Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree3Likes
Old 12-19-2012, 06:50 AM   #166
Default spencehpotbodies
the SXX V2 with graded board is totally different to the flow. The flow has 7 adjustments the SXX has 4.
RCvetran is offline   Reply With Quote
Old 12-24-2012, 01:30 AM   #167
will this get roar approval?
shadow4478 is offline   Reply With Quote
Old 12-24-2012, 08:44 AM   #168
hey guys
i just picked up one of these flows for my tc and its the first time i will be running an lrp. does anyone know what the settings are right out of the box? unless i read the manual wrong it doesnt seem to give you a base line unless i read it wrong. any help would be greatly appreciated. thanks
jdick is offline   Reply With Quote
Old 12-24-2012, 11:58 AM   #169
Originally Posted by jdick View Post
hey guys
All the settings are just the minimum as default because there are so many combinations it would be impossible to set a "default".
Depending on the class, Luke Hobson put a post earlier that had some good settings.
stuartb is offline   Reply With Quote
Old 12-24-2012, 03:01 PM   #170
oh sweetness ill have to check those settings out. i just need a general ball park because im not going to be competitive because its my 2nd time driving a tc. just need it to go and stop and shut off at the right voltage for my esc. thanks for the help
oh and i forgot to mention its for 17.5 blinky.
Old 12-24-2012, 10:50 PM   #171
AE-Reedy
Yes it will be submitted after we have enough stock to be able to send units to ROAR.
Sean Cochran is offline   Reply With Quote
Old 12-24-2012, 11:31 PM   #172
B00t13g's Avatar
Any chance it will be in time for snowbirds or do I have to use my r10 pros for that
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 12-25-2012, 07:51 AM   #173
W_St's Avatar
Hi guys, could you help me please...
I'm new to LRP, now I installed LRP Flow Works team on my Tamiya TA06pro with 17.5T motor.
I've already tried FDR from 6.0 to 9.2 but the car still run like a turtle.
I set the FLOW: initial drive #3, torque timing#2, boost timing #10, boost angle #9.
I have also tried to combine between boost timing from #6 to #10, and also boos angle from #6 to #10. There is no significant changes
Is the FLOW doesn't fit for stock 17.5 racing or I did something wrong with the setting??
Please help me guys, and thank's before
Merry Christmast!
W_St is offline   Reply With Quote
Old 12-25-2012, 07:57 AM   #174
B00t13g's Avatar
Merry Christmast!
Torque timing is only for Lrp motors.
Mackenzie Meyercord
Old 12-25-2012, 09:32 AM   #175
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
How long is your track? The FDR combos you tried are way off for a 17.5 motor. Try 4.7 FDR as a starting point and work your way down until you start to get a drop off in power half way through your run, then go back a bit on the FDR.
I run 4.0 everywhere and just mess with the timing on the motor.
Racing4Evo is offline   Reply With Quote
Old 12-25-2012, 09:41 AM   #176
B00t13g's Avatar
He's running boosted. 4.0 is more of a blinky gearing. To anyone running an Lrp 17.5 x12 what timing insert are you using along with what settings on the flow?
Mackenzie Meyercord
Old 12-25-2012, 09:42 AM   #177
B00t13g's Avatar
Also what settings/ timing insert for an x20 4.5 on a medium traction carpet track. 90x40
Mackenzie Meyercord
Old 12-25-2012, 01:30 PM   #178
Losiho's Avatar
Always use the 4 Dot (27.5 degrees) insert with any sort of boosted racing with the X12.
Losiho is offline   Reply With Quote
Old 12-25-2012, 01:50 PM   #179
B00t13g's Avatar
What about for blinky 17.5 with the x12 and mod sedan with the x20 4.5?
Mackenzie Meyercord
Old 12-25-2012, 01:58 PM   #180
Losiho's Avatar
I don't race mod, sorry. I use a X12 17.5 in off road blinky - I use the 2 dot insert. I'm not sure what insert you would use for on road sedan. The trick with the X12 is to run the gearing & timing that keeps the motor under 80 - 85 degrees c max (180 - 185F). You can't run very much ESC timing due to the fact that 27.5 degrees of endbell timing is the lowest you can go.
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12532 06-12-2017 04:14 PM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
