Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 07-14-2013, 01:39 AM   #436
Whats the difference between Stock Mode and Modify Mode? They both have the same setting options.
Realtek is offline   Reply With Quote
Old 07-14-2013, 08:48 AM   #437
Bigz84's Avatar
Trader Rating: 15 (100%+)
yes, but the settings w/I the those 2 options are different.
setting #2, timing
for Mod, you can go from (off to 20)
for stock you can go from (off to 40)
turbo timing is also different between the 2
blinky is blinky, it doesn't matter which mode your in.
Radiopost : EA Motorsports : Orca : Reflex Racing/RSD : Wild Turbo Fans : Franchise Racing Products : RCAmerica : Hudy : Xray : Diggity Designs:
Bigz84 is offline   Reply With Quote
Old 07-15-2013, 03:07 AM   #438
Trader Rating: 9 (80%+)
Dan-Dan Team-X is offline   Reply With Quote
Old 07-15-2013, 04:19 AM   #439
Default programe card
Just tried to download Program card ver.3 1209220 to my card, when I connect to my esc the card flashes Orca program card then goes blank. The card remains alight but no information. Has anybody got any idea what my be wrong. Thanks for any help
67fastbk is offline   Reply With Quote
Old 07-15-2013, 06:44 PM   #440
B00t13g's Avatar
Can the switch be removed and left off?
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 07-15-2013, 06:52 PM   #441
stikman's Avatar
did you update the ESC to V3 to match the program card? you have to do both.
stikman is offline   Reply With Quote
Old 07-16-2013, 06:18 AM   #442
Default program card
Hi Stikman. Yea match both downloads esc to card and still didn't work. For some unknown reason it didn't match even though they were both the some. Lucky for me a mate had it on his laptop and the program card updated. problem solved.
Old 07-17-2013, 12:42 PM   #443
Trader Rating: 22 (100%+)
Default 17.5 stock settings
I recently bought two of these new speed controls and plan to use them this weekend in 17.5 blinky class on an indoor carpet track. Are there any recommended settings to try? Team Powers Plutonium 17.5 Motor, xray t4
thanks so much
gocoogs is offline   Reply With Quote
Old 07-17-2013, 06:38 PM   #444
hanulec's Avatar
Trader Rating: 23 (100%+)
thanks so much
good choice...
ppm/drive freq - 4k
brake freq - 1k
punch - 10
i don't run drag brake or any other active brake settings.
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 07-17-2013, 06:53 PM   #445
Hi Guys Trying Unload This ESC $120 Shipped And Its Yours ORCA Vritra VX Titanium Colour Immaculate With Boxs Manuals Everything Version With Posts
Old 07-20-2013, 05:58 PM   #446
Default Prob with speedo
I accidentally plugged battery in wrong and sparked quickly. It didn't stay plugged in, but did spark. After that, the throttle doesn't seem to work on my orca vritra 3.0. It still turns on fine and blinks, but the throttle doesn't seem to work. Any idea what could be wrong? I tried to reprogram limits with radio and that worked fine. I changed the sensor wire an the throttle worked for a few seconds, then shut off again. Any suggestions guys???
Old 07-22-2013, 01:52 AM   #447
Hi!
New to blinky racing and have not yet put the gear on the track for the first time. Do I need the cooling fan at all? Will be racing 17.5 Tc with a D3.5 motor.
All the gear are new to me and the class so that is why I am wondering.
Alex
quasimodo is offline   Reply With Quote
Old 07-22-2013, 04:24 AM   #448
B00t13g's Avatar
Originally Posted by quasimodo View Post
Hi!
Alex
You shouldn't.
Mackenzie Meyercord
Old 07-22-2013, 04:50 AM   #449
hanulec's Avatar
Hi!
Alex
Esc/speedo fan - no
Motor fan - yes!!!
Old 07-22-2013, 05:41 AM   #450
Team EAM
EAMotorsports's Avatar
Trader Rating: 75 (100%+)
Send a message via AIM to EAMotorsports
You'll have to contact the place you bought it from to send it back in for repair. It probably popped the fets. Thats pretty standard for plugging any speedo in backwards though.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
