Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree3Likes
Old 12-25-2012, 06:29 PM   #181
W_St's Avatar
Originally Posted by B00t13g View Post
He's running boosted. 4.0 is more of a blinky gearing. To anyone running an Lrp 17.5 x12 what timing insert are you using along with what settings on the flow?
Yes, I'm running boosted. I've already set "0" torque timing also, but there was no different. As far as I tried on 17.5T motor The smaller FDR result in smaller power, and the boost didn't come out.
I run on 25 meter long track. I'm starting frustated with this LRP Flow...
W_St is offline   Reply With Quote
Old 12-25-2012, 06:44 PM   #182
geeunit1014's Avatar
What motor do you have, and how much endbell timing?
I would think 1/3/0/9/10/3/0 with a 6.5 FDR should be a good place to start. You still want some endbell timing, how much depends on the motor.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 12-26-2012, 01:38 AM   #183
W_St's Avatar
Thank's for the answer guys, I'll try and update it soon...
Old 12-26-2012, 08:26 AM   #184
Also what settings/ timing insert for an x20 4.5 on a medium traction carpet track. 90x40
For X20 4.5T just use standard timing 4 dots 27.5
minez is offline   Reply With Quote
Old 12-26-2012, 09:27 AM   #185
B00t13g's Avatar
^ thank you.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 12-29-2012, 06:29 AM   #186
Originally Posted by scoyle View Post
Is the firmware that comes installed on the Flow Works the most up to date at the moment?
Has anyone a good set of settings for 10.5 boosted indoors on carpet?
I am really confused
Nosram have released the new software but there doesnt look to be any firmware?
The LRP website talks about using v4 software but the speedo comes with 1.4?
Also in mode 6 there are more settings than those that are in the manual?
Sponsored by Team Wave Online
www.teamwaveonline.com
stuartb is offline   Reply With Quote
Old 01-01-2013, 12:14 PM   #187
Happy New Year to you all :-)
So is there really only one person on this planet who is willing to post a setup?
I am looking for 17.5 & 13.5 Boosted setups in TC with X12 motors, can anyone help?
008-Racer is offline   Reply With Quote
Old 01-01-2013, 01:32 PM   #188
wtcc's Avatar
Hey guys
Does the Flow boost programs like the Reedy Sonic stock motors (10.5t/17.5t/21.5t) ?
Or would you recommend an other Esc for boosting the Reedy Sonic?
/// CAUTION: Rogue robot \\\
wtcc is offline   Reply With Quote
Old 01-01-2013, 04:39 PM   #189
AE-Reedy
Originally Posted by wtcc View Post
Hey guys
It hard to find help for boosted stock when the US has mostly gone no boost.
Sean Cochran is offline   Reply With Quote
Old 01-02-2013, 02:08 AM   #190
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
It really is just a case of trial and error unfortunately, I don't mind giving out my settings to a certain degree for a base line, and I know this sounds mean, but why should someone spend a day at the track refining settings (which is costing money) to then just give them away to someone who doesn't want to put in the time and effort.
I could understand that being harsh if I had any links to Lrp or Nosram but I don't. And as Sean mentions, hardly anyone in the US runs boosted now.
If its any help to WTCC, Olly J uses Reedy motors with boosted here...
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 01-02-2013, 02:15 AM   #191
scoyle's Avatar
Luke, it was great of you to give out your base settings - I was very glad to get my hands on them as it meant I was in the ball park from the start (and didn't blow a motor trying to find a base!). Thanks for your work.
I also agree with you that speedo settings are key now to a days racing and if you or the likes of Olly gave out settings then they would lose the advantage on the track as everyone would just copy them.
The other thing to take into account is that settings are very much down to track size, motor type and personal preference (whether you like a smooth or aggressive car) so anything other than the base that Luke has kindly given out would not be that much use.
I am hoping to get out with my LRP Flow this weekend for some practise and I will put my settings up here afterwards for 10.5 boosted but whether they are any use...
Web Site: http://www.rcracingreviews.net
Sponsors: Schumacher UK | XFactoryUK | Zen Racing
scoyle is offline   Reply With Quote
Old 01-02-2013, 02:24 AM   #192
Luke thanks for your message!
You've actually been a great help but your settings didn't work for me sadly
I was running a Reedy 17.5 & 13.5 but found it getting a little too hot and it also stuttered a little on full throttle, this did improve when I got rid of the torque timing but I just couldn't get any low end grunt
I have tried many things like gearing and reducing timing on the can and boost etc
But just when I think I am on top of it I go to a different track and its way off!!
I was just getting lost with it, I have now got X12's to see if they make life a little easier
I have spoken with OJ but sadly he is not running the same software that we all have :-( as his settings don't mean anything to what's on the instructions
I will continue to keep testing and when I find something that does work well I will be very happy to post it.
Old 01-02-2013, 02:29 AM   #193
scoyle's Avatar
I see that there is software listed on the LRP site;
http://www.lrp.cc/en/service/software-update/
and this shows as v2.0.7 - what version of firmware does this put on the speedo (or is it 2.0.7)?
I assume Olly has some untested firmware for factory drivers - any idea when this will be available for us mere mortals :-)
Old 01-02-2013, 02:34 AM   #194
I think the software you have linked to is just software to access the speedo
Sadly LRP haven't listed any Firmware updates that I can find
I don't know exactly what OJ is running but his settings don't match what I see on the sheet so it has to be different?
The benefits of being a factory supported driver I guess
Old 01-02-2013, 03:14 AM   #195
scoyle's Avatar
Ah got it now... I had assumed that the firmware came with the update software like the Hobbywing/HPI software that I have been using.
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12544 10-09-2017 08:03 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
