Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 06-29-2013, 10:47 PM   #406
hanulec's Avatar
Trader Rating: 23 (100%+)
Thx Eric. I have to thank Haynes for showing me you can be slow in mod but go fast
Originally Posted by Ron Goetter View Post
He's gone soft in his old age. What ever happened to the oh no not again days?
Oh yeah... Thankfully that hasn't been a issue. My Awesomatix cars keep on getting better. Might be ready for a 5.5 now (from 6.5).
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 06-30-2013, 11:43 AM   #407
I've been testing the esc and 4.5 TX motor.
I've had al day long problems with the temp of the motor.
After 3 minutes 80C.
This were the last settings that i tried, and the temp was after 5 minutes 85C
Timinig start 35%
timing 7
timing interval +2
delay 0.03
turbo 28
interval +3
drag brake 9
punch 4
FDR was 7.7 with 8, the temp was higher.
What could i change to reach lower temps?
With my lrp flow and X20 motor, it only gets 60C and had a little more power.
DW Hobbyshop
Serpent, VBC racing, muchmore racing, skyrc, nosram,...
Driving a ERYX3.0
stofke is offline   Reply With Quote
Old 06-30-2013, 04:02 PM   #408
Team EAM
EAMotorsports's Avatar
Trader Rating: 76 (100%+)
Send a message via AIM to EAMotorsports
Timinig start 35%
timing 7
timing interval +2
delay 0.03
turbo 28
interval +3
drag brake 9
punch 4
No one in the US has gotten a chance to run the ORCA TX motors yet. So it will be hard for anyone here to give you any help with them.
I will have the ORCA TX motors in stock this week though and then some of the US Drives can provide more feedback for setups and such.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 07-01-2013, 12:36 AM   #409
B00t13g's Avatar
Timinig start 35%
timing 7
timing interval +2
delay 0.03
turbo 28
interval +3
drag brake 9
punch 4
Ill be running my tx 4.5 tomorrow, but I'm starting with an 8.7 fdr.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 07-02-2013, 08:39 AM   #410
I guess this has been brought up before.
USB link software problems. Have installed the software and when I open the program it says Insert USB link and I do. Tried it with it already in the USB port and with the esc connected and without.
When installing the drivers it says in can not copy the INF file.
What to do? Just bought the damn thing so I could install V3. I have a W8 pc so does this matter? I am no computer genius per say.
Help would be much appreciated.
Alex
quasimodo is offline   Reply With Quote
Old 07-02-2013, 11:34 AM   #411
Timinig start 35%
timing 7
timing interval +2
delay 0.03
turbo 28
interval +3
drag brake 9
punch 4
My guess is reduce the timing and turbo interval to +1, but with that ratio you should be running on a big straight track?
Check also the timing on the motor, that should be on zero seting.
How is your pwm setting for Th and BK?
Team AME/ORCA
https://www.facebook.com/strawberryrcdesigns
http://www.strawberryrcdesigns.pt/
jorgesimes is offline   Reply With Quote
Old 07-02-2013, 01:28 PM   #412
i talked to Harper and Hagberg on facebook, and for medium tracks they say FDR 7.6 and on big tracks 7.4.
pwm is 32
brake freq 2k
Also tehy said to use a big fan on the motor.
DW Hobbyshop
Driving a ERYX3.0
Old 07-02-2013, 07:29 PM   #413
Mugen10's Avatar
Send a message via Yahoo to Mugen10 Send a message via Skype™ to Mugen10
pwm is 32
brake freq 2k
I guess this is a 4.5 motor? I wonder how different a 5.0 motor setting is? I am going to try 7.74 on a I guess Med/large track (175ft straight)
Central Kentucky Racing
Xray T4
Mugen10 is offline   Reply With Quote
Old 07-03-2013, 03:00 AM   #414
pwm is 32
brake freq 2k
A fan is a must have. What is for you a big track?
Team AME/ORCA
Old 07-03-2013, 08:53 AM   #415
If the track has a straight line of +50 meters. That is already a big track.
DW Hobbyshop
Driving a ERYX3.0
Old 07-03-2013, 09:44 AM   #416
Now we can compare, for you to have an idea, at the euros warmup race on a track with a 55 mts straight (Big Track on your definition) Hagberg used 7.88, as you can see you have diferent notions of big track.
See here the setup: http://forum.teamxray.com/xform/inde...D=403&setup=t4
See the track here: http://cardoso-modelismo.com/euro2013/track.html
Another exercise you must do is ask them the firmware version and compare to the one you got, because you may be surprised.
In the end if you want try my advices and maybe on a medium track 8.1 - 8.3 ratio and a good 30mm fan should do the work great.
Team AME/ORCA
Old 07-03-2013, 11:26 AM   #417
Is there a motor limit for the speedo?
I have a 3.5t in my box I'd like to use sometime.
cyclonetog is offline   Reply With Quote
Old 07-03-2013, 03:32 PM   #418
Bigz84's Avatar
Trader Rating: 15 (100%+)
4.5 is the limit. it is written on the manual of the speedo.
Radiopost : EA Motorsports : Orca : Reflex Racing/RSD : Wild Turbo Fans : Franchise Racing Products : RCAmerica : Hudy : Xray : Diggity Designs:
Bigz84 is offline   Reply With Quote
Old 07-03-2013, 03:42 PM   #419
Ok thanks
Old 07-04-2013, 01:23 AM   #420
B00t13g's Avatar
I'm very pleased with my TX 4.5 after running it for a few days.
Mackenzie Meyercord
