Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree1Likes
Old 01-19-2013, 08:37 AM   #256
Cridd's Avatar
Trader Rating: 16 (100%+)
Originally Posted by geeunit1014 View Post
1. Smoother Throttle profiles, can adjust throttle profile while in blinky
2. More boost adjustability, mod & stock boost profiles on one ESC
3. Aluminum case
4. "U" solder tabs
5. Improved BEC reliability
I also saw a small drop in motor temps in 17.5 blinky TC, 5-10*F.
LRP have also released new firmware that more specializes the profiles, 1 for offroad (mod), 1 for onroad(mod), and one for stock racing.
Cool, will put one in B4.2 when it gets here, like my SXX.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 01-19-2013, 10:45 AM   #257
LEM C's Avatar
Default settings
I received my Flow the other day and installed it last night. It's all setup with settings and gearing which I believe will work but I wanted to get a second opinion. Here's what I got: Flow w/Ballistic 7.5 @40 deg endbell timing
112/29=7.72 ratio
settings=5,3,1,6,3,0,3
track is 100x48 carpet/technical w/sweeper
RC Cars-Lipos-ESC-Brushless Motors-Surface Radio-Carpet Track-Asphalt Track
LEM C is offline   Reply With Quote
Old 01-20-2013, 04:39 PM   #258
Send a message via Yahoo to goinbrokeracin
I recently had my LRP SXX TC Spec Ver 2 sent back to have the new board installed. Will I now need Ver2 of the USB bridge to update it or will the original version still work? Thanks.
goinbrokeracin is offline   Reply With Quote
Old 01-20-2013, 05:15 PM   #259
Nuno Gancho's Avatar
hi All,
any starting point for Flow on gearing and settings for modify with a 4.5T LRP X12.
thanks.
Nuno Gancho is offline   Reply With Quote
Old 01-20-2013, 05:43 PM   #260
Cridd's Avatar
112/29=7.72 ratio
On the SXX V2 there are only 4 numbers, more numbers looks like on the flow.
Chris
B6D / T5M / SC5M
Old 01-24-2013, 06:40 AM   #261
does the version 1 usb bridge work with the LRP Flow speedos?
Smartypants is offline   Reply With Quote
Old 01-24-2013, 06:49 AM   #262
Julius's Avatar
No
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 01-24-2013, 11:34 AM   #263
AE-Reedy
Yes, you will need the Spec 2 updater. However I do not expect there to be any firmware updates. That board was only intended to be a bridge from the SXX to the Flow. All future development will most likely be only on the Flow. This is just my opinion not official from LRP
Sean Cochran is offline   Reply With Quote
Old 01-24-2013, 11:41 AM   #264
James35's Avatar
Sean,
If you have any influence with LRP, ask them to offer an "Oval" firmware for the Flow. Starting at 5100 RPM is too late for most oval classes. And the ramping isn't fast enough. Even in 10.5, with the timing maxed in the D3.5 motor and in the Flow, it doesn't pull hard enough. It pulls too late down the straight and the motor comes off too cold. With the current firmware, I'd say it's only good for Open Mod. I am going to run it in Open Mod at the Birds, but I'd like to have the option for other classes.
James Van Horn
McPappy Racing
James35 is offline   Reply With Quote
Old 01-24-2013, 12:13 PM   #265
Julius's Avatar
Originally Posted by James35 View Post
Sean,
James,
I think a firmware with lower start rpms would be good for the 1s classes and especially the 13.5 and higher winds.
However using about 10 degrees more static and less dynamic timing creates a similar feel to the escs with lower start rpm.
For example i ran 2k start 12k end rpm with 45 degrees of oost on my tekin. Thattranslates in a 4,5 ramp angle in the flow. However at 5k rpm on my tekin i'd already have 15 degrees of timing.
So that is why with the flow i've increased the static by 10 (need to test 15) and reduced the dynamic boost by the same amount. Track performance is close to what i had with the tekin but with much better feel (as far as that is important. In 1s 13,5......)
Old 01-24-2013, 12:21 PM   #266
James35's Avatar
As I mentioned, I can't put more static into the D3.5 motor. It's maxed out. The Flow needs to be able to kick in the timing earlier and ramp faster than 3.5/K.
James Van Horn
McPappy Racing
Old 01-24-2013, 08:52 PM   #267
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 150 (100%+)
Is there a way to determine which version usb bridge i have? I have used it with my SXX stuff with no problems but dont want to risk it with my flow. Will it just not work if it's the old one or will it jack something else up?
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 01-24-2013, 09:46 PM   #268
spencehotbodies's Avatar
Hello all
What version of software does the flow come with?
Cheers
spencehotbodies is offline   Reply With Quote
Old 01-24-2013, 11:12 PM   #269
Julius's Avatar
Originally Posted by spencehotbodies View Post
Hello all
Cheers
1.4
Old 01-25-2013, 03:00 AM   #270
Julius's Avatar
Weird but true...
The stock specific sw only goes to 3,5 deg/ krpm
The std 1.4 sw has a 4,5 deg/krpm max angle!
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12525 03-20-2017 08:59 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
