Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 08-10-2013, 12:09 AM   #466
flameoutgarrett's Avatar
Send a message via MSN to flameoutgarrett
You can change your neutral range and up your punch, or even make a more aggressive throttle curve
Team fun-Www.rc-trim.com-Team Speedmerchant-Team Orca-Team Br00d
flameoutgarrett is offline   Reply With Quote
Old 08-10-2013, 12:57 AM   #467
Originally Posted by Racing4Evo View Post
Can i do anything to lessen the dead band? I feel that the even the lowest setting for neutral range is really making it hard for me to drive. It is better than the orion r10 but still not as good as the flow to me. I know that this somewhat translates into a "smoother throttle feel" but I myself prefer more sensitive and instant throttle response, even in mod.
What is your ESC and motor setting?
Keith Yu
Team ORCA/Team Pro-Spec/Team EAM/Team Yokomo
rcproshop@hotmail.com
Keith Yu is offline   Reply With Quote
Old 08-15-2013, 07:59 PM   #468
A Ilievski's Avatar
Trader Rating: 39 (100%+)
Silly question,
I recently got the Vitra Comp, can someone point me in the right direction with the recent software to download off the Orca website. Its rather confusing :/.
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIGE BEARINGS*
A Ilievski is offline   Reply With Quote
Old 08-16-2013, 02:38 AM   #469
Originally Posted by kid TT-01 View Post
Silly question,
As for now, the Ver.3.0 is the one you need. But the Ver3.3 software will be out very soon
Keith Yu
Old 08-16-2013, 08:33 AM   #470
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
Hey keith, for a track the size of irocc, what would be ideal starting settings for this esc with a tx17.5? Does the motor prefer low fdr or more static timing? Your car was very fast when i saw back in may.
My stuff
Sanwa M12 - Xray T4/16 - Xray Nt1/16 - CRC XTI-WC - ProAMPS - Hobbywing - ReVTECH - ORCA
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com
valk is offline   Reply With Quote
Old 08-16-2013, 04:27 PM   #471
Bigz84's Avatar
Trader Rating: 15 (100%+)
what kind of changes are we looking at w/ this new software?
Radiopost : EA Motorsports : Orca : Reflex Racing/RSD : Wild Turbo Fans : Franchise Racing Products : RCAmerica : Hudy : Xray : Diggity Designs:
Bigz84 is offline   Reply With Quote
Old 08-16-2013, 07:48 PM   #472
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
blinky or boosted
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 08-16-2013, 08:49 PM   #473
valk's Avatar
17.5 blinky 2s. also curious if the settings would be different for VX1 single cell and 13.5 12th scale.
If i like this 17.5 that will probably be a TX as well.
My stuff
My RC
Old 08-16-2013, 09:22 PM   #474
For IROCC track I usually gear at 3.88 with the RX2 17.5 motor. With the TX I will start it at 4.0~4.2 with high timing.(about 4mm pass the 20*)
ESC setup Ver.3.0
PWM 8K
Punch8~10
If you are using the M12 radio then set the Punch to 7 and then go to the racing mode on the radio to adjust the throttle curve.
Keith Yu
Old 08-16-2013, 09:49 PM   #475
The new Ver.3.3 had two different Blinky mode ( mod and spec mode) both offer different throttle response.Brakes are much stronger and more controllable. Also Motor and ESC runs cooler it allowing us to use lower PWM setting. With the Ver3.0 we usually set it at 8K but with the Ver3.3 we can set the PWM to 4K with Full Mod 4.5T motor.
Keith Yu
Old 08-16-2013, 09:51 PM   #476
Yes! You can use same setting
Keith Yu
Old 08-16-2013, 10:00 PM   #477
valk's Avatar
Thanks Keith!
I run all linear settings on my m12 so do you adjust it positive or negative curve? and why in racing mode? i almost never go in there ha. *noob*
My stuff
My RC
Old 08-16-2013, 10:31 PM   #478
Thanks Keith!
I always set the positive throttle curve when I race spec class.
More detail adjustment can be done with the Racing Mode.
Keith Yu
Old 08-16-2013, 11:43 PM   #479
valk's Avatar
Thats interesting. Ill have to try. I have the throttle expo set to my thumb lever. I run a tiny bit of negative in mod to take some of the edge off. Ill have to try possitive with my bext race day.
Not sure what to expect. The tekin was so flat anywhere but the top. It was an on switch mostly. Especially with boost.
My stuff
My RC
Old 08-18-2013, 12:46 PM   #480
G-rem's Avatar
Hello everyone,
I have to buy a new esc for my 1/10 touring car.
I'd like to know how the new Vritra VXX works with a 10,5t blinky or boosted and with a mod motor (7.5/6.5t) with timing. How the esc deals with heat, smoothness, stability of the software, how easy the speedo is to tune,...
I wanna know everything ;-)
Thanks in advance for your replies,
Best regards,
G-rem
G-rem is offline   Reply With Quote
