Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree3Likes
Old 01-27-2013, 07:04 PM   #286
B00t13g's Avatar
Definitely man! I'm hoping the x20 4.5 I have is prett good! I pulled out the x12 17.5 and am never running it again. Completely useless lol
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 01-29-2013, 01:23 PM   #287
B00t13g's Avatar
What are normal temps to expect out of a mod motor and speedo?
Lrp flow team works 130
Lrp x20 4.5 125
After 5.5 minutes gearing at a 9.1 in blinky medium carpet track. Both the esc and motor have a fan.
Mackenzie Meyercord
Old 01-29-2013, 05:32 PM   #288
rangerjkb's Avatar
Trader Rating: 39 (100%+)
Send a message via MSN to rangerjkb
Used the LRP FLow Team Works last 2 weeks in 17.5 blinky with surprisingly great results. Very linear throttle and strong brakes. Have tried everything with X12 motors, but nothing could get them to be highly competitive in stock blinky.
Jason Burks
Psycho Cells Racing~Hal's Hobby Warehouse~Murfdogg Products~Avid RC
rangerjkb is offline   Reply With Quote
Old 01-29-2013, 09:06 PM   #289
Trader Rating: 20 (100%+)
Lrp x20 4.5 125
TC Mod? We run a large outdoor track and my SXX and X12 liked to be around 160 and 180 respectfully. 125 and 130 are just barely putting any load on those.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 01-30-2013, 03:31 AM   #290
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Is there a way to determine which version usb bridge i have? I have used it with my SXX stuff with no problems but dont want to risk it with my flow. Will it just not work if it's the old one or will it jack something else up?
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 01-31-2013, 06:22 PM   #291
jag88's Avatar
I'm having problems updating my Flow to ver 5 stock mode.
I download the firmware and the software from the LRP web site and when I plug in the USB bridge (spec 2) the blue l.e.d. on the bridge starts blinking. According to the bridge instructions it is suppose to turn on (not blink) after it has seen the driver file. It does try to find the driver file and when it fails it asks me 'to insert the disc that came with your LRP bridge'. There is no disc.
I think there is a problem with the bridge because as soon as I plug it in it starts blinking and there'd nothing in the instructions that mentions that.
ANYBODY !! ... please help ...
jag88 is offline   Reply With Quote
Old 01-31-2013, 11:02 PM   #292
nerdling's Avatar
What version of Windows are you running? I had trouble with getting it to work on 7 but everything was fine on XP.
The driver is downloaded as part of the software. If Windows can't locate a driver automatically it will prompt you to insert a disc, when this screen appears you should get the option to browse to the location of the driver file, do this and following the prompts and you should be ok to install the driver.
Getting it to work might be harder.
If you’re not running XP (but you are ruing Vista/7/8) you need too much around with setting the .exe files to run in compatibility mode (I would suggest WinXP) and make sure you run it with administrator privileges.
To confirm the Bridge2 is working try it on another computer.
Good Luck
--XRAY--NOSRAM--PROTOFORM--MUCHMORE--
www.teamxray.com -- www.hudy.net -- www.hobbyexpress.com.au
nerdling is offline   Reply With Quote
Old 02-01-2013, 01:24 AM   #293
spencehotbodies's Avatar
Hello
What software Vesion does the flow come with?
spencehotbodies is offline   Reply With Quote
Old 02-01-2013, 06:21 AM   #294
Damon's Avatar
Originally Posted by spencehotbodies View Post
Hello
1.4
Awesomatix A800
Awesomatix A800X
Damon is offline   Reply With Quote
Old 02-01-2013, 09:33 AM   #295
jag88's Avatar
Good Luck
Thanks for the reply !!
I tried running it on Vista and then on XP. On both computers the bridge starts blinking immediately when I plug it in which according to the instructions should not happen. On the computer with XP it doesn't even look for a driver file. No windows come up.
I'm at a total loss here, anyways thanks again.
Old 02-01-2013, 09:14 PM   #296
Cridd's Avatar
Trader Rating: 16 (100%+)
Just bought a flow, I have a SXX what settings should I start with on my 13.5. Right now my SXX is 3-0-5-3 and then 3-0-0-3 when blinky?
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 02-01-2013, 11:44 PM   #297
Default LRP USB Bridge
I had problem with USB Bridge before using Windows 7 (64 bit)
What was wrong is when plugged in the USB the windows automatically installed wrong driver in the system. Goto control panel and check your hardware driver, check on the USB bridge and reponit the driver directory to program files/LRP Firmware Update Tool 2.0/ and you should get your driver install correctly.
Before you do that, install the Update tool software first
formosa008 is offline   Reply With Quote
Old 02-03-2013, 08:50 AM   #298
feizal917's Avatar
hi everybody!
Wanna ask you guys something. Just bought Flow and it state clearly in the manual that in Mode 6, the turbo timing got 4 selection. But mine got 5. Is that normal or there is something wrong with my Flow?
feizal917 is offline   Reply With Quote
Old 02-03-2013, 10:01 PM   #299
Originally Posted by feizal917 View Post
hi everybody!
Its nothing wrong with your Flow. Have you check the version on your Flow? My friend also happen to his Flow Competition and have been update to V5.0
minez is offline   Reply With Quote
Old 02-03-2013, 10:26 PM   #300
B00t13g's Avatar
Well my flow popped today the second I turned it on for no apparent reason. Sending it back to Lrp for warranty and selling it. Back to Orion's I go. The brakes aren't quite as good, but they've never failed me.
Mackenzie Meyercord
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12544 10-09-2017 08:03 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
