #1
Torque Timing #0
Boost #5
Boost Angle #7
Turbo Timing #3
// Tomas
Thankyou, very much. I dont think I am able to run a fan behind the motor though. Ill have to play with settings ect until heat isnt the issue.
Thanks again
Bill
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12532 06-12-2017 04:14 PM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
