Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 09-10-2013, 06:59 PM   #556
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
OVA is offline   Reply With Quote
Old 09-10-2013, 07:02 PM   #557
Jerz616's Avatar
Trader Rating: 49 (100%+)
Originally Posted by 2Quick View Post
Hi. Can you help me with a good setup for 17.5 boosted with a D3 motor on a 50meter straight
Wow that's a long straight fit a 17.5. I tried boosting my 17.5 one day to run with the mod guys at our track when the 17.5 class didn't make. Our track is smaller then yours at 96' X 40'. I ran a 3.88 fdr with 50* timing on the motor. I ran no timing in the ESC but used 30* turbo. It had great pull down the straight. Obviously not as fast as a mod but I was only .5 off the pace. After 6 min I came off at 130*. With you bigger track you might try these and play with gearing to get what you need.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 09-11-2013, 10:58 AM   #558
Hi guys.
What do they mean by " turbo timing" never bigger than "timing"
Also, has anybody got a good setup for 17.5 boosted with a d3.5 or KillShot rpm. The straight is about 30m and some technical sections.
Gerrie is offline   Reply With Quote
Old 09-11-2013, 12:02 PM   #559
Jerz616's Avatar
Originally Posted by Gerrie View Post
Hi guys.
Turbo is just as it sounds. Gives you that extra rpm. Just like in a 1:1 car. I posted a setup a couple post above on what I used one time. You might try it and see. I saw your post in the killshot thread and you run a 6.63 fdr. The setup I used was with an 3.88 on a 96x40 track. Maybe Keith will chik in with something soon. Nobody runs much 17.5 boosted around here any more.
Ryan Gracey
XRAY XB8'14
Old 09-11-2013, 12:41 PM   #560
I will give that a try. I will post the settings I used this past weekend
Old 09-11-2013, 05:37 PM   #561
Trader Rating: 23 (100%+)
Is the vxx going to be released in orange?
bmcallister is offline   Reply With Quote
Old 09-11-2013, 10:16 PM   #562
Team EAM
EAMotorsports's Avatar
Trader Rating: 76 (100%+)
Send a message via AIM to EAMotorsports
I've had them on my site for three weeks in all colors.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 09-12-2013, 06:48 AM   #563
Hi guys.
Here is the 17.5 boosted setup. We usually use same setup for 13.5 and 17.5 boosted. But this setup is for the Orca RX2 motor.
This is a more aggressive race setup
17.5 RX2 motor timing 2.5 lines on the motor. FDR 6.5
Timing start: 5~10%
Timing 33*
Timing interval.0
Turbo timing 56
Turbo interval +2
PWM 8K(Ver3.0)
I will suggest you try out this setup frist before you jump in to the aggressive setup.
Timing start 5~10
Timing 27
Delay 0.1s
Turbo 44
Turbo inter. 2
PWM 8K
D.B. 1%
B.F. 1K
Initial B. Off
FDR 6.3
Motor ORCA 17.5 RX2 with 1330 rotor 4.5bars timing on Motor came off after 5mins 150f*
Keith Yu
Team ORCA/Team Pro-Spec/Team EAM/Team Yokomo
rcproshop@hotmail.com
Keith Yu is offline   Reply With Quote
Old 09-12-2013, 07:15 AM   #564
For those who have updated there program box to v3.3 does it work with v3.0
I have the Vxx and Vx units being that the v3.3 update firmware is not out I need to Know before updating my program box to v3.3 if it work on the v3.0 speedies
**Ausrab Industries**Destiny RX-10s**Futaba**LRP**GRP**SpeedyRC
Madmaxaus is offline   Reply With Quote
Old 09-12-2013, 08:07 AM   #565
Team EAM
NO. It will not work with different versions. You will either have to up grade your VX to 3.3 software, buy a 2nd program box or update software on the program box each time you switch between speedo's (not an easy task obviously).
EA
Contact Us
Old 09-12-2013, 12:57 PM   #566
Timing start: 5~10%
Timing 33*
Timing interval.0
Turbo timing 56
Turbo interval +2
PWM 8K(Ver3.0)
Timing start 5~10
Timing 27
Delay 0.1s
Turbo 44
Turbo inter. 2
PWM 8K
D.B. 1%
B.F. 1K
Initial B. Off
FDR 6.3
Thanx Keith. Much appreciated
2Quick is offline   Reply With Quote
Old 09-12-2013, 04:13 PM   #567
EA
Thanks as I thought, updating to the 3.3 would be the easiest option but its not readily available as of yet.
Old 09-12-2013, 06:59 PM   #568
Team EAM
Send me an email. Teameam@me.com
EA
Contact Us
Old 09-12-2013, 10:33 PM   #569
Thanks Keith
I had my settings on
Boost-36
Timing start - 10
Timing interval -3
Turbo timing - 58
Turbo interval -2
PWM- 8
FDR 6.27 with D3.5 , came of at 83deg C
This was with 2 long straights being +/- 45m - 55m
I will try your settings on the shorter track which will give me more bottom end if I'm not mistaken
Old 09-12-2013, 10:55 PM   #570
Thanks Keith
Boost-36
Timing start - 10
Timing interval -3
Turbo timing - 58
Turbo interval -2
PWM- 8
Your setup might also work on a smaller track. You can try set both the timing interval and turbo interval to +1~+2 and then lower the turbo down to 56*
Keith Yu
