Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 02-16-2014, 10:31 AM   #421
Hey there,
I do have a question about the braking performance of the Hobbywing controller.
I am using the Hobbywing XERUN V3.1 with latest level of Firmware in my XB4 with 7T motor without issues and also in my T4 touring car with 13,5T engine.
Unfortunately the touring car has nearly no braking power when coming from high speeds. The braking power is set to 100%. I have to say, that I changed the motor and also the power cap of the controller at the same time, as I misconnected the power connection.
Now I observed, that the power cap differs from that, which is connected in the XB4, which is still the original one. According to my local dealer, that red one is the part to use.
Does anyone have any experiences with exchanging the power caps and any possible relation to break performance? Is the power cap the right part?
Is there any other root cause possible for missing brake performance?
For a better understanding, here is a picture of the exchanged cap:
abload.de/image.php?img=t427sg2.jpg
And the original one:
abload.de/image.php?img=xb4ins94.jpg
Thanks a lot for support.
Jörg
XRAY XB9 - XRAY XB9e - XRAY XB4`14 - XRAY T4
www.nitromaniacs.de
JSchirchen is offline   Reply With Quote
Old 02-16-2014, 11:36 AM   #422
COBRARACING's Avatar
Originally Posted by JSchirchen View Post
Hey there,
Jörg
The power cap is correct it is also a larger cap board.What i want to ask you is what motor you running what brand and please send me your settings to ae@hobbywing.com
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 02-17-2014, 08:22 AM   #423
Hello,
I run a 4.5 Motor and I am a little bit lost !!!
which timming and ratio do you recomend?
What punch makes? and how works the 2 stage of punch, where do you feel them?
If we want a smoother power in bottom and more top speed what should we change in the speedo?
Which is the maximun timming recomend?
Between which rpm you work with the boost?
How do you get medium power?
Thank you for your help
RC Racing addict
Roedor is offline   Reply With Quote
Old 02-17-2014, 10:12 PM   #424
32819toon's Avatar
I've bought a v2.1 90A Xerun for my son and have tried to program it using the v3.4 software upgrade from the website. When trying to program the esc from the program box, I'm only getting standard setting, not the turbo & boost etc. The firmware it's giving me are versions v1.11_120331_v3 or v1.08_120504. Can someone point me in the right direction where I might find it ?
32819toon
VBC Wildfire D08, Yokomo BD7 RS, Schumacher Atom, Tamiya M03, M05 (outdoor Mini), M03RWD, MF01-X, BSR M-Rage, ABC Gambado, Associated TC4 (outdoor car).
32819toon is offline   Reply With Quote
Old 02-17-2014, 10:14 PM   #425
504 is what you need to.load .
Old 02-17-2014, 11:53 PM   #426
32819toon's Avatar
Thanks for the quick response. Do you have a link ?
Thanks again.
32819toon
Old 02-18-2014, 03:34 AM   #427
TryHard's Avatar
Thanks again.
Angelo means you need to load the V1.08_120504 software onto your esc. Most of the softwares are shorted to the final three digits, hence "504". The names themselves are actually the dates.. so 120504 is 4th May 2012.
HiH
Ed
Old 02-18-2014, 03:48 AM   #428
32819toon's Avatar
HiH
Ed
Thanks Ed, I'll try that
32819toon
Old 02-18-2014, 07:50 AM   #429
32819toon's Avatar
When I switch the program box on its the right software, but when I press R/P it says v1.10_090205_MOD but still doesn't show any more setting. Am I doing something wrong ?
32819toon
Old 02-18-2014, 08:58 AM   #430
32819toon's Avatar
All sorted now, thankyou
Where can I find some suggested set ups for 17.5t on a small track ?
32819toon
Old 02-22-2014, 05:26 PM   #431
Hi guys
Ive had some enquiries on how to limit the kick from the turbo so it is not so aggressive from boost to turbo.
You must overlap the boost and the turbo by 1000 rpm which means the boost end rpm is for example is 13000 you will need to start your turbo at 12000 and activation must be full th and rpm .
Old 02-28-2014, 10:40 PM   #432
pullstarter's Avatar
Trader Rating: 14 (100%+)
Hey Guys,
Just installed a V3.1 and not sure what firmware I need to use for "Blinky"? Can anyone help me out here?
Cheers
Simon
pullstarter is offline   Reply With Quote
Old 02-28-2014, 11:01 PM   #433
Originally Posted by pullstarter View Post
Hey Guys,
Cheers
Simon
Profile 2 is zero timing.
Old 02-28-2014, 11:46 PM   #434
Cheers
Old 03-03-2014, 12:44 PM   #435
jasons56's Avatar
How is the 3.1 1s Roar approval coming along?
I was able to get another 2.1 and made the A at the Nats with it, but would love to run my 3.1.
Let us know when it makes the list!
Thanks!
http://www.youtube.com/user/ZenRacing
jasons56 is offline   Reply With Quote
Hobbywing Xerun 120 V2 ESC for 1/10 cjtamu Electric Off-Road 289 09-15-2014 03:52 PM
HobbyWing XERUN 13.5T( V3 ) YZFAndy Electric On-Road 6 03-04-2011 04:48 PM
