Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree3Likes
Old 02-28-2013, 01:07 AM   #376
Bill K's Avatar
I highly doubt its the flow if your other motor worked fine..
Bill K is offline   Reply With Quote
Old 02-28-2013, 02:00 AM   #377
The other motor worked fine providing I didn't turn the boost up too muh. If I went over setting 8 on either boost settings it would go into an almosy blinky mode at full throttle.
Mi4cxl is offline   Reply With Quote
Old 02-28-2013, 02:01 AM   #378
And that motor was fine with my previous speedo (reventon pro)... luckily I've still got it to hook up to the sonic to see if it works fine with that.
Old 02-28-2013, 03:50 AM   #379
Bill K's Avatar
In that case it might be your flow...
Send it back.. go tekin with 2.5 t, you'll love it
Old 02-28-2013, 08:00 AM   #380
Company Representative
Trader Rating: 15 (100%+)
Originally Posted by Mi4cxl View Post
Dam. Having another issue now. Fitted the reedy mach 2 into my car just (13.5) Between half throttle & just before full throttle the motor starts stuttering like a bad case of cogging. I've changed the sensor wire to no avail. It was perfect with the speed passion I was running previously. Anybody any ideas???
Just a thought, What radio are you using? I had a similar exp with one of my SXX SS's last year after switching to the M12 radio.. If I had "chan 2" binded with anything other then "Normal" ( 3X possible setting choices are Normal, SHR and SSR) for the speedo chan on the rx, I would get the exact same sinereo that you are having... It would start to boost then it would die out....... I tried everything... even another SS speedo motor you name it.... same issue.. Thats when I went hunting into the radio setup.
Here is how I setup:
My default is "normal" for all chan's on the RX except for chan 1 ( servo) where I run the SSR setting because I use Sanwa servo's.. However chan 2 will work in "SHR" if you use just blinky class.. But as soon as you add boost, you will have the same issue.. At least in my testings.
Hope this helps.
WCICS- Competition Director
Korgae is offline   Reply With Quote
Old 02-28-2013, 09:34 AM   #381
I'm using a ko esprit universe 3 40mhz.... Coming to the conclusion that it's the speedo. But like hell i'm sending it away only to be told theres no issue with it (As i've read a few people have) and then charger a 15 handling fee!!
Getting a video up soon.
Old 02-28-2013, 10:42 AM   #382
https://www.youtube.com/watch?v=Nv4h...e_gdata_player
Not the easiest thing to hear as there is a lot of noise for this crappy phone recorder. But you can physically see the car shaking when the stuttering of the motor starts. But when full throttle is reached itnsounds perfectly ok & bloody lovely if you ask me!
Old 02-28-2013, 01:23 PM   #383
Bill K's Avatar
Try spectrum receiver and radio? It might be your radio failing to transmit.
It looks like something from an aircraft model
Old 02-28-2013, 01:24 PM   #384
Radio is fine, worked perfect with everything else ive got. Still the best handset made imo. Not for planes ;-)
Old 02-28-2013, 02:48 PM   #385
Shows off the issue much better.
https://www.youtube.com/watch?v=p2Es...e_gdata_player
Have tried it with a gm 17.5 & team powers 13.5 both of which worked and revved smoothly. Looks like the flow (or maybe just mine) doesn't like the mach2 motor!!
Old 02-28-2013, 09:17 PM   #386
Cridd's Avatar
Trader Rating: 16 (100%+)
When you bound the radio to the esc everything was set to 100%. Have you upgraded to the newest firmware on the esc? Wires are on motor correctly? May just be bad board on the esc.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 02-28-2013, 10:33 PM   #387
Blueman Austria's Avatar
Default Wich one to choose?
Hy there!
Im planning to get a flow to replace my SPXZero, an dnow i wanted to ask if there are any noticeable differences in Blinky mode 17,5T Racing between the competition and the works Team?
I think the comp. is far enough because i max, run 10,5T Motors. So it should be fine.
Are there any reasons to go for a Works Team?
Greets Rainer
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 02-28-2013, 10:55 PM   #388
Everything is set as it should be, v5 is loaded, my soldering is perfect.
Old 02-28-2013, 11:01 PM   #389
Cridd's Avatar
Yep bad esc, I'll buy it for 50 bucks if you want to sell it.
Chris
B6D / T5M / SC5M
Old 02-28-2013, 11:14 PM   #390
If you read above. I've tried it with another two motors, both from different manufacturers, which worked perfectly.
So I'm more inclined to believe I've got a dud motor (despite it being brand new)... Think I may send t back and exchange it out for a lrp x20.
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12544 10-09-2017 08:03 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
