Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 12-15-2014, 09:17 PM   #616
i know hobbywing have a V3.1 ESC,is it the newest V3?
Jusitick is offline   Reply With Quote
Old 12-17-2014, 01:00 AM   #617
jsr555's Avatar
Trader Rating: 17 (100%+)
From their competition line yes. They also have the v3.1 stock spec and I believe they have a new Just stock coming out.
http://www.hobbywing.com/product_show.asp?id=284
Xray T4 - Yokomo Bd7-14 - HPI Pro5 - Powered by Hobbywing
HPI RS Pro - HPI Pro 3 - ??
jsr555 is offline   Reply With Quote
Old 12-21-2014, 07:36 PM   #618
Hey guys just put in a new 3.1 running 17.5 blinky 3.8 ratio. Small med size track.
I am getting high temps in the motor and esc... I had a lrp sxx in before same motor running about 25f higher. Both esc feel good. But with the hw on profile 2. Esc temp 125f and motor was 180s...
Anyone else notice?
Gordie88 is offline   Reply With Quote
Old 12-21-2014, 09:28 PM   #619
ByteStream's Avatar
Anyone else notice?
What motor are you running? What do you have the endbell timing set at? For 17.5 TC 3.8 - 4.0 FDR works well for most motors. Your ESC seems a little warm but your motor seems like it's running hot. For motor temp, I'm usually around 140F for club racing and no more than 160F at larger races.
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 01-29-2015, 12:41 PM   #620
Trader Rating: 14 (100%+)
I have a couple questions about a XERUN V3.1.
1) When removing all timing and boost (0 deg), it blinks red on the ESC. Is that normal?
2) What profile should I run for 1/10th 2WD Buggy Off Road Carpet in the 17.5T stock class?
3) Do I need to recalibrate after I change settings in the ESC?
THanks!
sstriano is offline   Reply With Quote
Old 01-30-2015, 12:31 AM   #621
THanks!
Answers
1. Yes the flashing red light indicates the ESC is in "blinky" mode I.e no boost or timing.
2. Sorry I run on road,so no idea.
3. No need to recalibrate after changing settings
markrobinson is offline   Reply With Quote
Old 01-31-2015, 09:06 AM   #622
hi all, i have a problem with my V3.1 esc
when i program it, i dont see all features
i have last firmware but i dont see:
4B and other boost timing parameters
i see 4A boost timing, but i dont see 4B, 4C.. etc, it goes to 5A direcly, so i cant set the rpm value for boost timing as described in the instruction....
same thing from program card and PC....
help
turboboost is offline   Reply With Quote
Old 01-31-2015, 11:58 AM   #623
And believe that's correct, latest version software took these parameters away.
adyb is offline   Reply With Quote
Old 01-31-2015, 12:08 PM   #624
ok... so why? i cant change the BOOST timing curve in this way.... not? (by setting the max and the min rpm, we can change the dynamic boost behaviour)
Old 01-31-2015, 01:57 PM   #625
Search "cobraracing" one of his posts recently explain why.
Old 01-31-2015, 06:22 PM   #626
If you know what you are doing don't use this software, use the previous version that has all the options available.
DamianW is offline   Reply With Quote
Old 01-31-2015, 08:02 PM   #627
TryHard's Avatar
The ESC figures out the boost RPM range for itself on the latest software... and does a pretty decent job of it too, in my opinon. Give it a try.
If you desperately want/need boost rpm control, then you'll have to use an older version.
HiH
Ed
Old 02-01-2015, 12:59 AM   #628
i think the best optiion was to add the AUTO mode at the regulation, not to take off all of them
thanks you all, unfortunately i dont be able to find cobraracing post.... he have too much...
Old 02-07-2015, 04:43 PM   #629
swimbikerun's Avatar
Trader Rating: 100 (100%+)
Default New Hobbywing V3.1 1S
I just purchased the HW V3.1 1S ESC and loaded the latest software/firmware. I have the speedo connected to an Sanwa/Airtronics RX471 receiver which is controlled by a Sanwa/Airtronics M12. The voltage cutoff is turned off. The issue I am facing is that the ESC shuts down during calibration. I know the receiver is bound since I have power and control the steering servo. I hold down the power button and the ESC goes into calibration mode with the 3 beeps. When I hit the button to confirm neutral the ESC shuts down. I still have power to the servo/receiver but the ESC is down. I will have to unplug the battery to repower up. What am I missing?
-Xray T4 '16/Xray X12 '16
-2010 Cincinnati Beer Mile Champion
swimbikerun is offline   Reply With Quote
Old 02-28-2015, 08:10 PM   #630
Cedric50's Avatar
Send a message via Yahoo to Cedric50
Default Xerun V3.1 1s: How to Set "Blinky" mode for 13.5?
I have a Xerun V3.1 1s ESC and the Multi-function LCD Program Box from Hobbywing. In the documentation for the ESC it list "Blinky" as one of the factory loaded profiles. However blinky mode is not listed as one of the profiles. Is there downloadable Blinky mode profile from Hobbywing, or is there documentation that will instruct me on how to make these setting changes? I am also running a Reedy Sonic 13.5 motor. Any assistance will be greatly appreciated!!
Serpent 966 TE V2 - Trinity Nitro Reflex - Team Magic G4 - NovaRossi Engines - Byron's GEN2 Racing Fuel
Cedric50 is offline   Reply With Quote
Hobbywing Xerun 120 V2 ESC for 1/10 cjtamu Electric Off-Road 289 09-15-2014 03:52 PM
HobbyWing XERUN 13.5T( V3 ) YZFAndy Electric On-Road 6 03-04-2011 04:48 PM
