Like Tree2Likes
Hobbywing Xerun V3
Old 09-07-2012, 04:50 AM
  #106
Originally Posted by CraigM
Turn BT by TH to "No" will give you the punch you're looking for
What does that option do? will it cause more heat on the motor?
iwkyb is offline
Old 09-16-2012, 09:19 AM
  #107
L.Fairtrace's Avatar
Trader Rating: 24 (100%+)
Is there anyway to get rid of the crazy amount of drag brakes in this thing? I have them set to zero and when i lift off the throttle it doesn't roll like an LRP speedo.
It feels like it has way more drag brakes than it should.
L.Fairtrace is offline
Old 09-16-2012, 09:58 AM
  #108
Airwave's Avatar
This option reproduces the behaviour of the V.2.1, the turbo only switches on when the throttle is 100% and the delay is consumed.
If you turn this option to no, I suppose it will allow the turbo to switch on even the throttle is not at 100%...
Airwave is offline
Old 09-16-2012, 10:33 AM
  #109
Barry_Hughes's Avatar
No it doesn't
"Boost Controlled by Throttle
This setting is a limit for the boost timing addition, in relation to the throttle position, which can aid car stability whilst on throttle. If enabled, the ESC will monitor the throttle position and Motor RPM, and limit the maximum amount of available boost timing.
E.g. If the boost timing is set to 36 points and the boost end RPM setting has been achieved, but the throttle position is only 50%, then only 32 points (50% of 64 points) of boost will be applied. "
turning it off there is no limit to the boost applied at any given throttle position.
check the link software it explains each setting in the bar to the right
Barry_Hughes is offline
Old 09-16-2012, 11:02 AM
  #110
Where to fine v3 in stock? All is sold out...
Zooberg is offline
Old 09-17-2012, 09:38 AM
  #111
Has no one noticed this?
Old 09-17-2012, 09:40 AM
  #112
Matt Howard's Avatar
http://www.falconsekido.com/products...-brushless-esc
They're in stock here
Matt Howard is offline
Old 09-17-2012, 09:42 AM
  #113
I haven't noticed too much drag brake in mine, I have it set to 10% and it feels fine to me but I've never run an LRP to compare it to.
Old 09-17-2012, 09:44 AM
  #114
xrayaustin's Avatar
Trader Rating: 12 (93%+)
larry i notice it. The only thing I can sugguest you do is like youve already done, and put the drag brake to 0 and also put the initial brake brake setting to equal drag brake. i know it sounds weird but its almost as if the brakes engage under neutral throttle if you have any initial brake in the speedo at all. Thats what i run and it works pretty good for me. Still doesnt roll as much as the lrp, but it will give you a better result.
btw u going to vegas?
xrayaustin is offline
Old 09-17-2012, 09:54 AM
  #115
defcone's Avatar
Trader Rating: 15 (100%+)
I had it like 3minutes in, I just dealt with it.
defcone is offline
Old 09-17-2012, 10:25 AM
  #116
ByteStream's Avatar
Just checking .. Are you using V1.1_120511_beta from the Version 3.1_120808 Package of software? That package is the latest.
ByteStream is offline
Old 09-17-2012, 11:06 AM
  #117
Try reducing turbo disangage. It should help.
Hi-LowBlow is offline
Old 09-17-2012, 12:40 PM
  #118
artwork's Avatar
Trader Rating: 88 (100%+)
Both Adam and I have noticed it and I have sold mine as a result. Plain and simple it needs to be fixed and until it does I will steer clear of this ESC for stock racing. I love the design, but on the track it does not feel quite right to me!
In mod I bet it works just fine...
artwork is offline
Old 09-17-2012, 04:31 PM
  #119
Warren Weaver's Avatar
Trader Rating: 49 (100%+)
are you running the latest version if not i will set you up with the update,i did take all drag brake out on mine didnt like it not rolling at neutral
Warren Weaver is offline
Old 09-17-2012, 04:33 PM
  #120
COBRARACING's Avatar
Hi guys
it has come to my attention about a company called Aliepress in china supplying a copy version of the 2.1v but calling it the v3 under the brand hobbypower .
First it's a copy of the 2.1v 120 amp second we have no connection with the branding hobbypower .
So dont get caught out
happy racing guys
Angelo
COBRARACING is offline
