Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 11-22-2013, 02:35 PM   #631
Originally Posted by Madmaxaus View Post
You will find what your looking for here
http://www.orcarc.com/en/supports.asp
Great Thanks for that
Bryan D is offline   Reply With Quote
Old 11-25-2013, 01:56 PM   #632
ropezz's Avatar
Default MALFUNCTIONING
As occured with my previus VX ESC, i am having a strange issue with a new VXX. After minor o more pronounced vibrations, caused by collisions or bumps on track suface, the throttle does not respond. All i need to do is move the sensor cable to operate the ESC again. Consider that i already tried different sensor cables & ribind the ESC with radio. Any ideas of what might be the cause of this issue ? Thanks
ropezz is offline   Reply With Quote
Old 11-25-2013, 03:54 PM   #633
Trader Rating: 57 (100%+)
What motor are you using? I ask because I have always had this same issue with Novak motors and other brand sensors. Switched to a Novak wire and stopped having the issue.
PROMODVETTE is offline   Reply With Quote
Old 11-25-2013, 10:13 PM   #634
Tommy R's Avatar
Trader Rating: 19 (100%+)
Is reverse enabled?
Tommy R is offline   Reply With Quote
Old 11-26-2013, 12:19 PM   #635
ropezz's Avatar
In combination with a Novak and Trinity motor.
Old 11-26-2013, 12:21 PM   #636
ropezz's Avatar
Old 11-26-2013, 12:22 PM   #637
ropezz's Avatar
Originally Posted by Tommy R View Post
Is reverse enabled?
No it isn't.
Old 11-26-2013, 08:57 PM   #638
Have you tried different brand sensor wires? Novak are pretty stiff but the plug is excellent. I usually use TQ on everything, but for some reason with Novak motors they do not work. I even ended up using a zip tie around the endbell of my novak motor to hold it in.
Old 11-27-2013, 01:29 PM   #639
Reese Bobby's Avatar
ropezz, does the throttle not respond while you're out on the track or when you turn on the ESC? Could it be the signal cable to the ESC?
VBC Wildfires
Orca - Revolectrix - Sanwa - SMC
Reese Bobby is offline   Reply With Quote
Old 11-27-2013, 02:08 PM   #640
ropezz's Avatar
Frottle stops responding on track and occasionally when i turn on the ESC at the pits.
Really odd behaviour of ESC, starting to think Orca have a delicate spot, due to the fact this is my second ESC with similar issue.
Fortunate i am getting feedbacks on this forum, no reply on Facebook from Myberg and Orca. Pitty, if this is ORCA' s after sales support, i will switch to another brand.
Old 11-27-2013, 02:16 PM   #641
Odin544's Avatar
Trader Rating: 93 (100%+)
Have you checked all your other electronics as well?
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 11-27-2013, 02:35 PM   #642
Hey ropezz, have a look on the previous page and you will see I had to a similar problem. My VXX ended up dead. If it's within the 60 day warranty period, send it back. I'm still trying to get the address though, so I've had a similar experience.
VBC Wildfires
Old 11-27-2013, 03:26 PM   #643
Team EAM
EAMotorsports's Avatar
Trader Rating: 75 (100%+)
Send a message via AIM to EAMotorsports
Default Warranty/Repairs
Anyone that has a VX or VXX that needs repairs please email aboutrcracing@gmail.com Anthony is the person that will reply and he is in charge of the warranty and repairs of all ORCA products sold through AUTHORIZED dealers in the US. If you bought it outside the US they can not do any repairs on them. All serial numbers are tracked as they come in so they can tell where it came from originally.
If its within the 60 day warranty you will have to provide a copy of the receipt from where you bought it for them to warranty it for you.
Hopefully this will help the few guys having issues.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 11-28-2013, 02:01 PM   #644
ropezz's Avatar
Problem is that AME in Germany, isn't replying to my mails asking for support.
Apparently i am not the only one who as had similar issues.
Changing sensor cables did not solve problem with my old ESC, ill try again with this new one. Other thing i noticed is that when ESC was bran new, the beep sound emitted when changin parameters was much louder, now it's feebel.
Here in Italy ORCA isn't popular, actually im the only one still using there ESC.
Hope my english isn't too bad
Old 12-19-2013, 05:02 PM   #645
I'm using the vritra vxx with a BLS451 and 4PL. When I bring the steering servo back to neutral, the throttle glitches on me. It only does it when returning to neutral. I've been told that my BEC is shot. Any suggestions?
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
