Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree3Likes
Old 05-07-2013, 02:35 PM   #496
AE-Reedy
Originally Posted by Cridd View Post
I have the lrp flow works team and mode two brake ramp and brake type in version 3.3 I don't understand what that does? can somebody explain it?
It is difficult to explain exactly what it does but the basics are this.
A lower value makes the brakes weaker, both drag and push brake will be effected. The purpose of the ramp is to change the relationship between high speed brake and low speed brake. An example is going down the straight and you lift for the sweeper and the car gets loose if the drag brake is too high. By lowering the brake ramp number the brake effect at the end of the straight is reduced. But like I said it will effect the brakes through the entire range so if you lower the ramp you might have to increase your drag brake a little to compensate.
It really is a driver feel preference so there is no right or wrong but what you think works best for you. As grip increases you can increase the ramp value.
I hope this helps.
Sean Cochran is offline   Reply With Quote
Old 05-07-2013, 03:42 PM   #497
Cridd's Avatar
Trader Rating: 16 (100%+)
I hope this helps.
Sounds like I need to do a lot of testing to get the best feel. A lot more complicated than I thought. Thanks for the information.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 05-09-2013, 09:04 PM   #498
JustWill75's Avatar
Send a message via AIM to JustWill75
Originally Posted by Mike Haynes View Post
Yes i have for the past month with no issue so far, you have to disable the driver signature enforcement requirement in windows, then install the lrp link and driver.
I cant get his to work Bro. Does anybody have a step by step to do this. I notice on the LRP said this will not work with windows 8......
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
Old 05-09-2013, 09:34 PM   #499
B00t13g's Avatar
I'm selling a brand new Lrp flow if anyone is interested.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 05-12-2013, 12:54 PM   #500
Crashmaster's Avatar
Hi guys,
Is there any advantage to the Works Team over the standard Flow for running in 13.5 Boosted?
Dan
Crashmaster is offline   Reply With Quote
Old 05-12-2013, 02:07 PM   #501
Anybody else running a 13.5 Orca tx with the flow works and finding it a bit flat/slow?
Mi4cxl is offline   Reply With Quote
Old 05-12-2013, 11:50 PM   #502
spencehotbodies's Avatar
Originally Posted by Crashmaster View Post
Hi guys,
Dan
The only difference I found is the heat build up, I run the 2 nosram versions. The works does have more fets to handly the heat.
Xray T416- Xray X1-Spec-r-Sanwa-Orca-Ame-Arrowmax-Wild turbo fans
West London Race Club
spencehotbodies is offline   Reply With Quote
Old 05-13-2013, 01:08 AM   #503
Thanks for that - did you have thermalling issues with the non works version then?
Just pondering what to go for as I'm unlikely to run mod!
Old 05-13-2013, 01:12 AM   #504
Hello
No problem with heat, I run 13.5 boosted as well. Just back to back running there was a heat difference when checking the speedo.
Old 05-13-2013, 03:07 AM   #505
defcone's Avatar
Trader Rating: 15 (100%+)
I ran it in 17.5 and found was hard to get bottom end out of it.
defcone is offline   Reply With Quote
Old 05-13-2013, 05:00 AM   #506
I'm not getting top or bottom end. Smooth as butter on power. But just doesn't seems to have the legs when compared to an x20/flow setup.
Old 05-14-2013, 02:07 PM   #507
yumlailai's Avatar
Will the old Bridge work with the Flow esc update? I just tired and it doesn't seemed to work.....
yumlailai is offline   Reply With Quote
Old 05-14-2013, 02:40 PM   #508
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
No
Need ver2 bridge
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 05-15-2013, 01:08 AM   #509
Jamesalex's Avatar
I am currently running a reedy sonic 13.5 with my flow in boosted class and have speed but I am still left needing some more compared to the competiton.
I was wondering what motor combo's everyone is running with the flow. How's the x20/flow combo holding up or anyone run the flow with the GM or vampire motor.
www.cmcc.org.uk
www.mmrflux.co.uk
www.hpiracing.co.uk
www.hotbodiesonline.com
Jamesalex is offline   Reply With Quote
Old 05-17-2013, 07:06 PM   #510
Bill K's Avatar
Im running the FLOW Works team, installed with stock firmware running a Thunder Power 17.5 motor. Can anyone suggest settings for the esc? The way I have it now works, and with extremely low motor temperatures but Im feeling it a bit weird to drive.
Thanks in advance
Bill
Bill K is offline   Reply With Quote
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12532 06-12-2017 04:14 PM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
