Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 07-22-2013, 04:59 AM   #451
MrRolla's Avatar
Trader Rating: 29 (100%+)
Originally Posted by gocoogs View Post
I accidentally plugged battery in wrong and sparked quickly. It didn't stay plugged in, but did spark. After that, the throttle doesn't seem to work on my orca vritra 3.0. It still turns on fine and blinks, but the throttle doesn't seem to work. Any idea what could be wrong? I tried to reprogram limits with radio and that worked fine. I changed the sensor wire an the throttle worked for a few seconds, then shut off again. Any suggestions guys???
I did the exact same thing. with the same results you are having. I just bought another one, probably send mine direct to orca as my local distributor wasnt real interested in sending it back
MrRolla is offline   Reply With Quote
Old 07-22-2013, 05:15 AM   #452
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
send unit straight back to orca and they will replace with new unit for a fee
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 07-22-2013, 07:53 AM   #453
Trader Rating: 24 (100%+)
EA,
I bought the speedo from you...HA.
Should I send directly to orca, or send to you directly?
Let me know address to send it to.
Thanks,
Justin
gocoogs is offline   Reply With Quote
Old 07-22-2013, 08:16 AM   #454
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
EA,
Thanks,
Justin
Hey Justin,
Send me an email to [email protected] and I'll get you the info you need to get it taken care of.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 07-22-2013, 08:31 AM   #455
Originally Posted by hanulec View Post
Esc/speedo fan - no
Motor fan - yes!!!
Did just that! Thank you for the reply.
quasimodo is offline   Reply With Quote
Old 07-22-2013, 12:04 PM   #456
Does this speedo have a blinky
mode
ronallen is offline   Reply With Quote
Old 07-22-2013, 12:28 PM   #457
Team EAM
mode
Yes and it is complete ROAR Legal as well.
EA
Contact Us
Old 07-22-2013, 12:56 PM   #458
Ok thanks.
Old 07-27-2013, 05:04 PM   #459
Mugen10's Avatar
Send a message via Yahoo to Mugen10 Send a message via Skype™ to Mugen10
Problem with my ORCA VRITRA COMPETITION
The last time I raced my car stopped cold with no throttle. I came off drivers stand and checked esc temp. 135F and motor temp 150F (5.0 mod)
After I went thru the setup with the Orca card. I noticed I cannot send the data to esc.
It reads "unUpdata"
What is this and did I change something to cause this? Is this a problem with the esc or the card? I have a new esc and card with the 3.0 software.
I emailed the company and waiting for reply.
Thanks for any info.
Central Kentucky Racing
Xray T4
Mugen10 is offline   Reply With Quote
Old 07-28-2013, 07:53 PM   #460
Mugen10's Avatar
It reads "unUpdata"
Has anyone came across this same issue?
Xray T4
Old 07-28-2013, 08:34 PM   #461
Jerz616's Avatar
Trader Rating: 49 (100%+)
Did you change any settings before you got that message. Mine does that if I go through the different settings but dont change anything and then try to send it to the esc. It's almost like its saying unchanged data. I think you need to select exit if you don't change any settings. I'm sure EA or someone will chime in at some point. Does your speedo work otherwise?
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 07-28-2013, 08:48 PM   #462
Mugen10's Avatar
OK i will try that. EA told me the same thing.
Xray T4
Old 07-30-2013, 11:41 PM   #463
hi there
i like this esc. i run it in mod class in my 2wd buggy with a 7.5 and 8.5 motor.
i ordered a speed passion reventon pro r for my sc 2wd and truck 2wd.
the orcae is much better for me. it has a better feel ( brake, throttle) and the programms are better for my class.
so i ordered a 2 orca´s again for my other cars.
a real good speedo. i like it.
mihaelbencek is offline   Reply With Quote
Old 08-06-2013, 07:32 AM   #464
Trader Rating: 30 (100%+)
Hey guys,
What sort of timing, boost, turbo is best to run with a 8.5t motor.
Thanks.
RyanGreenie is offline   Reply With Quote
Old 08-09-2013, 11:04 PM   #465
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Can i do anything to lessen the dead band? I feel that the even the lowest setting for neutral range is really making it hard for me to drive. It is better than the orion r10 but still not as good as the flow to me. I know that this somewhat translates into a "smoother throttle feel" but I myself prefer more sensitive and instant throttle response, even in mod.
Racing4Evo is offline   Reply With Quote
