Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree3Likes
Old 02-13-2013, 02:44 PM   #346
Cridd's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Cridd View Post
what is the difference between drag brake and initial brake?
I think it is initial throttle?
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 02-13-2013, 08:01 PM   #347
AE-Reedy
Do you mean feel/initial drive? It could also be refered to as minimum drive.
That is how slow the motor will go when you first move into the acceleration zone of the trigger. If you run mod on a slick track you may want to use a low number, say 1. If you run 17.5t on a grippy track you might want to use 5, this will make the motor feel faster on the low end. It is really just a driver preference for his trigger feel.
Sean Cochran is offline   Reply With Quote
Old 02-16-2013, 02:52 PM   #348
YAH
YAH's Avatar
Trader Rating: 77 (100%+)
Questions?? USB Bridge spec 2 (81801) Mac software
Hi, I hope someone can help me with this.
I bought a Flow Competition ESC and a USB Bridge spec 2. I use an imac. I downloaded the firmware driver from the LRP site okay. When I click on the LRP Firmware Update Tool 2.0.7 icon to install the software (presumably that is what to do as I could not find any instruction), all I get is a pop up message that says "LPR Firmware Update Tool 2.0.7" is damaged and can't be opened. You should eject the disk image. I have tried to download it 3 times from scratch deleting the previous download first but still got the same result.
Anyone has any clue on this.
Alfred
The only Surviving Active Life membership of the Smash 'EM! Racing Team, WA's Home of Fun in RC Motorsport, has retired!!
2013 WCMRC club champion - VTA and Mini.
YAH is offline   Reply With Quote
Old 02-21-2013, 08:44 AM   #349
Having a small issue with mine. Have changed sensor wires and motors before anybody asks that.
Changed the software to v5 the other day... set boost & trigger etc to around 6 to start with. Revs up great. Green light stays on... but if I start going up towards 8-10 on these settings the car will not rev out. (This is free standing I know I shouldn't but I've nowhere to test it all works)... the green led drops out & solid blue comes on. The car stutters before it reaches full throttle & then sounds as if it's in blinky mode. Any idea on this? Cheers.
Mi4cxl is offline   Reply With Quote
Old 02-21-2013, 10:30 AM   #350
Right. Been tryig different things. By leavong everything else turned up. N turning down the turbo boost to setting 2-3 it allows me to get to full throttle. So I'm assuming it's just too much timing through the motor.
Old 02-22-2013, 01:49 PM   #351
Cridd's Avatar
going to upgrade mine tonight t v5, on AE website set up sheets look like drivers are running more brake in the Flow compared to the SXX V2.
Chris
B6D / T5M / SC5M
Old 02-23-2013, 03:13 AM   #352
Turned on Torque Timing (despite using a speed passion mmm 13.5) and this appears to have solved my issues. Revs out with no stuttering or issues.
Old 02-23-2013, 08:52 AM   #353
Cridd's Avatar
What is your 7 digit set up?
Chris
B6D / T5M / SC5M
Old 02-23-2013, 09:08 AM   #354
I copied Ollies set up from Mendip which is on the Ae website.
Off the top of my head its 2548750
Old 02-23-2013, 12:08 PM   #355
Evening everyone
Just about to upgrade my flow works to v3.3 for off road racing. Might be a stupid question but on the brakes there is now the option of brake ramp and break type (semi x & x brake) can some one tell me the what this is all about. Thank you
thorny97 is offline   Reply With Quote
Old 02-23-2013, 09:09 PM   #356
Cridd's Avatar
upgraded to 5.0 last night, went great. glad I did it to a new flow instead of setting up than doing it. ran from 2 to 3 on initial brake, but think I will try 4 or even 5.
Chris
B6D / T5M / SC5M
Old 02-23-2013, 10:24 PM   #357
Bill K's Avatar
Im running a 13.5 with everything turned all the way up. the motor barely scrapes 65 degrees celcius and its a rocket!!
Bill K is offline   Reply With Quote
Old 02-23-2013, 10:55 PM   #358
ChadB.'s Avatar
Trader Rating: 21 (100%+)
Are there any places in the USA that has them in stock? I have been checking Amainhobbies, Stormer and Speedtech and none of them have had it in stock for some time.
Chad Burdick
*Mugen Seiki*Flashpoint Racing Products*9th Annual Timezone Grand Prix July 13th-16th 2017*Unique Air Design*TimezoneRacing*RoseCityScaleRacers* Daves RC Track
ChadB. is offline   Reply With Quote
Old 02-23-2013, 10:57 PM   #359
Bill K's Avatar
Rcmart has them on special for $200 + free shipping.
Check it out!
http://www.rcmart.com/flow-worksteam...Path=1560_1021
Old 02-24-2013, 12:12 AM   #360
spencehotbodies's Avatar
Hello
What settings did you run?
spencehotbodies is offline   Reply With Quote
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12544 10-09-2017 08:03 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
