Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree3Likes
Old 04-17-2013, 05:40 AM   #466
LoudOne's Avatar
Trader Rating: 31 (100%+)
I have Windows 7... When using the USB Bridge, does anyone know what file needs to be selected in Step 2: when it asks for the specific Firmware file? I'm able to establish communication w/ the esc in Step 1: but don't know how to get past Step 2: ???
Kyosho RB6.6, ZX6.6
Serpent SRX2 MM
X-RAY XB4 (2013), XB2 Carpet (2017)
Schumacher KF2
LoudOne is offline   Reply With Quote
Old 04-17-2013, 07:07 AM   #467
flyradio's Avatar
I use Flow with the motor LRP LRP 13.5t stockspec boost.
My 7-digit setup 2344813 6.0 ratio with 40m straight track. When 3 minute run, my ESC losing power, when I check my esc, it shows a blue flickering (like 0 boost indicator). Is it my ESC overheat?
Team TRF Malaysia
flyradio is offline   Reply With Quote
Old 04-17-2013, 08:04 AM   #468
geeunit1014's Avatar
Yes, if the esc overheats and you have thermal protection on, it will go to blinky. I think 6.0 is probably overgeared for 40m, I would drop gear to 7.0, and maybe try different settings (Less aggresive ramp maybe). You may also find the thermal cutoff is premature, and you may be okay turning it off completely (last setting 0). Make sure to watch all your temps if you try this though.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 04-17-2013, 09:11 AM   #469
peter.'s Avatar
try the 7.5 ratio and mode 7 (lipo cutoff voltage) on disabeld
peter. is offline   Reply With Quote
Old 04-17-2013, 10:11 AM   #470
flyradio's Avatar
Thanks geeunit1014 u're much help
Team TRF Malaysia
Old 04-17-2013, 01:10 PM   #471
Cridd's Avatar
Trader Rating: 16 (100%+)
Yes you need the file ending in .lrp. when you click it it goes to step 3.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 04-17-2013, 01:20 PM   #472
Cridd's Avatar
6.0, I usually run a 72-29 or 72-30 on my 13.5 reedy with flow works. Try dropping gearing one tooth at a time and check your engine temps and get a temp gun on your esc too. You can run a fan if needed. You can set all your modes to blinky and increase each mode that has to do with esc slowly also, takes some test time but you may have one setting off a little especially on that 130 foot straight.
Chris
B6D / T5M / SC5M
Old 04-17-2013, 03:54 PM   #473
flyradio's Avatar
72/29? I guess youre running blinky
Team TRF Malaysia
Old 04-18-2013, 03:31 AM   #474
peter.'s Avatar
I usually run a 4.0 whit 13.5 sp
Old 04-18-2013, 10:01 PM   #475
Cridd's Avatar
Yep.
Chris
B6D / T5M / SC5M
Old 04-22-2013, 07:34 AM   #476
JustWill75's Avatar
Send a message via AIM to JustWill75
Do anyone have this thing working with windows 8 yet? I'm still running the the out the box settings in 17.5 TC with a Reedy Sonic mach 2.
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
Old 04-22-2013, 05:03 PM   #477
Cridd's Avatar
Last I looked it was not.
http://www.lrp.cc/en/service/software-update/
Notice:
The Win software currently canít be used with Windows8. The software update works with all other Windows versions without any problems.
Chris
B6D / T5M / SC5M
Old 04-23-2013, 07:26 AM   #478
Default boosted or blinky
running 10.5 boosted ver 5.0 software loaded is this best for this set up or is there another version to use.
RCvetran is offline   Reply With Quote
Old 04-23-2013, 10:22 PM   #479
Cridd's Avatar
Version 3.3 is more of a mod. I run 5.0 on 17.5 and 13.5 and 3.3 on my 9.5 and 7.5.
Chris
B6D / T5M / SC5M
Old 04-24-2013, 12:06 AM   #480
metalnut's Avatar
Trader Rating: 36 (100%+)
Which firmware would you guys use with 21.5 (VTA)?
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12544 10-09-2017 08:03 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
