Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 07-15-2014, 10:44 PM   #871
hydrakermit's Avatar
Originally Posted by JAM Racing View Post
having trouble down loading and getting the usb link operating...the computer is windows 8......any thoughts
Hi JAM
Check this out ORCA Team - VRITRA VX COMPETITON ESC
Just follow that and you wont have a problem, I followed it and updated mine fine.
HTH!
hydrakermit is offline   Reply With Quote
Old 07-16-2014, 06:51 AM   #872
I updated my program box and esc without loading default settings. What will gonna happen? How can I understand that my system works properly or not? The usb link belongs to my friend so I can not do it again in a short period
fasfury is offline   Reply With Quote
Old 07-16-2014, 06:23 PM   #873
Jerz616's Avatar
Trader Rating: 49 (100%+)
If you just updated your ESC from 3.3 to 4.0 or 4.1 it will automatically load the default settings. If you don't have access to the box regularly then you need to make your changes now as your previous settings will be changed.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 07-16-2014, 10:39 PM   #874
I have program box but I dont have a usb cable. I just updated both to vers4.0. without loading the default settings. You say that I did it correct, right?
Old 07-17-2014, 11:26 AM   #875
Jerz616's Avatar
You have to have the USB cable in order to update the ESC and box to a newer/older version of software. If you say both the ESC and box are ver. 4.0 then you can adjust the settings in the ESC.
Ryan Gracey
XRAY XB8'14
Old 07-17-2014, 05:25 PM   #876
BBJ
BBJ's Avatar
Hi,
I've been looking at the VRITRA VC4 Off Road Spec ESC for 2wd 17.5t blinky off road (yes i know this is on-road, but most recent discussions on ORCA are here). My question is, do these ESC's come with power capacitors or do they need to be purchased seperately. No mention of them being included anywhere. This particular ESC seems to be discontinued but is still available. From what i have read these appear to be able to be adjusted with the program box only, without the need for a PC to select profiles etc. Is this correct? I've only read good things about this brand, anything (bad) i ought to know before i go ahead with a purchase? Thanks...
BBJ is offline   Reply With Quote
Old 07-20-2014, 03:54 PM   #877
Was looking into trying one of these speedos. do I need the programmer to set it in blinky mode? How are they in the 17.5 blinky classes? I am currently running Hacker anyone know how they compare?
WEEZY is offline   Reply With Quote
Old 07-20-2014, 06:43 PM   #878
Jerz616's Avatar
I can't compare to hacker but I have been running mine for over a year now after switching from Orion. It should already bee in blinky mode and you will need the box to change anything. I would suggest just get the box at the same time. You can run it with stock out of the box settings but I doubt you will like it that way.
Ryan Gracey
XRAY XB8'14
Old 07-21-2014, 03:19 PM   #879
Trader Rating: 57 (100%+)
Anyone use the aluminum endbell for the TX motors? Notices any difference besides bling?
PROMODVETTE is offline   Reply With Quote
Old 07-21-2014, 09:35 PM   #880
Slightly lighter, and screws only go into the motor a certain point, so less chance of doing what I did and that's snapping the sensor board. Plus yes, it does look nicer
Old 07-21-2014, 10:46 PM   #881
The motor also runs a little bit cooler 6-7 degrees celcius
nitroargi is offline   Reply With Quote
Old 07-22-2014, 03:32 PM   #882
That's what I was wondering, if it actually ran any cooler. Its a pretty significant drop for just changing the endbell.
Old 07-25-2014, 01:25 PM   #883
Photocycler's Avatar
Trader Rating: 34 (100%+)
Couple questions
1) Is there a way to reset to factory defaults?
2) Where can i find good recommended settings for a 17.5 blinky TC?
thanks
Photocycler is offline   Reply With Quote
Old 07-25-2014, 06:47 PM   #884
Jerz616's Avatar
Originally Posted by Photocycler View Post
Couple questions
thanks
You can use your program box to set it back to default. Just select load default at the end of the menu. You can go to team-ame.com and get some setups. Here is what I ran when I ran blinky.
17.5 blinky
Punch at 10
Brake 2k
PWM 8k
Drag brake how you like it. Not much need for blinky so maybe 10
Initial brake about 10-15.
Ryan Gracey
XRAY XB8'14
Old 07-26-2014, 04:51 AM   #885
tdu verney's Avatar
Default Download
I have Windows 10, do I follow the same process for Windows 8?
tdu verney is offline   Reply With Quote
