Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree3Likes
Old 02-10-2013, 06:52 AM   #316
Default constant 6V BEC for 1S
Hi,
Can someone advise if the new Flow ESC support 6V BEC for 1S operation ?
My blog: http://ongbenghui.blogspot.com
ongbenghui is offline   Reply With Quote
Old 02-10-2013, 09:45 PM   #317
spencehotbodies's Avatar
Hello Luke
Do you still have those 13.5 thunder power settings? If so what would you change if you want to run 30d turning on the motor?
spencehotbodies is offline   Reply With Quote
Old 02-10-2013, 11:55 PM   #318
Cridd's Avatar
Trader Rating: 16 (100%+)
13.5 running an SXX V2 now going to run a Flow what can I expect.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 02-11-2013, 12:10 AM   #319
Hello
In the same boat, I think much smoother power delivery, have you up dated to v5 software?
Old 02-11-2013, 12:11 AM   #320
Julius's Avatar
Originally Posted by ongbenghui View Post
Hi,
No. There is no booster. So for 1s you'll need to run a seperate booster or receiver pack.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 02-11-2013, 05:04 AM   #321
Okie. thanks!
Old 02-11-2013, 01:17 PM   #322
mark-rc's Avatar
I've just read that the LRP Flow works team speedo 'ONLY' works with LRP, Nosram, Orion and Tekin motors! Is this correct??? as I have just ordered one.
ANSWER-RC, HB, Sworkz, X-Act, Xpert RC, Novarossi
mark-rc is offline   Reply With Quote
Old 02-11-2013, 01:23 PM   #323
scoyle's Avatar
I'm using mine with a Reedy Sonic 10.5 and 13.5 if that's any good
Web Site: http://www.rcracingreviews.net
Sponsors: Schumacher UK | XFactoryUK | Zen Racing
scoyle is offline   Reply With Quote
Old 02-11-2013, 01:58 PM   #324
Cridd's Avatar
Originally Posted by spencehotbodies View Post
Hello
No I haven't but will tonight. Just finished sons new car (he went with Viper) now I am starting mine LRP, Reedy, hope the Mach 2 come out quick.
Chris
B6D / T5M / SC5M
Old 02-11-2013, 04:18 PM   #325
Trader Rating: 30 (97%+)
so overall is this worth gettting?
laceup is offline   Reply With Quote
Old 02-11-2013, 04:19 PM   #326
What am I to expect in terms of performance and driveability switching to a flow works over a reventon pro??... Any issues?
Mi4cxl is offline   Reply With Quote
Old 02-11-2013, 04:40 PM   #327
AE-Reedy
I think a more correct description should be "any 540 sensored motor will work with the Flow Works team."
Sean Cochran is offline   Reply With Quote
Old 02-11-2013, 09:46 PM   #328
Hello
I don't think that's right, I will be running mine with a thunder power 13.5.
I have been running with Sxx 2 stock spec, with the up dated board and it will Defentley because up grade on that. And with v5 firmware it will at the cutting edge for stock.
Old 02-12-2013, 04:05 AM   #329
I'm using mine with a Thunderpower 13.5T motor & a mate is using GM 13.5 T motor.
Yokomo BD7 2015 (x2); Futaba 4PKR-S; LRP Flow; Teamwave Motors; Savox servos;
http://demonpowerproducts.co.uk/
mcdoogle is offline   Reply With Quote
Old 02-12-2013, 04:45 AM   #330
Hello
Do you have a good starting point to rub thunder power 13.5? I will also be running the new v5 firmware. Am running 6.4 gearing.
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12544 10-09-2017 08:03 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
