Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 09-11-2014, 10:43 PM   #931
Josh-n-ya's Avatar
Trader Rating: 73 (100%+)
Originally Posted by RedBullFiXX View Post
Josh wants you to turn his up to 11
Spinal Tap! Yesssss lol
Josh-n-ya is offline   Reply With Quote
Old 09-11-2014, 11:46 PM   #932
Originally Posted by EAMotorsports View Post
VXX and VX1 only.
You should be able to turn the drag brake up so high that it will feel like your using push brake as soon as you let it off. If its not then its possible you have a speedo issue. Perhaps you have bumped your batteries wires backwards at one time. A slight bump can cause to blow some of the fets but still work in forward just fine.
EA
Thanks for the reply. Even with the drag set at 25% it makes no difference. With the wheels off the ground you can notice the motor braking but it is so slight that with the car on the floor it has no affect at all.
No chance of wiring issues as its new and never used in anger. I just thought someone may have had the same issue before?
dragonmount74 is offline   Reply With Quote
Old 09-12-2014, 03:41 AM   #933
Originally Posted by S I O View Post
EA or keith
any good starting set up for 13.5 blinky for the 4.1? outdoor asphalt/tamiya track
Here is my setup for the reedy race this year at the Tamiya track.
ORCA TX 13.5T motor timing @ 1.5-2.0mm passed the + line
FDR @ 3.95
Stock Blinky Mode
D.B. Off
B.F. 1K
Punch 8~10
PWM 8K
Initial B. 10%
Hope this helps! Have fun!
Keith Yu
Team ORCA/About RC Racing/Team Pro-Spec/CTRL Systems/
APS Racing/RCMISSION/Teamorca.shop/
[email protected]
Keith Yu is offline   Reply With Quote
Old 09-12-2014, 03:46 AM   #934
What kind of motor are you running? Mod or stock?
Have you try running different B.F. ?
Keith Yu
[email protected]
Old 09-12-2014, 08:16 AM   #935
Trader Rating: 152 (100%+)
FDR @ 3.95
Stock Blinky Mode
D.B. Off
B.F. 1K
Punch 8~10
PWM 8K
Initial B. 10%
is this for the 4.1 version?
thanks
S I O is offline   Reply With Quote
Old 09-12-2014, 09:54 AM   #936
Motor is an Orca TX 8.5T and again is new.
I have altered all the settings for brake force, drag, delay ect. In fact I don't think there is a setting I have not altered in order to spark it in to life!
Old 09-12-2014, 05:01 PM   #937
I will suggest you to reset the ESC by setting it to the default setting. and then try setup the D.B. again to see if this help!
Keith Yu
[email protected]
Old 09-12-2014, 05:04 PM   #938
thanks
I was using the Ver3.3 on that time.
You can use the same setup with the Ver4.1 I'm sure. It will only works better
Keith Yu
[email protected]
Old 09-30-2014, 11:06 AM   #939
Trader Rating: 8 (90%+)
Would this fry my Esc?
I'd like to use a orca vxx Esc ( rated 720a peak current) on a 4.5t 550 motor inside an off road 1/10 sc truck.
The manual says 540 motor type.
Can I get away with this or should I sell the Esc?
Boostgod is offline   Reply With Quote
Old 09-30-2014, 11:37 AM   #940
Odin544's Avatar
Trader Rating: 93 (100%+)
I see ORCA has a new ESC coming out. When can we expect to see the VX3?
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 09-30-2014, 11:41 AM   #941
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Some guys have ran 550 motors with them but I dont think you can go crazy with timing and such. Keith may be better to answer that question for you.
Anytime now.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 09-30-2014, 11:53 AM   #942
fitforbattle's Avatar
Why no built in switch?
Yokomo BD7 / SpeedPassion Reventon Pro AJ Edition / LRP x12 Vector Octa-wind 5.5T / Futaba S9352HV / Gens Ace 5000mAh
fitforbattle is offline   Reply With Quote
Old 09-30-2014, 12:03 PM   #943
Team EAM
Hey have too many issues and it would force you to mount your speedo only one direction too. Some cars this is not easy to do. The switch has a harness that plugs in and will have different lengths available. All black in color along with the receiver harness in different lengths all black as well.
EA
Contact Us
Old 09-30-2014, 12:10 PM   #944
EA
Actually... Now that you say it... I have all my speedos with built in switch in an awkward pos.
All black, different length harnessess sounds amazing.
Only reason I like the built in is because of the space savings.
Btw, is the vx3 for 1:10 tc 540? Stock and mod fw? I kinda feel it's time to try something new.
Old 09-30-2014, 01:05 PM   #945
Josh-n-ya's Avatar
EA
Yeah I prefer the external switch. Looks good. I just got hooked on the VXX but I do like new things. 😊. Oh building a mod and need a good setup for a VXX and using a 5.5 in tc. Thx
