Like Tree2Likes
Hobbywing Xerun V3
Old 09-16-2014, 10:10 AM
  #601
nicorozog's Avatar
Default Brake Control
As we know, this ESC has tons of options, but sometimes is quiet hard try to understand some of them, especially in the brake panel. Probably, The only way to understand changes in the ESC Setup is testing, and see what is the best point for the driving style.
However, i would like to know what can i expect if i change, increase and decrese these options:
1. Brake Strenght
2. Brake Rate Swicht Point
3. 1st and 2nd Brake Stage Rate
Thanks.
nicorozog is offline
Old 09-17-2014, 12:06 PM
  #602
13Maschine's Avatar
I have a very new HobbyWing Xerun 3.1 and the original fan has already failed. I've only had one day of practice on it. When I turn the car on the fan spins for a moment then stops. Even if I try to hand spin it it won't start up again. It's nice that the ESC came with a spare, but I'd really like to know why I've gone through so many fans. Perhaps we need to be using ball bearing fans that are more able to withstand bouncing around in a car? Is there any warranty on my fan? Thanks!
13Maschine is offline
Old 09-17-2014, 12:44 PM
  #603
xrayaustin's Avatar
Trader Rating: 12 (93%+)
Originally Posted by xrayaustin
Can anybody guide me in the right direction for a speedo setup for mod. Im running a orca 4.5 and am lookong for a good starting point. The track is about 160x75 medium to medium-high bite. But i live in florida and temps are an issue so not something super aggresive. Im currently geared at a7.94 with the first mark past 0 for motor timing. Just need a good speedo setup to go with it.
Anybody?
xrayaustin is offline
Old 09-17-2014, 04:36 PM
  #604
ByteStream's Avatar
Anybody?
Starting Points .. 4.5T
Andy Moore's setup (asphalt)
http://www.hobbywing.com/uploadfiles...-2012IFMAR.pdf
Atushi Hara's setup (asphalt)
http://www.hobbywing.com/uploadfiles...s-TITC2013.pdf
Paul Lemieux's setup (carpet)
http://www.hobbywing.com/uploadfiles...L-SNOWBIRD.pdf
ByteStream is offline
Old 09-17-2014, 05:44 PM
  #605
13Maschine's Avatar
@xray: I may have missed it, but what kind of car are you running and what kind of track or tracks are you running on? Generally since you are running a 4.5, I would suggest any of the mod profiles the are built in to your unit. Do you have the programing box?
Old 09-17-2014, 05:54 PM
  #606
xrayaustin's Avatar
Yes i do have a box. I run a 418 mostly on asphalt. Anywhere from low bite dusty tracks to super high grip. i think im going to start with andys setup and go from there on feel
Old 09-19-2014, 09:40 AM
  #607
13Maschine's Avatar
Old 09-19-2014, 10:12 AM
  #608
valk's Avatar
Lol I.killed both fans in the first day on my.2014.
First one I killed.immediately.clamping the shoegoo second one I guess was just really delicate.
Ill prob pick up an orca or speed passion fan to replace. I wouldn't hold my breath about waranty on fans. Maybe if you run into a hobbywing rep you can score a spare or two.
valk is offline
Old 09-20-2014, 06:13 AM
  #609
Default Program Box
Hey Guys,
Im new to hobbywing. I bought an XERUN V3.1. As I try to update the program box. It ask me to pay $3.99 since the file is too large. Is this normal?
fx35rc is offline
Old 09-21-2014, 07:42 AM
  #610
TB03Racer09's Avatar
I'm looking for a new esc as I had accidently stuffed up my justock esc.
- Will be racing 21.5t and 13.5t blinky touring car
- Must have in-built switch
- No pre-soldered motor wires
- Lightweight and compact designs
The esc that ticks all these boxes that is currently available seems to be the stock spec v3.1. The new zero spec seems more appropriate however it hasn't been released yet. Any idea on a release date/month so I can decide if I should just get the stock spec or wait for the zero?
TB03Racer09 is offline
Old 09-23-2014, 10:45 AM
  #611
YoDog's Avatar
Trader Rating: 28 (100%+)
Originally Posted by fx35rc
Hey Guys,
What???
Who would you pay $3.99 to?
I would say you have spam issues. The program box can't charge you money.
YoDog is offline
Old 12-15-2014, 05:25 PM
  #612
Just got a new Hobbywing v3.1 and it comes with two fans? the first one lasted all of 1 minute so I have the spare on there now. Anyone else had a issue with these fans? other then the fan the quality of these units is impressive so far... testing soon. updated to the latest firmware with no issues.
rbr31andrew is offline
Old 12-15-2014, 06:15 PM
  #613
jsr555's Avatar
Trader Rating: 18 (100%+)
Get the 3.1 Stock Spec. I got one recently for 13.5 blinky. Great little compact speedie.
jsr555 is offline
Old 12-15-2014, 07:01 PM
  #614
evochick's Avatar
only run a fan if you are running Mod, not needed for anything else,
But yes the 3.1 Stock Spec is also a great ESC, I even ran a 5T in TC the other week without any dramas (yes I ran a fan then), I run one in my F1 and spare TC and would have no problems replacing the full V3.1 that I currently use if I blew it up.
evochick is offline
Old 12-15-2014, 07:07 PM
  #615
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
The V3.1 have pre-soldered motor and battery wires. Luckily they are all black this time but are 12 gauge. They use some serious solder because I really have to crank up the heat on my solder iron to get it liquified.
The V3.1 stock spec is pretty compact and light. I have the regular V3.1 also (with the aluminum case) but its only needed for really low turn mod.
Dan is offline
