Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 02-10-2014, 02:23 AM   #406
COBRARACING's Avatar
Originally Posted by sgp-chris View Post
Hi guys,
I really hope you can help shed some light on this problem I'm having.
I'm new to electric touring cars (been running nitro alot), so it's possible that I can make every rookie mistake out there.
I have a V3.1 straight out the box, with no firmware updates (wanted to keep it simple at first) I'm running a SpeedPassion 17.5 V3 motor in Blinky mode (profile 2 if I remember correctly on the ESC)
When I run the car, it can do x amount of laps with no issues (17 last night) and then it begins to not respond to my throttle input. It doesn't matter if it sits on the track or I'm holding it in the air. I give it some throttle a couple of times, and then there is no response. I then have to turn the wheels manually to get it going again.
The motor and ESC is not getting too hot and my FDR is 4.34:1
Is it a firmware issue?
Motor issue?
Sensor issue?
Something else?
I am totally lost, and so was the people I had looking at it last night.
I hope you can give some advice on how to solve this problem
Sensor issue could be your sensor cable or the sensor board on the motor.I know of someone else that had the same issue and the motor was new and it was a sp motor
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 02-10-2014, 05:34 AM   #407
sgp-chris's Avatar
I tried changing the sensor cable, it didn't help. I also tried another SP motor with the same results....
Hotbodies D812 | Schumacher Mi5
sgp-chris is offline   Reply With Quote
Old 02-10-2014, 06:54 AM   #408
Trader Rating: 27 (100%+)
I had a similar problem. Tried two different motors. Turns out both motors had bad sensor boards. Once I changed them everything was fine.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 02-10-2014, 07:44 AM   #409
sgp-chris's Avatar
I just tried a third SP motor. Brand new out of the box, and I had the same issues. 3 different sensor cables, and nothing helped.
Tried connecting the esc with my lcd program box, and it wouldn't connect. Tried to connect thru my laptop, and still nothing...
Then I tried connecting my Justock esc with the lcd box, and also the laptop. And it worked perfectly...
Something must be wrong inside the V3.1 esc...
Old 02-10-2014, 11:15 AM   #410
Are you using the programming port to connect ? Or the rx cable .Also remember you will need to have your radio on and no signal input or the rx cable removed because the rx takes precedant over the programming port
Old 02-10-2014, 01:33 PM   #411
peter.'s Avatar
thank you very much COBRA RACING (ANGELO ECONOMOU)
for your suport for me hw v.3.1 with setups i've had a lot esc but the suport was never as good as hw thank you very much for that
King regards peter
peter. is offline   Reply With Quote
Old 02-10-2014, 03:01 PM   #412
sgp-chris's Avatar
I was using the RX cable to connect both esc's. It work ed on the JUstock, but not the V3.1
Old 02-10-2014, 04:19 PM   #413
TryHard's Avatar
On the v3 you need to connect via the programming port. Connecting via the rx cable does nothing.
Old 02-10-2014, 04:29 PM   #414
King regards peter
Your welcome anytime
Old 02-10-2014, 05:42 PM   #415
sgp-chris's Avatar
Originally Posted by TryHard View Post
On the v3 you need to connect via the programming port. Conneting via the rx cable does nothing.
Well that explains ALOT! Thank you, I will try that when I get home. I uset the RX cable because it was show in the program box manual...
I am hoping that a firmware upgrade is the solution...
Old 02-10-2014, 06:37 PM   #416
Monsta's Avatar
I was that person.
I bought the SP 13.5 as a stopgap due to my Mach2 letting the smoke out. the SP now only has about 20min run time on it - if that. running 3.7fdr and only temping at 65deg.
I would get maybe 2 laps before the motor would cog down low and behave as if in a boosted profile (half power for 2sec then normal - in blinky profile). Easy looking as if it was a ESC issue. Ended up trying another reedy and the problem went away.
I just wanted to say thank you to Angelo again. Fantastic and quick support for an issue that had nothing to do with the ESC (v3.1)
BD7 '14 / Trinity / LRP / SANWA
F1R2 / Reedy / Hobbywing / SANWA
1:1 racer
HR31 Skyline - 350Kw RB30DET, 1130kg and 255 wide R comp tyres... needs more traction!
Monsta is offline   Reply With Quote
Old 02-10-2014, 07:40 PM   #417
Originally Posted by Monsta View Post
I was that person.
Its my job so your welcomeNow go out there and have fun lots of it.
Old 02-11-2014, 07:23 AM   #418
sgp-chris's Avatar
My current firmware is V3.1_121129_Beta
Is that okay, or should I upgrade to something else???
EDIT: Next piece to the puzzle. I've again tried 2 different SP motors, and 3 sensor wires. When I give it full throttle and let go again, the motor will only stop working when it stops at a certain point. I watched the set screw on the pinion, and it would only refuse to rev again when it stopped at the exact same angle of rotation. I switched motor, and it was the same result with both. But the rotation angle was different between the motors.
If it stopped at any otner point of rotation, I could rev it again with no issues.
Does this mean I have a sensor problem inside the esc? Changing wires didn't help the issue.
It also sounds abit rough when it runs. Not like when it runs completely withpout a sensor, but something in between. It's not a nice smooth sound. It goes for both motors.
Old 02-11-2014, 01:06 PM   #419
The software is correct.
It sounds more like a batch of faulty motors from sp .It is a sensor board issue the other issue could be that one of the phases on the esc is damaged but i dout it .
Please run a simple test for me pull out the sensor cable and let me know if it runs properly without the cable attached
Old 02-11-2014, 04:16 PM   #420
sgp-chris's Avatar
I don't think it's a bad batch of motors. There are aproximately 6 months between the 2, I just havent used one of them before now. They are also not the same turn (13.5 and 17.5) But I hope youre right, it would be a easier fix for sure
It can't be something to do with the esc getting too hot while soldering New wires on it? I removed all the coloured ones, and wired it up again with all black wires. The coloured ones where a pain in the butt to get off... :/
I will do the test when I get home
EDIT: I did the test you afsked me 2, and the motor runs fine without the sensor cable. A little rough, but no stops.
I first attached the sensor to the motor, gave it some throttle to verify where the motor stops. I did that a handfull of times, and it was the same spot each time. I then removed the sensor cable while the motor was in the "stuck" position, and it wasn't stuck any more. I did that a bunch of times aswell, and there where no issue when the sensor was out of the equation...
ESC sensor problem???
Hobbywing Xerun 120 V2 ESC for 1/10 cjtamu Electric Off-Road 289 09-15-2014 03:52 PM
HobbyWing XERUN 13.5T( V3 ) YZFAndy Electric On-Road 6 03-04-2011 04:48 PM
