Problem with a hobbywing/novak ballistic setup
I use a hobbywing 150a, novak ballistic 4.5t, cc bec and hobbywing capisators
Here is my problem in the short version.
From a standstill ther is a lag before it hits full power (0,5sec or so)
If the car is moving it is not that bad.
I have tried evry adjustment there is and can not figure this out
Help plase
Help plase
Help plase
Help plase
One other thing is whether or not your battery can keep up.
It is not cogging, more of a lag in response...
The battery is turnigy nanotech 6000mah 65-130c, and it worked fine with the novak esc that whent up in smoke........
Using the blue 150a xerun esc.
The abc wires are in connected rigth, if i change them arond it gets worse....
And i have a new sensor wire
The esc works just fine with the tenshock 401 5600kv...
I did replace the board also together with the wire...
If i take the sensor wire out it gets mutch wore and coggs....
I have just about tried every adjustment possible....
This is what it works best with
Drag brake 0
Cut off 3.2v
Punch level 5
Brake force 50%
Reverse force 50%
Neutral range 9%
Timing 15
Motor rotation cc
Thanks...
Drag brake 0
Cut off 3.2v
Punch level 5
Brake force 50%
Reverse force 50%
Neutral range 9%
Timing 15
Motor rotation cc
Thanks...
It calibrates correctly, works fine with other motors.
Mecanical timing seems to be best around 15 or so.
Will try and adjust some more and even try another esc from my 1/8 buggy
Thanks...
Thanks...
