Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 09-13-2013, 04:18 AM   #571
rangerjkb's Avatar
Trader Rating: 36 (100%+)
Send a message via MSN to rangerjkb
Great VX update with the Ver 3.3 software! Fantastic overall performance, resulting in improved brakes and slightly cooler motor temps. Appreciate the support with this superb product!!!
Jason Burks
Murfdogg Products~Psycho Cells Racing~Hal's Hobby Warehouse~Avid RC~Kal-Gard~VP Powermaster
rangerjkb is offline   Reply With Quote
Old 09-13-2013, 10:51 AM   #572
Originally Posted by Keith Yu View Post
Your setup might also work on a smaller track. You can try set both the timing interval and turbo interval to +1~+2 and then lower the turbo down to 56*
Will that giv a bit more bottom end? Maybe also change fdr to 6.6
Gerrie is offline   Reply With Quote
Old 09-13-2013, 05:29 PM   #573
stikman's Avatar
Originally Posted by Gerrie View Post
Thanks Keith
I had my settings on
Boost-36
Timing start - 10
Timing interval -3
Turbo timing - 58
Turbo interval -2
PWM- 8
FDR 6.27 with D3.5 , came of at 83deg C
This was with 2 long straights being +/- 45m - 55m
I will try your settings on the shorter track which will give me more bottom end if I'm not mistaken
also double check the timing on the motor. some motor have a build in timing at 0. the overall timing on the motor should be between 5 and 10 deg.
otherwise it will over heat very quickly and less bottom end power
stikman is offline   Reply With Quote
Old 09-13-2013, 09:18 PM   #574
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Can anyone recommend a setup for LRP 4.5 on low-med asphalt small track?
I was planning on running blinky with the punch at 4...
Racing4Evo is offline   Reply With Quote
Old 09-13-2013, 09:39 PM   #575
The d3.5 has built in timing of 30deg. I had the motor on 10 which totals 40deg. I normally come off at 65-70 degC.
Old 09-14-2013, 02:15 AM   #576
where did you get the update for the vx esc?
cheers
ARC R10/2015 - HOBBYWING - PROAMPS - ORCA
BRCCC
elche_83 is offline   Reply With Quote
Old 09-14-2013, 04:22 AM   #577
rangerjkb's Avatar
EAMotorsports provided Ver 3.3 update, works fantastic. Sent you a "pm".
Jason Burks
Old 09-15-2013, 11:53 AM   #578
MR.Clone (arip)'s Avatar
where can i get this software vx 3.3 version?
MR.Clone (arip) is offline   Reply With Quote
Old 09-15-2013, 09:45 PM   #579
Trader Rating: 15 (100%+)
Send a message via AIM to DJGonzo69
Really odd today in the Mains with my VX ESC. On the 5th lap my ESC all off a sudden lost top end. It was on a slow crawl on full throttle. I turned off the ESC & turned it back on & it was back to normal. Any ideas?
thx-John
|XRAY|RCAmerica|Hobbywing|KO PROPO|Team Scream Motors|Gonzo PaintWorX|
DJGonzo69 is offline   Reply With Quote
Old 09-16-2013, 08:58 AM   #580
Team EAM
EAMotorsports's Avatar
Trader Rating: 78 (100%+)
Send a message via AIM to EAMotorsports
John (DJG)
I have not heard of any of that happening with the speedo's. Ive been running them for a year and not had any issues. Ive had a couple people hit a wall really hard (Like end of the straight away head on) and the speedo quit all together but thats about it.
Did it work fine after you cut it off and back on?
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 09-16-2013, 08:59 AM   #581
Team EAM
ORCA spec motors are in stock for all those waiting.
EA
Contact Us
Old 09-16-2013, 12:11 PM   #582
EA
Are they roar approved yet?
Old 09-16-2013, 12:26 PM   #583
Team EAM
Waiting on them to finish that up.
EA
Contact Us
Old 09-16-2013, 09:24 PM   #584
Eric- yeah after I shut it off & turned it back on it was fine.
Old 09-19-2013, 03:23 AM   #585
Penz316's Avatar
One of my ORCA casing had cracked. I was wondering if it's possible to buy top and bottom casing for a little repair ?
Alex Fournier
Team Associated | Reedy | Team Scream Racing | Hyper Hobbies
Penz316 is offline   Reply With Quote
