Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 03-24-2014, 04:51 PM   #721
Jerz616's Avatar
Trader Rating: 49 (100%+)
Originally Posted by Mister-E View Post
Just wondering, how do get the IR value of the battery?
I got the IR values from my Hyperion charger (not calibrated).
Also the values are different, depending on the amount of capacity you manage to push into the battery.
How do you measure it properly?
My icharger gives it to me each time I charge the battery. I can also get it at anytime with a quick push of a button.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 03-30-2014, 11:33 PM   #722
hydrakermit's Avatar
Default VXX Speed Controller
Hi all,
Sorry I didn't really know where to post this, so id thought id post it here.
I've been getting a problem with my speed controller I believe it to be the problem.
What happens is; when I use my transmitter to accelerate, the motor sometimes starts turn and other times it doesn't.
Now I thought it might of been the receiver, so I brought a new one and I'm still getting the problem.
Then I thought it may of been the motor, so I had it apart to check for damage or a build up of crap.
The motor seems fine as well, I even soldered a different older motor with the speedo and it worked at first, then I switched it off and It wouldn't even accelerate.
I've even changed the sensor wire as I though it was that.
Any ideas of what it could be? Or anybody has a similar issue before?
The Speedo controller and motor are both less than 3 months old, and im just getting no drive from my motor.
I'm getting very frustrated so if anyone could help that would be great.
Thanks in advance.
hydrakermit is offline   Reply With Quote
Old 03-31-2014, 01:18 PM   #723
Originally Posted by hydrakermit View Post
Hi all,
Thanks in advance.
I understand that sometimes the motor turns no other. This usually happens when the motor overheats and loose stage of the weld. Open the motor and see if the part of the stator not let some solder.
Pickthall is offline   Reply With Quote
Old 03-31-2014, 01:23 PM   #724
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Hi all,
Thanks in advance.
Have you checked your lipo cuttoff setting in the controller? It sounds like a problem I had and it turned out to be me incorrectly putting in the wrong cutoff voltage. Turn the cutoff protection off and see if it works then...
Racing4Evo is offline   Reply With Quote
Old 03-31-2014, 09:19 PM   #725
Is there a stock firmware where I can get more punch and brakes on blinky mode?
zzztech is offline   Reply With Quote
Old 03-31-2014, 09:32 PM   #726
Jerz616's Avatar
You can update to version 3.3 which has a better brake feel if you already haven't.
Ryan Gracey
XRAY XB8'14
Old 03-31-2014, 10:02 PM   #727
B00t13g's Avatar
Try the new 4.0 software. It's a definite improvement over 3.3. Feels great in my sedan and 12th.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 03-31-2014, 11:55 PM   #728
Odin544's Avatar
Trader Rating: 93 (100%+)
4.0 isn't out yet from my understanding? And it's not legal for blinky class either as it was just sent to ROAR a few weeks ago according to Keith.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 04-01-2014, 12:00 AM   #729
spencehotbodies's Avatar
4.0 is live
Xray T416- Xray X1-Spec-r-Sanwa-Orca-Ame-Arrowmax-Wild turbo fans
West London Race Club
spencehotbodies is offline   Reply With Quote
Old 04-01-2014, 12:15 AM   #730
Odin544's Avatar
Is there a quick over view of how to update everything? I know I need the USB link. Also will it work on a Mac?
TriCitiesRC.com
Old 04-01-2014, 12:35 AM   #731
Jerz616's Avatar
Do you know if we can use 4.0 in Denver Mackie?
Ryan Gracey
XRAY XB8'14
Old 04-01-2014, 07:52 AM   #732
Team EAM
EAMotorsports's Avatar
Trader Rating: 75 (100%+)
Send a message via AIM to EAMotorsports
There is no over view anywhere that I know of. No it will not work on a mac and will not work on a computer with Windows 8 either.
They are working on a new USB for the future that will work with all computers including Mac....but its probably something we may see toward the end of the year.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID | Futaba.
EAMotorsports is offline   Reply With Quote
Old 04-01-2014, 08:14 AM   #733
Can anyone elaborate on the differences between the 3.0, 3.3, and 4.0 firmware versions?
JamesL_71 is offline   Reply With Quote
Old 04-01-2014, 08:21 AM   #734
howardcano's Avatar
Trader Rating: 35 (100%+)
Not sent yet. Hopefully soon!
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 04-01-2014, 08:56 AM   #735
If you go to the orca website it gives you a bit of a break down. What I no about 4.0 it runs the motor cooler with better braking.
