Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree4Likes
Old 05-19-2013, 01:40 AM   #511
Hey Guys,
I have just recently purchased a LRP flow works team, I am running it in a R5.2!
I am wanting to know if anyone could give me a good base setup for a 5.5 speed passion motor. The track I race on is low/med traction plus it will be for the software the esc comes with.
Any help will be appreciated
Thank you
Kevin
HBRC-LBD is offline   Reply With Quote
Old 05-21-2013, 11:10 AM   #512
ChadB.'s Avatar
Trader Rating: 21 (100%+)
I am having a tough time downloading the v4 software. I think I have found the correct firmware to update the speedo, but it is not recognizing it so it can be downloaded. I am currently using Windows 7. Any help would be great.
Chad Burdick
*Mugen Seiki*Flashpoint Racing Products*Daves RC Track*
ChadB. is offline   Reply With Quote
Old 05-21-2013, 11:21 AM   #513
gearhead_22's Avatar
Send a message via AIM to gearhead_22
well sent my second lrp flow back to lrp today hope I get a working one this time because i paid good money just to be sending a speedo back and fourth
serpent 977WC-novarossi-748TQ
serpent S120 LTR-S411 4X-F110 fs2
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter http://rccarworld.com/............ serpent.com
Track director at RCCW.
gearhead_22 is offline   Reply With Quote
Old 05-23-2013, 06:45 PM   #514
95lscoupe's Avatar
Does anybody know what the torque timeing does? I have a x20 5.0t. Just picked up a flow to replace my SXX and trying to learn all over again.
Matthew Abey
Awesomatix USA/Speedzone USA
LRP/Futaba/Middle River Russian Mafia
Awesomatixusa.com/Speedzoneusa.com
95lscoupe is offline   Reply With Quote
Old 05-25-2013, 05:49 AM   #515
LoudOne's Avatar
Trader Rating: 31 (100%+)
I'm having the same issue as well and have Windows 7.. I can download the Firmware Update Tool, but after that I can't download the firmware. Can some please let us know what firmware they are choosing and how to go about saving it? Thanks!
Originally Posted by Mike Haynes View Post
Yes i have for the past month with no issue so far, you have to disable the driver signature enforcement requirement in windows, then install the lrp link and driver.
Is this what I should be doing below?
Kyosho RB6.6, ZX6.6
Serpent SRX2 MM
X-RAY XB4 (2013), XB2 Carpet (2017)
Schumacher KF2
LoudOne is offline   Reply With Quote
Old 05-30-2013, 02:14 PM   #516
Trader Rating: 15 (100%+)
Can anybody explain the difference(s) between the stock and mod software for the LRP Flow? I have been using whatever software version comes standard in the Flow for mod 12th recently, and only just learned that there might actually be a mod-specific fw version. Can anyone provide further information about the actual differences between the firmware versions? I see the LRP release notes that basically just show some different values for the boost settings...is it a significant enough difference, considering the bridge costs $40?
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 05-30-2013, 02:18 PM   #517
Mike Haynes's Avatar
I don't think that will work out properly, i completely uninstalled any lrp stuff i had tried, and then used the steps here, followed by a complete install of the link and driver for windows 7.
http://www.craftedge.com/tutorials/d...tall_win8.html
If you have trouble i'll do my best to help.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 05-30-2013, 02:26 PM   #518
The mod specific software has finer adjustments compared with the stock firmware (has some mod and some stock values). The stock version concentrates on the higher power settings then the mod version does (both of which give more options then stock). If you look at the timing and ramp values they can be compared with each other, and this will make more sense. Check out the pdf from lrp website for specific values.
Old 05-30-2013, 02:44 PM   #519
Will there be any more updates for this speedo? Specifically stock as it's lacking in that department compared to other speedos.
Mi4cxl is offline   Reply With Quote
Old 05-30-2013, 07:55 PM   #520
vr6cj's Avatar
Trader Rating: 124 (100%+)
whats it lacking compared to others? Its got the highest amps per phases of any esc Ive seen and is by far the smoothest
vr6cj is offline   Reply With Quote
Old 05-31-2013, 12:01 AM   #521
Well in my last 13.5 boosted race I was getting made to look as if I was standing still in comparison to others using the orca/tekin speedos. It was smooth, just not fast. It certainly makes for a better mod speedo.
Old 05-31-2013, 08:07 AM   #522
Because clearly the only thing that could be at fault is the speedo, right?
Old 05-31-2013, 08:14 AM   #523
AdrianM's Avatar
The LRPs have been very fast in boosted spec classes for some time. Are you running the stock/spec firmware? If you are running the mod software certain settings are limited to prevent damaging mod motors.
Beyond that there are lots of variables to trip you up. Too much gear will make it so you never hit or don't get all the boost you want, etc...
Adrian Martinez
Old 05-31-2013, 08:16 AM   #524
Bar
the LRP Flow holds the track record at my local outdoor track in 17.5 blinky, not that i think it makes a lot of difference in this class, as it's a very controlled class, anyway
Bar is offline   Reply With Quote
Old 06-04-2013, 08:08 AM   #525
Ive got a flow with the stock firmware 1.4 and a 13.5T Turnigy Trackstar in my TC.
Can anybody tell me a god FDR to start with when driving a small outdoor Track with a 25m straight?
And what flow setup is good to start with?
Regards,
Christian
Chris85 is offline   Reply With Quote
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12544 10-09-2017 09:03 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 01:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 09:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 01:24 AM
