Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 09-09-2013, 04:09 PM   #541
Originally Posted by OVA View Post
Hey keith Yu
I drove devin car and I really like his esc setting.. really smooth and easy to drive..
Can you give me an ideal what and how set my VX esc..my motor is 6.5 not 4.5 motor..Thanks
PS I think devin also said something about cutting down the motor power..
Franko,
This is the setup for 6.5 Mod.
Orca TX 6.5T motor, timing at 10* FDR at 6.8
ESC setup: (STOCK MODE) Ver3.0/Ver.3.3
Timing Start: 25%
Timing:22*
Timing interval:0
Turbo Timing:32
Turbo interval:-1
Turbo Delay:0.02
Punch:4~5
D.B.:4%
B.F.: 1K
Initial B.: off
PWM: 8K(Ver.3.0) 4K(Ver.3.3)
Hope this help
Keith Yu
Team ORCA/About RC Racing/Team Pro-Spec/CTRL Systems/
APS Racing/RCMISSION/Teamorca.shop/
[email protected]
Keith Yu is offline   Reply With Quote
Old 09-09-2013, 05:11 PM   #542
OVA
OVA's Avatar
Trader Rating: 77 (100%+)
Originally Posted by Keith Yu View Post
Franko,
Timing Start: 25%
Timing:22*
Timing interval:0
Turbo Timing:32
Turbo interval:-1
Turbo Delay:0.02
Punch:4~5
D.B.:4%
B.F.: 1K
Initial B.: off
Hope this help
Thanks Keith
Right now..I'm running Orca VX with stock 17.5 in my BD7
I did some test and tune last weekend sunday .I didn't like the feel of the throttler..it kinda hit and missed on power..or flat like no response around the corner...
Mike Malkinson and I try to figureout the problem.. so far nothing...
may have to try again hopefully the esc is okay...
OVA is offline   Reply With Quote
Old 09-09-2013, 05:21 PM   #543
hanulec's Avatar
Trader Rating: 27 (100%+)
Thanks Keith
what are your settings?? i don't have any such problems w/ blinky stock/super stock and the ORCA
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 09-09-2013, 05:23 PM   #544
Thanks Keith
If you are running 17.5 Blinky try setup the ESC with 100% throttle on the radio and turn up the thorrle to 120% after.
PWM set at 8K Ver.3.0
Punch start with 8 and add more if needed.
Keith Yu
[email protected]
Old 09-09-2013, 07:01 PM   #545
alcyon's Avatar
Could some one forward me the V3.3 Software for my VX ESC? My local distributor isn't helpful in releasing this software at this time. My email is [email protected].
Thanks a bunch !
http://kawada-alcyon.blogspot.com/
http://superturbooptimamidspecialzx-5.blogspot.com/
kawada sv10 alcyon 3-sanwa mx3x-orca vx v4.1 software-team powers 13.5 motor-turnigy 4200 shorty lipo-savox 1251 servo RIDE RE32
alcyon is offline   Reply With Quote
Old 09-09-2013, 07:10 PM   #546
OVA
OVA's Avatar
Thank you for your help Hanulec
Keith I didn't up the throttler atferward..try the later..
yes the pwm set at 8K ver 3.0
we did set the punch at 8 at frist than 10 ,no luck..
another things also.after 3 minutes mark ,it seem to felt like, it lossing the punch power and somtime like the thremo shut down on full throttler around the apex..
Old 09-09-2013, 07:28 PM   #547
vabroom's Avatar
Hanulec, setups for the ORCA will be a good section in your RacerLog wik.
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 09-09-2013, 07:35 PM   #548
hanulec's Avatar
if there is a fade 1/2 through, i'd recommend checking your motor or batteries. overheat could also be signs of a different problem. check your belts (who uses those? j/k) and axle bearings.
good idea. my buddy eric lee posted my mod tc settings from this summer. i can download / review my tc stock setting and post them. they are pretty simple. punch at 10 .....
Old 09-09-2013, 07:39 PM   #549
OVA
OVA's Avatar
Hey Mike
No binding or tight on the belts..axles bearing is checked before the test and tune...switching over to 700L this week..what Belt? lol
Old 09-09-2013, 07:44 PM   #550
hanulec's Avatar
Hey Mike
smart man -- but i'm a bit biased
make sure you got a motor fan blowing strong. this is even more important on the awesomatix longitudinal motor design as the motor doesn't get much air contact.
i don't run a speedo fan in 13.5 or 17.5. i do run either the stock fan, or the WTF 25mm fan for modified.
setups 'will' go here, but there are none yet. once i'm done freshing my car for carpet i'll download my stock setups. http://racerlog.com/wiki/ORCA_ESC_Setups
Old 09-09-2013, 08:06 PM   #551
hanulec's Avatar
i just added everything i know about boosted / modified setups with the ORCA VX speedos. i've included some useful info from Ian Hardman -- it was very useful to help me figure out what was wrong/right with my setup(s). also, making 'binary' changes -- maxing a value and then minimizing a value helped me understand what many of these changes did.
stock settings later in the week.
Old 09-09-2013, 10:05 PM   #552
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
How have the TX motors been handling in 12th scale blinky? looking to upgrade my 12th scale for WCICS this year and shopping for a motor. ill be running a VX1 esc in this car. for 17.5 boost, i was running a high rpm rotor in a reedy, is something similar available, or desireable for blinky?
My stuff
| Team Associated - Reedy - Reflex Racing/RSD - ProAMPS RC |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/ - www.teamassociated.com
valk is offline   Reply With Quote
Old 09-10-2013, 02:12 AM   #553
Hi. Can you help me with a good setup for 17.5 boosted with a D3 motor on a 50meter straight
2Quick is offline   Reply With Quote
Old 09-10-2013, 05:47 PM   #554
hanulec's Avatar
probably not.... we don't run 'stock' boosted around here. i'd really recommend you play around, and learn the speedo settings yourself.
have you tried Andrew's mod setup?
Old 09-10-2013, 05:54 PM   #555
flameoutgarrett's Avatar
Send a message via MSN to flameoutgarrett
Luckily Keith has lots of Experience with 17.5 boosted, all last year one of the local clubs ran it, the straight wasn't 50meters but I'm sure u will get in the ballpark, I have my setup written down somewhere might take me a little but to find it tho.
Team fun-Www.rc-trim.com-Team Speedmerchant-Team Orca-Team Br00d
flameoutgarrett is offline   Reply With Quote
