Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 11-07-2012, 10:37 PM   #181
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
Originally Posted by onekiwi View Post
if needed where could the usb link be purchased?
http://shop.team-ame.com/product_inf...roducts_id=169
from here
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 11-09-2012, 03:32 AM   #182
Hi all,
Does anybody have a setup for a 10.5 thunder power motor?
Boosted and/or blinky?
I'm running the V3 software version.
thanks for the help.
greetings PQ
neys_p is offline   Reply With Quote
Old 11-10-2012, 04:41 PM   #183
Default help needed, not enough brakes...
Blinky 17.5, touring 2S, FDR 4.2
Using orca vx v2.2 (legal), car was fast and ESC was smooth, however, the brakes were not strong enough.
I tired all the different brake frequencies, starting from 500 Hz (strongest, I think) all the way to 2Khz...the brakes always felt lacking.
Have I missed something?
Was previously using Tekin RS pro V2.23. Others have tried the car at the track and agreed.
Any suggestions would be greatly appreciated.
Thanks in advance!
mhavlena is offline   Reply With Quote
Old 11-11-2012, 06:12 PM   #184
NolanP's Avatar
Thanks in advance!
Please list all your brake settings. I don't know how much brake you are looking for but I have tons of brake on my car. BTW are you running the cap that came with the car?
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 11-11-2012, 06:39 PM   #185
Settings were:
V2.2 (ORCA VX)
V2.0 Programmer Card
Punch = 10
Drive Freq = 8K (also tried 4K)
Drag Brake 3% (also tried no drag brake) (to be fast at our track, one must be trained not to use drag brake as there is too much time lost in the twisties)
Initial Brake 2%
Brake Freq 700Hz (tried 500 Hz, 1Khz and 2Khz)
Touring car 2S lipo, 4.2 FDR using 100 tooth spur gear, 17.5 blinky
Not enough brakes, nowhere near the Tekin RS (with active brake engaged, that is)
I hope that I have missed something...
Appreciate any advice!!
Old 11-11-2012, 06:49 PM   #186
NolanP's Avatar
Settings were:
V2.2 (ORCA VX)
Punch = 10
Initial Brake 2%
Are you running the stock capacitor?
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Old 11-11-2012, 06:50 PM   #187
Bigz84's Avatar
Trader Rating: 15 (100%+)
Settings were:
V2.2 (ORCA VX)
Punch = 10
Initial Brake 2%
I was/am fighting the samething today w/ my brakes (tight course). From the Tekin, i set my radio back to 100% EPA. I also set ESC at 500HZ. I am beginning to wonder if i forgot to reset the radio to 100 when i programmed the ESC???? I am going to reprogram the radio/ESC w/ all at 100% to see if that solves the problem. If not, i am going to start going higher in the Initial.
Let me know how you solve your issue, as i am curious.
Radiopost : EA Motorsports : Orca : Reflex Racing/RSD : Wild Turbo Fans : Franchise Racing Products : RCAmerica : Hudy : Xray : Diggity Designs:
Bigz84 is offline   Reply With Quote
Old 11-11-2012, 06:54 PM   #188
oopps sorry, Yes, I am...
Old 11-11-2012, 06:57 PM   #189
NolanP's Avatar
Ok just making sure.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Old 11-11-2012, 06:58 PM   #190
I most definitely had everything on my radio set to 100% when binding the ESC to my radio..., I also incrased brake and throttle EPA afterwards to see if there was any effect, no effect...
Also, when trying the different brake frequency options, the brakes always felt the same...that is lacking...
Old 11-11-2012, 07:02 PM   #191
Let me know if the initial brake setting makes any difference.
Thanks!!
Old 11-11-2012, 11:36 PM   #192
onekiwi's Avatar
Im going to try this in a 2wd mod buggy Do I need to upgrade it to V3 software version?
Any suggestions for settings?
IS this esc not run that much in offroad? There is no thread in that section
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 11-12-2012, 01:53 AM   #193
With this new V3 software, is there any difference for modified TC? Looks like you have to upgrade a few items to get it up and running and programmable so is it worth it?
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 11-13-2012, 06:34 PM   #194
Default ROAR approved ESC list
It would seem that the ROAR approved ESC list has been updated.
They have added the new Vx-1 ESc, but both the list only allows V2 firmware??
Shouldn't this have said V3?
Now my V2.2 is no longer allowed at my track....I hope they will change this soon..
Old 11-13-2012, 06:35 PM   #195
Settings were:
V2.2 (ORCA VX)
Punch = 10
Initial Brake 2%
Any ideas?
