Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree1Likes
Old 04-24-2013, 01:50 AM   #481
Would I be ok to wire a much more high speed fan to the connector for the existing fan? My lrp fan has given up the ghost.
Mi4cxl is offline   Reply With Quote
Old 04-24-2013, 01:58 PM   #482
Hey guys,
I am wanting to know whats the lowest turn motor you can use with the standard flow with 3.7v? it doesnt state anything on website
Cheers
Kevin
HBRC-LBD is offline   Reply With Quote
Old 04-24-2013, 10:10 PM   #483
Mike Haynes's Avatar
Originally Posted by JustWill75 View Post
Do anyone have this thing working with windows 8 yet? I'm still running the the out the box settings in 17.5 TC with a Reedy Sonic mach 2.
Yes i have for the past month with no issue so far, you have to disable the driver signature enforcement requirement in windows, then install the lrp link and driver.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 04-25-2013, 09:42 AM   #484
Default Pulsing
Hi, can someone tell me what could cause pulsing or pulsating? Also the radio sync seems to drift quite a bit. For example after I sync initially I get steady throttle and then after a while it drifts where I don't. Goes full throttle and cuts back back on back off etc. At all throttle settings it drifts.
I have a spectrum 3s radio with a 3520 dsm2 receiver.
eldridgejoe is offline   Reply With Quote
Old 04-25-2013, 10:03 AM   #485
AdrianM's Avatar
The search function is not letting me look for "1s". Has there been any mention of a 1S version for 1/12 or WGT?
Adrian Martinez
Old 04-25-2013, 02:41 PM   #486
JustWill75's Avatar
Send a message via AIM to JustWill75
Thanks Mike.....
Do you have any tips for a good starting point for a Flow Works pushing a Reedy Sonic M2 17.5 Blinky on a short track 100x50? Gering and Timing would be cool to bro. You know of course when you got time.
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
Old 04-25-2013, 06:14 PM   #487
Thanks Mike.....
For blinky i was using 2,2,0,0,0 for 2s application, not sure what class your referring to?
Old 05-02-2013, 08:21 PM   #488
Cridd's Avatar
Trader Rating: 16 (100%+)
I have the lrp flow works team and mode two brake ramp and brake type in version 3.3 I don't understand what that does? can somebody explain it?
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 05-05-2013, 08:32 PM   #489
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
+1
or what fan can I use as a replacement?
dontfeelcold is offline   Reply With Quote
Old 05-05-2013, 10:47 PM   #490
syndr0me's Avatar
Trader Rating: 32 (100%+)
My fan recently died as well. Luckily I'm too scared to ever try modified again, so I won't need it.
syndr0me is offline   Reply With Quote
Old 05-05-2013, 11:18 PM   #491
B00t13g's Avatar
Wait what?
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 05-07-2013, 03:39 AM   #492
Default Flow with new LRP X20 13.5T motor
Has any one used it with the new LRP X20 13.5T motor ?
Yokomo BD7 2015 (x2); Futaba 4PKR-S; LRP Flow; Teamwave Motors; Savox servos;
http://demonpowerproducts.co.uk/
mcdoogle is offline   Reply With Quote
Old 05-07-2013, 05:48 AM   #493
peter.'s Avatar
I have a lrp esc flow and want to buy a 4.5t engine which is working the
best the thunder power or the speed passion motor or is it better to use a lrp x20 4.5t
peter. is offline   Reply With Quote
Old 05-07-2013, 08:01 AM   #494
metalnut's Avatar
Trader Rating: 36 (100%+)
This past weekend, I had one of the wires on the power switch break, right at the soldering point on the switch. The wire is really thin and so vibration must have broken it. Something to watch out for.
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
Old 05-07-2013, 01:01 PM   #495
The flow and a x20 4.5 will be a very fast combo, you won't be dissapointed.
Smartypants is offline   Reply With Quote
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12525 03-20-2017 08:59 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
