Hobbywing Xerun V3
#721
Updated the firmware and fixed.
#722
Anyone got any suggestions on this one? A friends got a v3.1, it was working fine but then stopped, it started going in the final after someone pushed it from the line but then stopped mid race.
It turns on automatically when plugged in and has a red light. I've had a look, it is still factory soldered, so unlikely an issue with bad soldering etc. I connected it up to the PC and successfully flashed etc so it is somewhat working. It's been tested with two motors but doesnt go.
He said he very briefly connected up reverse once but only very briefly and worked fine for 5-6 meetings after that. It doesnt smell burnt out and looks perfectly fine inside the case.
Any possible suggestions on a fix?
#723
#724
I hooked it up for a motor on the bench last night and does seem to run better than he suggested, the motor does run with both a sensor and without however it did stall sometimes, so if you just feather the throttle the motor will not turn, you can hear it trying to go and the 'whine' gets a little louder the high the throttle but if you spin the motor then it'll run fine.
Thats the problem he said originally as the car wouldnt go from the start line until someone pushed it.
#725
Is it bad if my Hobbywing v3.1 turn on automatically when its plugged into a battery? Seems odd? Its been a year or two since i last used it. Also it seems to not like my 30mm Yeah racing Motor cooling fan in my 17.5 touring car. It will run for a minute or two with the motor cooling fan plugged in then sorta shuts dow and flashes red. Unplug fan and it runs fine. except it still powers up automatically when plugged into the battery??? Please advise. My son may have reverse poled it!
#726
If you dont mind powering it up like that it will work just fine.
#727
#728
Looking for some help:
I'm running a V3.1 in my 2wd buggy. (13.5)
Suddenly i noticed it lacking speed. And it seems the esc turns itself to blinky. Green led flashes.
When i connect the programbox it shows the 25 degrees of timing i set.
When i test it, it does run mod. At the table a threw the car around to see if that triggerd it to go to blinky, it didn't.
Volt protect and all heat protect are disabled.
#729
#730
#731
#733
setup for V3.1
hi,
could somebody give a good starting point how to setup my newly bought Xerun V3.1?
I drive b64
track is tight hight traction carpet track.
I drive mod class with 5.5t motor.
Any advise is welcome
I drive b64
#734
Fwd/Brk
LVC – auto voltage cutoff
ESC Overheat – disabled
motor heat – disabled
PR Sw point – 50%
1st punch rate – 15
2nd punch rate – 15
Th Curve – Linear
Neutral Range – 6%
Drag Brake – 8%
Brake Strength – 75%
Initial Brake – =Drag Brake
Brk SW Point – 50%
1st Brk Rate – 15
2nd Brk Rate – 15
Brake Curve – Linear
No Timing Function used
#735
Here is my V3.1 setup
Fwd/Brk
PR Sw point – 50%
1st punch rate – 15
2nd punch rate – 15
Th Curve – Linear
Neutral Range – 6%
Drag Brake – 8%
Brk SW Point – 50%
1st Brk Rate – 15
2nd Brk Rate – 15
Fwd/Brk
PR Sw point – 50%
1st punch rate – 15
2nd punch rate – 15
Th Curve – Linear
Neutral Range – 6%
Drag Brake – 8%
Brk SW Point – 50%
1st Brk Rate – 15
2nd Brk Rate – 15
