Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 02-17-2005, 02:44 PM   #61
17driver's Avatar
R/C Tech Charter Subscriber
Thanks for the info pitstop now I just have to wait for it to come out for the 3PK.
Midwest malitia member Got NI-MH?
17driver is offline   Reply With Quote
Old 02-17-2005, 02:49 PM   #62
PitCrew's Avatar
Thanks Ritchie,
That'll be $5....
By the way, before the capacitor was on there, I tried both my 4735, and 4750....They both did the same exact thing you described. Have the 4735 in the car now with the cap and it works great. I think the steering is faster now than before.
Acctually, thats a good idea. I should sell the cap's, wired up for use. That way I could make a few $$ off my discovery...
PitCrew is offline   Reply With Quote
Old 02-17-2005, 02:56 PM   #63
Greg Sharpe's Avatar
There is a much more interesting article in the latest issue of R/C Driver (IIRC) which address the response time issue. The story goes that early on in the design they used one method of frequency control that had poor repsonse time. After which, they began using a faster method which has much faster response time than that of current transmitters (as quoted prior about the M8). I'd be guessing that the team drivers had early units that were slow????
www.jacksonRCracing.com <---schedule, announcements, euro style curbs, naked ladies
SJCCR - Brownie's - Horsham - Blue Diamond
You meet the nicest people as you hit them in a Mini! -Tom Slick
Greg Sharpe is offline   Reply With Quote
Old 02-17-2005, 03:08 PM   #64
PitCrew's Avatar
Thats possible.
It could also be a manifestation of the voltage depression by the extra load of the receiver on the BEC. Less voltage to servo=slower servo.
Old 02-17-2005, 04:07 PM   #65
N4S
N4S's Avatar
I just can't believe all the boasting they did about the extensive testing . I dont believe i have ever been more disapointed in a product or a company for the way they have handled this. Just curious to see if the second one ( if it ever gets here ) will work or not.
N4S is offline   Reply With Quote
Old 02-17-2005, 04:10 PM   #66
N4S
N4S's Avatar
Good work though guys . Its great to see that the average racer can fix a problem that a multi million dollar company obviously can't.
Old 02-17-2005, 04:15 PM   #67
PitCrew's Avatar
Thanks!!!
but who you calling average...
ritchie.....Back me up here
I really belive the cap trick will solve most of the receiver/servo/speed issues.
No, I'm not a rep for spektrum, just a joe who spends every last buck on RC. well, not quite, but close.
Old 02-17-2005, 04:20 PM   #68
Company Representative
Tres's Avatar
PitCrew is correct, it also helps on A LOT of standard Tx/Rx issues also.
Tre's
Custom Graphics - Race Plates/Wraps & Pit Products
www.tnt-fx.com
Tres is offline   Reply With Quote
Old 02-17-2005, 05:33 PM   #69
rovic's Avatar
actually, airtronics/novak drivers have been using caps for years. and to yet has not been incorporated into the rx (at least to my knowledge). you still see caps being used today...
i say, good job pitcrew...
rovic is offline   Reply With Quote
Old 02-17-2005, 06:00 PM   #70
scoobydo's Avatar
The Cap solution makes sense.
In the recent RCCA article they make mention that while the Transmitter draws less power on your batteries,
the reciever actually draws more power than a normal reciever. Something like Double if I remember correct.
They quickly mention this problem but then cover it right up by saying how much more power your saving on your transmitter.
Correct me if I'm wrong, but I could care less about my transmitters draw! The most important is the recievers draw.
I don't see how they could have missed this in all the "testing" they say they did.
Oh, well. Time will tell.
scoobydo is offline   Reply With Quote
Old 02-17-2005, 06:15 PM   #71
PitCrew's Avatar
They didn't miss it in the testing. They come right out and say it draws more power. The problem lies in speedos that have a low BEC output like the Quatum 2 that I am running. It only puts out 1.6 amps. Just not enough to run the servo motors and keep the receiver locked on.
With the cap on there everything works fine, except the button to "Bind" on the transmitter. Lukily I got it to go once in 500 tries.
Old 02-17-2005, 06:20 PM   #72
brians11's Avatar
Trader Rating: 18 (100%+)
Send a message via AIM to brians11
i'll have to try this... i use a qc2, and it linked up the first time... i'm gonna go find a cap now
Team Associated | Hurricane | SMC | LRP | Parma/PSE
brians11 is offline   Reply With Quote
Old 02-17-2005, 06:41 PM   #73
koabich's Avatar
Send a message via Yahoo to koabich
Would a cap on the ESC itself work? I use the large capaciter from the Worlds kit on my LRP Q2.
koabich is offline   Reply With Quote
Old 02-17-2005, 06:51 PM   #74
TCR
Default Horizon Rep Please
I wish some Horizon rep would please respond to this topic?
thanx
Someone who has this please test it like this.....
using the old rec
run 20 laps
alternate rec to spektrum
run 20 laps
old rec
20 laps
spektrum
20 laps
repeast this until you have 5 or 6 runs with each set up
take all your lap times with each system
drop the 5 fastest and slowest
take the average of each
Is the a difference and what is the difference?????
It would be great to see test results from various people running under different conditions
TCR is offline   Reply With Quote
Old 02-17-2005, 07:27 PM   #75
racer-oZ's Avatar
I used my spektrum last Saturday at an indoor offroad track and it seemed to work fine, but I don't like the idea of wondering if it is working at 100% or not. On carpet I could see where guys could feel a difference because carpet is so precise, in offroad you may not feel it as much because your car is being tossed around anyway through the jumps and bumps, but if it's there it's still got to be hurting you. I too would like to hear Horizon's point of view and what if anything they plan to do about it. Again mine seemed to be working fine and I love this technology, but when you invest so much money into a weekend of racing you also want to know everything is working right.
racer-oZ
racer-oZ is offline   Reply With Quote
Forum Jump
Futaba 3PKS - Lipo Tx Pack - Spektrum Module - Spektrum Micro Pro Reciever - Case racer34v R/C Items: For Sale/Trade 2 06-20-2008 08:42 AM
HUGE SALE TONS TC5, Novak Speak Spektrum GTB 13.5, Spektrum Pro, AMB Transponder + mach51 R/C Items: For Sale/Trade 16 01-08-2008 02:11 PM
Electronics For Sale: M11/Spektrum, Spektrum Micro RX, Futaba Synth etc. johnnyboy R/C Items: For Sale/Trade 3 11-30-2007 07:17 AM
swap ko propo helios radio with spektrum pro for 3pk super with spektrum pro willabong Australia Wanted to Buy 0 04-01-2007 04:39 AM
Spektrum receiver...Spektrum 590 Servo...PCR Temp gun...CRT Roto start... SCUBA STEVE R/C Items: For Sale/Trade 8 08-22-2006 08:18 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
