Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 07-12-2014, 09:41 AM   #511
ByteStream's Avatar
The current version of the USB Link Software is v3.42 .. it is the program for your PC.
The current version of the LCD Box Software is V1.17
If you open the USB Link Software on your PC their is a menu item at the top called "Device" - make sure you have it selected to what you are trying to update .. either the ESC or the LCD Program Box, each has their own software versions.
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 07-12-2014, 10:49 AM   #512
OttoKrosse's Avatar
THANK YOU, that does help to clear the fog.
My learning curve is still very steep with all the new technology, being away from RC cars for over 25 years has it's downside.
This space for rent.
Oo=00=oO
OttoKrosse is offline   Reply With Quote
Old 07-12-2014, 06:01 PM   #513
Default Esc advice
I searched this forum for an official hobbywing forum and could not find one. I am looking for a hobbywing esc for mod touring car. I am not sure whether I will use a 3.5, 4.0 or 4.5 turn in a associated tc4 for now.... I believe I may have at least two choices within their line of esc....what say you... FYI this is for a large track only...
SouthFloridaApp is offline   Reply With Quote
Old 07-12-2014, 08:28 PM   #514
FastPete's Avatar
Trader Rating: 44 (100%+)
V3.1 120A
Authorized Dealer for /Agama / Tekno / Team Associated / Schelle / Hobbywing / PT Racing Shock & Diff oil / Serpent / Tekin / JConcepts / AKA / Proline / Savox / M2C / Picco / www.fiercercsolutions.com Like us on facebook www.facebook.com/FierceRCSolutions
FastPete is offline   Reply With Quote
Old 07-12-2014, 09:56 PM   #515
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Run the V3.1 120A Xerun
Best ESC for mod sedan imho.
Old 07-13-2014, 12:15 PM   #516
sorted
Bryan D is offline   Reply With Quote
Old 07-14-2014, 02:57 PM   #517
JayL's Avatar
angelo: any update on the new blinky esc, timeline wise?
We are trying to create an 'equal' F1 class running a fixed timing 21.5T motor, and are looking for a 'no timing options' ESC that is inexpensive and rumors say the JuStock will be discontinued, but it would be perfect
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 07-22-2014, 06:50 AM   #518
sohlman's Avatar
Trader Rating: 89 (100%+)
I have a Xerun 120a v3.1 and it won't connect to my PC. Connected ESC to LCD box to PC as directed in the manual. Running 3.42 on Windows 7 Starter. LCD box is running v1.17_140315. I can connect ESC to the LCD box no problem, but not PC. Same result for all my ESCs. Any suggestions? Thanks for your time.
Steve Sohl
sohlman is offline   Reply With Quote
Old 07-22-2014, 06:58 AM   #519
ByteStream's Avatar
Could be the order of the steps.
1. Start the USB Link Software
2. Connect the ESC to the Computer via the programming box.
3. Turn the ESC on. (must be connected with batteries)
4. The program should recognize your ESC.
* Make sure under the Device Menu at the top that "ESC" is selected.
* Try different USB Ports
Old 07-22-2014, 07:31 AM   #520
sohlman's Avatar
Thanks. My LCD box connects to PC no prob. I've tried just about every order combo with no success. The only thing I have not tried is "run as administrator" as suggested by Slotmachine. Hope thats it. Will try that tonight.
Steve Sohl
Old 07-22-2014, 08:17 AM   #521
ByteStream's Avatar
Just to cover the basics ..
1. You should have your program box connected to the PRG/Fan Port (not the RX plug).
2. The leads to the box/esc should be plugged in correctly +/- (this appears upside down when looking down at the box)
3. Once the LCD box connects .. hit the first button on the box if nothing happens .. it should say connecting to ESC.
4. Run as Administrator.
Old 07-22-2014, 08:37 AM   #522
FastPete's Avatar
Good luck and report back.
Old 07-22-2014, 05:48 PM   #523
sohlman's Avatar
Worked. Not sure why the "run as admin" makes a difference, but I'm also a Mac guy so I guess I should just be happy. I am. Thanks guys.
And by the way, great speedo. I have a few and plan to buy more.
Steve Sohl
Old 07-23-2014, 06:11 AM   #524
hobie814's Avatar
Hi,
Yesterday I decided to make the update to the 3.42 version of the USB link. I did the installation on my PC, everything ok. Then I updated my box and then my ESC. Everything seems ok but when I start again my ESC, I could not make the throttle adjustment, I push the button 2 seconds but no red light and when I released my finger from the button, the ESC just switched off. Then I connect my box again and I got the following message: software has to be updated. But both software are updated apparently. Can somebody help me? Thanks in advance.
Bruno
hobie814 is offline   Reply With Quote
Old 07-23-2014, 06:46 AM   #525
ByteStream's Avatar
Originally Posted by hobie814 View Post
Hi,
Bruno
Which ESC are you using?
Hold the power button until you start to hear 'beeping' - usually 3+ seconds.
Hobbywing Xerun 120 V2 ESC for 1/10 cjtamu Electric Off-Road 289 09-15-2014 03:52 PM
HobbyWing XERUN 13.5T( V3 ) YZFAndy Electric On-Road 6 03-04-2011 04:48 PM
