Motor?
#16
If you have enough low end punch, throw some timing on it.
Watch ESC temps & motor temps too.
Even sensorless, the castle has reactive timing.
wen you adjust timing it is giving the ESC a sugested range to work in.
4pole motors are more sensitive to timing adjustments, so go little steps at a time.
I will look into it. need to find my programming card and reinstall castle link on my computer.
#17
Still cant find my programming card. But I found the squeaking noise was my gear mesh was a bit tight. I loosened it a bit and brought it out for a gps test with a freshly charged 2s and got to 40.5mph. So with better gearing and a 3s, it will be crazy.
