Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 04-11-2014, 10:47 PM   #781
Josh-n-ya's Avatar
Trader Rating: 72 (100%+)
Damn!
Josh-n-ya is offline   Reply With Quote
Old 04-11-2014, 11:13 PM   #782
Still Bill's Avatar
Originally Posted by Josh-n-ya View Post
Damn!
Josh,
Just go to bed. It will make more sense in the morning...LOL
G-night.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 04-12-2014, 07:18 PM   #783
PEEKracing's Avatar
Does anyone know where I can find the 3.3 .bin firmware for the VXX? It's not listed on the Orca site, and if you try the one for the VX it tells you it's incompatible.
PEEKracing is offline   Reply With Quote
Old 04-13-2014, 08:32 PM   #784
Trader Rating: 57 (100%+)
http://team-ame.com/ame/downloads/
PROMODVETTE is offline   Reply With Quote
Old 04-14-2014, 11:16 AM   #785
Having a little issue with my orca VXX
I installed a brand new VXX in my car along with a Reedy 4.5
Calibrated the speedo to my radio and everything seems fine in blinky.
Then I used the program card to the manuals recommended settings for mod 4.5 and everything went well except under low throttle the motor isn't smooth, almost like a cog like a sensorless motor from a slow start. Once revs goes up it smooths out. Switched back to blinky and the cog went away. Also in reverse it's smooth in either mode.
What could be the problem? I tried another motor and sensor wire.
Played around with very low timing/turbo settings and still doesn't matter. Anything besides blinky is not smooth at low Rpms
Would appreciate any help.
XRAY T4 14 - Orca - Futaba
Serpent 811 Cobra GT-E - Tekin - Hitec
Serpent 811 BE 2.0 - Tekin - Hitec
Voltron989 is offline   Reply With Quote
Old 04-14-2014, 01:31 PM   #786
stikman's Avatar
try to reset the ESC and see if the problem will go away.
stikman is offline   Reply With Quote
Old 04-14-2014, 02:10 PM   #787
Reset how? I put everything back to default a few times using the program card and Ive recalibrated the radio and esc(hold brake and turn on)
Is there another way to zero everything out?
Old 04-14-2014, 05:37 PM   #788
A few posts up...
STEP 4: RESETTING THE SYSTEM TO UPDATE SOFTWARE
You must reset the system to the default setting every time you update the software. This is to make sure that the ESC and Program Card synchronize to each other correctly.
- Plug the ESC to the batteries and the Program Card
- Turn on the ESC
- Go to the Advanced program
- Enter either Stock or Modified mode as you would normally use
- Go to “Load Default”
- Press “ENTER”
- “Load Default Successful” message will be displayed
- Go to “Send” and press “ENTER”
- Turn off ESC and unplug batteries
- Turn on ESC to drain the capacity and wait 30 sec
- Turn the ESC off
- Plug the ESC to batteries and reprogram the ESC that you had before the software update.
Old 04-15-2014, 02:50 PM   #789
noline's Avatar
Anyone have have a boosted touring car setup for this motor. Running on outdoor asphalt
Orca Vritra VX
LRP X-20 7.5t (what timing insert should i use)
Along with a boosted setup what gearing
Thanx
noline is offline   Reply With Quote
Old 04-16-2014, 08:44 AM   #790
is there a email for support for ORCA that someone actually responds?
I emailed them from the contact email address on the website on sunday and no response.
Im about to throw this POS esc in the garbage. I've tried everything to smooth out the start/initial throttle on this esc with no luck what so ever.
I've reset and recalibrated the esc dozens of time. I tried another motor and sensor wire and removed all the timing from the motor (0 degrees)
with no timing programmed everything is smooth but if I even put just 1 degree of timing its rough again. Removing the timing from the motor helped somewhat but not very much.
I run on a very large track with a 220ft back straight theres no way in hell I could run with all the timing turned down.
The motor im using is a reedy 4.5T, Do I need a orca motor to be able to have it work properly?
If someone has a direct email to someone that could help me id really appreciate it.
Old 04-16-2014, 10:21 AM   #791
B00t13g's Avatar
Calibrate your radio.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 04-16-2014, 10:33 AM   #792
I have calibrated the radio to the ESC a bunch of times.
Doesn't make sense that it would be the radio anyways with no timing everything is fine, as soon as I go 1 degree of timing then it's rough again.
If it was a calibration problem I'd expect to have problem with or with out timing.
Old 04-16-2014, 10:40 AM   #793
Jerz616's Avatar
Trader Rating: 49 (100%+)
try resetting the esc or reinstalling the software. What software are you running?
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 04-16-2014, 10:41 AM   #794
emacrimes's Avatar
Having trouble with the USB link, the driver installer pops a message that it coudnt copy or install the INF files.
help with this
Agama A215
Ko Propo | Highest RC | Team Orion | Sweep |
emacrimes is offline   Reply With Quote
Old 04-16-2014, 10:51 AM   #795
Purchased the ESC and card from superior 2 weeks ago and they came with the v3.3 software. I've reset it a million times unless there's another way to reset it besides putting it back to default and loading new settings.
Also did what was mention above which is the same way but leave ESC unplugged with switch on to drain caps after switching to default.
