Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 08-07-2012, 06:30 AM   #61
anyone got a good setup for firstly
13.5 Speedpassion MMM boosted - what endball timing should I be setting and also FDR
Secondly, I heard that LRP X12 doesn't work too well with the V3, is this true or false? if false anyone got some setting for it?
I am running a 40M straight track small to medium size technical with 4 small hairpins
Thanks guys
Tamiya - TRF 417V5 - Smokem - Hobbywing V3 - Reedy Sonic 4.5 Mach2
Sanwa M12
iwkyb is offline   Reply With Quote
Old 08-07-2012, 06:37 AM   #62
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
It works just fine. You only need to reduce settings on the speedo as motor comes with lot of timing
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
nnick is offline   Reply With Quote
Old 08-07-2012, 04:28 PM   #63
Tim Kowal's Avatar
Originally Posted by TRG View Post
I just checked the ROAR listing and I found this.
HOBBYWING - XERUN V3 - XERUN 120A SD V3 BRUSHLESS ESC V1.1_120511_BETA ESC MUST USE PROFILE #2 WHICH WILL HAVE A GREEN BLINKING LED THE POWER BUTTON
There is no part number.
Does this mean we can start using it???????????
Check here http://www.roarracing.com/?page_id=737http://
My power button blinks red when in profile 2, is ROAR incorrect or am I not in correct/current software?
TEAM ASSOCIATED - REEDY - J CONCEPTS - RC3 GRAPHIX - KOOL AID - TEAM P-NUT MOTORSPORTS.COM - SUPERIOR HOBBIES.COM
Tim Kowal is offline   Reply With Quote
Old 08-07-2012, 05:43 PM   #64
NolanP's Avatar
Mine blinks green and then red.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 08-07-2012, 06:59 PM   #65
narcotiks's Avatar
Originally Posted by melody5127 View Post
Anyone has idea the deifferences between hobbywing-xerun/120A-v3 & hobbywing-xerun/120A-v2?
V3 is the newer model which runs a different and more innovative software than the V2. Both are still good speed controllers.
narcotiks is offline   Reply With Quote
Old 08-08-2012, 04:54 AM   #66
xrayaustin's Avatar
Trader Rating: 12 (93%+)
Send a message via AIM to xrayaustin
Hey guys im going to be running 13.5 blinky with the v3 but am new to hobbywing. Could somebody please elaborate on the throttle rate switch point and the 1st and 2nd stage switch point.
Also I am running a d3.5 with about 20 degrees of endbell timing geared at 4.4. Its nit getting too hot. Does this sound about right?
Www.superiorhobbies.com
2010 cleveland indoor champs and 2011 snowbird nationals 17.5 stock A main winner
xrayaustin is offline   Reply With Quote
Old 08-13-2012, 04:02 PM   #67
Hi,
In one of my cars I wish to run this ESC without the fan due to space issues.
It's just in a F104 running a 21.5T motor and a 4200MhA battery, so I don't expect the ESC to be working as hard as in my Xray T3 2012 (that one has the fan on it).
Has anyone run the V3 without the fan?
How hot does it get?
(by the way, the reason I have the same ESC in my F104 and the T3 is in case of emergency at racetrack, I can choose which car to pull out of heats if one of my ESC's blows up during a meet. Always have a backup!)
Telinoz1975 is offline   Reply With Quote
Old 08-13-2012, 06:59 PM   #68
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by Telinoz1975 View Post
Hi,
It will be fine with no fan in a f1 car with a 21.5. I set up a friends car up like that and it had no issues
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 08-14-2012, 03:04 AM   #69
Thanks, I thought that would be the case.
I'm still sorting out some other issues with the kit and build just now, so maybe in a couple of weeks the car will be ready for first live test.
When I posted here, I also sent and email to Hobbywing with same questions (but I also asked for limits on motor <21.5T and max Battery type).
I'll post any replies I get here for other users to reference.
Old 08-16-2012, 02:37 AM   #70
Hi all,
Got a reply from Hobbywing:
If you run 21.5T motor, usually the cooling fan is not needed.
But please don't activate too much of boost timing and turbo timing, and you should monitor the temperature of the ESC after the trial running. If the ESC is very hot, that means maybe you active too much of boost timing or turbo timing.
Just because V3 ESC has the boost and turbo timing function, it is difficult to say for what type of motor the cooling fan of the ESC is unnecessary.
And you needn't consider about the battery capacity and C rate, only the battery cells number (2S or 3S)should be considered. When you use 3S, usually the using of cooling fan is always recommended.
I've asked them what temperature I should get worried (Hot is a bit vague for me!) - waiting for that response.
Has anyone measured the surface temperature on the heatsink during runs?
What is normal?
45-60DegC?
Old 08-16-2012, 03:21 AM   #71
SlideMasteR's Avatar
the esc will not overheat with a 21.5, ive run a boosted 4.5 (with the fan of course) at Heemstede in the IFMAR worlds and esc max temp in the data logger was only 90c max temp (which is what i would rate HOT)
Xray T4 15' - Hobbywing V3.1 ESC - Reedy Modified Motors - Thunder Power Batteries - Protoform - Much More
SlideMasteR is offline   Reply With Quote
Old 08-16-2012, 04:17 AM   #72
StevenOlsen's Avatar
Thanks guys
Have been running my V3 with a 4.0 and 4.5 x12 and it World fine, the motor is about 80 celcius after 5.30 min :-)
Steven Olsen
CAR: Awsomatix A700L.
Nosram 7000 Batteries.
Nosram Comet HD ESC.
Nosram Pure 2 evolution Motor.
StevenOlsen is offline   Reply With Quote
Old 08-16-2012, 04:20 AM   #73
peter.'s Avatar
hw v3 is the good in combination with a lrp x12 13.5
peter. is offline   Reply With Quote
Old 08-16-2012, 05:03 AM   #74
You got tHe setting for this?
I usually run my LRP with 4 dot (minimum) timing insert which is 27.5 degree right? Had some one burn up an LRP x12 13.5 with 4 dot + 30 boost + 30 turbo + 5.5 FDR last weekend and his car was actually slow on the straight
Sanwa M12
Old 08-19-2012, 10:21 PM   #75
my V3 burnt out on the weekend, running a 4.5T on large track. I get the feeling it had bad heat transfer between the electronics and the heatsink. (maybe i got a dud) because the temp reading on the heatsink was about 60c but the internal temp readout was 127c.
It has run sort of OK for 3 meetings but gave up, ironically after i reduced the timing settings. its a downgrade from my previous ESC in terms of speed. I know im running it close to its limits, when i first read internal temp and considered my car is a little slower on the straight than usual, i knew i had an issue.
I had thermal shutdown enabled at 125c so im supprised it failed. actually i dont see why this function should be user adjustable. maybe factory fixed at just under whatever the device can handle.
jeff_78 is offline   Reply With Quote
Hobbywing Xerun 120 V2 ESC for 1/10 cjtamu Electric Off-Road 289 09-15-2014 03:52 PM
HobbyWing XERUN 13.5T( V3 ) YZFAndy Electric On-Road 6 03-04-2011 04:48 PM
