Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 02-04-2013, 02:40 AM   #301
Hello!
What can replace the old capacitor? How to choose right?
What are the characteristics?
http://www.ebay.com/itm/4-Nichicon-N...item43aae19c5c
Normal?
kentOLOLO is offline   Reply With Quote
Old 02-04-2013, 04:23 AM   #302
feizal917's Avatar
Originally Posted by minez View Post
Its nothing wrong with your Flow. Have you check the version on your Flow? My friend also happen to his Flow Competition and have been update to V5.0
Tq! But how to check and update?
feizal917 is offline   Reply With Quote
Old 02-04-2013, 05:04 AM   #303
You have to buy Lrp Usb bridge V2 and install the tools on Lrp website.
http://www.lrp.cc/en/service/software-update/
minez is offline   Reply With Quote
Old 02-04-2013, 07:41 AM   #304
jag88's Avatar
Originally Posted by formosa008 View Post
I had problem with USB Bridge before using Windows 7 (64 bit)
What was wrong is when plugged in the USB the windows automatically installed wrong driver in the system. Goto control panel and check your hardware driver, check on the USB bridge and reponit the driver directory to program files/LRP Firmware Update Tool 2.0/ and you should get your driver install correctly.
Before you do that, install the Update tool software first
Thanks formosa008. I'll give it a try.
jag88 is offline   Reply With Quote
Old 02-04-2013, 10:25 AM   #305
spencehotbodies's Avatar
hello
Can some one please talk me through how to update my flow to v5 software please on w7.
have downloaded the driver and after connected the usb, the blue light goes solid, so thats all good.
but when i try to download the firm ware, i can't find it???
help please.
spencehotbodies is offline   Reply With Quote
Old 02-04-2013, 03:03 PM   #306
Aaron_M's Avatar
Has anyone had any problem with the LRP flow V1.4 runinning boosted and using LRP X12 motor?
Was running a LRP X12 10.5 on my Hobbywing ESC with no problems, then put it on my LRP flow. It ran ok but then 3 minutes in it began to stutter, then no power then all of a sudden lots of power.
Changed sensor cable and still didnt cure it. Also it is not the ESC as i put a Reedy Sonic 10.5 on it and its fine.
Any ideas?
Yokomo BD7
Aaron_M is offline   Reply With Quote
Old 02-04-2013, 06:32 PM   #307
Jochim_18's Avatar
What's the green led mean when it starts bliking and motor cuts off?
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 02-04-2013, 11:14 PM   #308
Has anyone tried LRP Flow with Non-LRP brand motor? My flow with Dualsky motor can't get top end out...it stucks at around 15000rpm and can't get any higher.....I have tried 13.5 boost, 6.5, 5.5 none of them can get it to work. It feels like the motor is running with broken sensor cable (but my cable is working).
formosa008 is offline   Reply With Quote
Old 02-05-2013, 08:49 AM   #309
Hello
If any body having a problem with window 7, a friend got his working by dragging the v5 firmware file on to the desktop, don't open it in any other way.
Hope that helps.
Old 02-05-2013, 10:47 AM   #310
JustWill75's Avatar
Send a message via AIM to JustWill75
I mainly run stock blinky classes and wanted to get a Flow to replace my Tekin. I notice 2 versions of the flow and found a great deal on the lesser one. What is the diffrence between the 2 versions and will I notice it in my 17.5 TC?
How do these ESC 's compare to a current Tekin.
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
Old 02-05-2013, 04:05 PM   #311
Cridd's Avatar
Trader Rating: 16 (100%+)
What I read is that one is for 9.5 turn motors (Competition) or higher and the other one (Works) is for 3.5 turn motors or higher.
crappy marketing and terminology I think.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 02-05-2013, 06:07 PM   #312
JustWill75's Avatar
Would I notice a difference between the two in 17.5 TC?
Old 02-05-2013, 06:26 PM   #313
rangerjkb's Avatar
Trader Rating: 36 (100%+)
Send a message via MSN to rangerjkb
Only used it in Boost 0 mode, but it has worked with Murfdogg, Trinity, and Reedy motors correctly. (This is after recieving a new one, when the first one was bad right out of the box). So far I like its performance characteristics.
Jason Burks
Murfdogg Products~Psycho Cells Racing~Hal's Hobby Warehouse~Avid RC~Kal-Gard~VP Powermaster
rangerjkb is offline   Reply With Quote
Old 02-05-2013, 06:50 PM   #314
DEE SPEED's Avatar
Default -
low voltage cut off
Serpent GT Cobra - Velox V8 Picco Evo - Team Orion - Atomic
T4'14 Xrays - Speedpassion - LRP - Hobbywing -Team Power - OS speed - SanWa - KO Propo - Kyosho - PN racing
DEE SPEED is offline   Reply With Quote
Old 02-09-2013, 10:38 AM   #315
hello
am awaiting my flow to be posted, am looking for a set up to run a 13.5 thunder power motor with 6.2 gearing with a fan.
cheers inadvance
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12531 05-24-2017 01:41 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
