Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 07-23-2014, 07:00 AM   #526
hobie814's Avatar
Xerun 120A v3.1
hobie814 is offline   Reply With Quote
Old 07-24-2014, 05:56 AM   #527
hobie814's Avatar
Originally Posted by ByteStream View Post
Which ESC are you using?
Hold the power button until you start to hear 'beeping' - usually 3+ seconds.
I hold the power button a long time and nothing happens... no beeping.
Old 07-24-2014, 06:12 AM   #528
hobie814's Avatar
Here are all thee entails about my devices if i can help you to address the problem:
LCD program box: V1.13_131106
Hardware version: HW310 V1.0
Database version: 140503
Car ESC: V3.1_121129_Beta
Hardware version: HOBBYWINGS_456_V2
Database version: 130814
Old 07-24-2014, 07:06 AM   #529
ByteStream's Avatar
I believe the program box is up to V1.17 .. but will have to check and don't have my LCD box on hand (lent to a friend).
I would try to reinstall the ESC firmware if possible.
When you are trying to get the ESC into calibration mode .. is everything hooked up? sensor wire, motor wires, etc - just curious.
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 07-24-2014, 07:23 AM   #530
hobie814's Avatar
Yes everything is hooked up.
I already reinstall the ESC firmware 2 times successfully but still the same issue
Old 07-24-2014, 07:37 AM   #531
ByteStream's Avatar
I've never seen a V3 HW ESC not want to enter calibration mode. Only HW exception was very early releases of the 1S Xerun with V1 blinky software.
Can you perhaps post a video of what your doing? (showing the connections, what lights are flashing or not)
What profile did you set the ESC to? What color light is on when you turn it on (without trying to calibrate)? flashing pattern?
Old 07-24-2014, 04:24 PM   #532
hobie814's Avatar
I use the profile 1. I will check tonigh to answer your other questions and will also try to make a short video. Thanks again for your help ;-)
Old 07-25-2014, 05:32 AM   #533
hobie814's Avatar
Just updated the software of the box with a _V3 version and now the box works again when connected to the ESC. Still I can't calibrate the ESC... When I start the ESC with my radio on, the green light is blinking and if I accelerate a little bit it becomes red and comes back to green immediately after and the motor is working well. But still when I try to push the power button a little bit of time, nothing happen, still the green light blinking. And if I stop pushing, the ESC switches off.
Old 07-25-2014, 05:46 AM   #534
COBRARACING's Avatar
yes it will power off if you press the button more than a few times past calibration.
Please send me an email to ae@hobbywing.com
COBRARACING is offline   Reply With Quote
Old 07-26-2014, 12:38 AM   #535
hobie814's Avatar
Good news, this morning I could calibrate my ESC
I just plug in the battery cables with maintaining the power button pushed and I could do it. Don't ask me why. Thanks to all of you for your support.
Old 07-30-2014, 02:32 AM   #536
Born2Run's Avatar
Angelo are you still in vacation in GR?
Whatever
Born2Run is offline   Reply With Quote
Old 07-30-2014, 08:21 PM   #537
no im back
Old 07-30-2014, 11:04 PM   #538
Born2Run's Avatar
I didn't have the chance to meet you there.Maybe the next time you'll come .
Whatever
Old 07-31-2014, 02:55 AM   #539
G-rem's Avatar
Hi Angelo,
I've just done the software update for my V3.1 esc with the "V3.2_140627_Beta" software and I'm rather surprised to see that the options to set the boost timing were removed (4B and following), the only thing I can tune now is the amount of boost I wanna have, compared to the previous version where we could select the Boost start and end rpm, the boost slope,...
Is that normal and why a such decision?
Anyway, I can't wait to try these new software on track!
Best regards,
G-rem
G-rem is offline   Reply With Quote
Old 07-31-2014, 04:37 AM   #540
daleburr's Avatar
Originally Posted by G-rem View Post
Hi Angelo,
Best regards,
G-rem
Was just about to ask the same thing! Will give the new software a try on the dyno tonight and see how it looks. Maybe HW have found a better way of doing things :-)
Or maybe they've just been removed as most people set them way too low which just generates lots of heat and no extra power.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Hobbywing Xerun 120 V2 ESC for 1/10 cjtamu Electric Off-Road 289 09-15-2014 03:52 PM
HobbyWing XERUN 13.5T( V3 ) YZFAndy Electric On-Road 6 03-04-2011 04:48 PM
