Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 01-25-2014, 05:38 AM   #391
COBRARACING's Avatar
Originally Posted by FLAT OUT View Post
Wow that was a fast reply, any chance you can email me a setup for 17.5 blinky ? what throttle graph curve would you advise ?? awebb1977@googlemail.com
Email sent 1 hr ago enjoy
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 01-26-2014, 02:24 AM   #392
Hey guys
My club will be making the change from our usual 21.5 boosted class to a 17.5 blinky setup! i was wondering if anyone can share a setup gearing and endbell wise using hobbywing v2.1 120A with reedy mach 2 17.5? flowing outdoor asphalt track. Any help would be appreciated. Also wondering what are some of the key differences with the v3.1 and v2.1 as im looking to make the switch.
"No matter if you win by a inch or a mile, winnings winning".
AleD123 is offline   Reply With Quote
Old 01-26-2014, 07:56 AM   #393
I switched from the v2.1 to the v3.1 in 1S. There is a small difference in that the v3.1 gives a bit more low-down punch out of the corners. The biggest advantage is that the switch and the capacitors are built in so you don't have to find space for them. Footprint is smaller than the v2.1, weight is average, it's a bit tall to be ideal for 1S classes, but it is bullet proof, good value and reliable. You pays your money and you takes your choice! HTH
SlowerOne is offline   Reply With Quote
Old 01-26-2014, 08:16 AM   #394
Hey my basically new v3 isn't connecting to the programming card. Is there anything I can do besides contact support?
Hyperhobbies.ca
Rcbatterydepot.com
lee111m is offline   Reply With Quote
Old 01-26-2014, 08:10 PM   #395
Are you plugging in to the fan port prg? Is the esc on?
Old 01-27-2014, 12:12 PM   #396
I just got the hobbywing justock, but was under the impression I needed a booster or Rx pack to use it for 1s. In the manual it says
Bec output 6v@2A built in bec(switching mode DC-DC regulator).
Isn't a dc-dc regulator a booster?
JOE SI is offline   Reply With Quote
Old 01-27-2014, 11:01 PM   #397
To run 1s you need to remove the red wire from the rx cable to receiver and run either a booster or a rx battery pack
Old 01-28-2014, 04:50 AM   #398
Thank you
Old 01-28-2014, 04:55 AM   #399
Thank you
Welcome
Old 02-03-2014, 09:44 PM   #400
tiko's Avatar
Trader Rating: 35 (100%+)
Send a message via Yahoo to tiko
Quick question guy on the 2S 120v3.1 ESC it shows that it can be used for 1/10 and 1/12 cars. What I would like to know is do I need a booster or a receiver pack, or it's like the 1S ESC everything inside the unit.
LionArtPrints - Custom Apparel, Hats, PitMats, RC Car Bags, and More
LionArtPrints - On Facebook
tiko is offline   Reply With Quote
Old 02-03-2014, 09:48 PM   #401
Trader Rating: 27 (100%+)
If it's not the 1s version, then you'll need a booster.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 02-03-2014, 09:55 PM   #402
Not a 1s needs a booster or rx battery and the red wire removed from the rx
Old 02-03-2014, 10:29 PM   #403
tiko's Avatar
Old 02-04-2014, 04:50 AM   #404
Default Hobbywing 120amp V3.1
I am new to RC racing and I have just ordered the xeron 120a 3.1 esc, I needed some advice on setting this ESC up, so I contacted Angelo Economou at Hobbywing Tech to see if there was any setup sheets for this esc.
I have to say that I was so impressed with the level of service and the quick response from him regarding my questions and the level of information he has provided, I have no problems in pointing anybody who has any questions to this person, so big thanks to Angelo for all your help.
mick
Mick123 is offline   Reply With Quote
Old 02-10-2014, 02:19 AM   #405
sgp-chris's Avatar
Default V3.1 issue
Hi guys,
I really hope you can help shed some light on this problem I'm having.
I'm new to electric touring cars (been running nitro alot), so it's possible that I can make every rookie mistake out there.
I have a V3.1 straight out the box, with no firmware updates (wanted to keep it simple at first) I'm running a SpeedPassion 17.5 V3 motor in Blinky mode (profile 2 if I remember correctly on the ESC)
When I run the car, it can do x amount of laps with no issues (17 last night) and then it begins to not respond to my throttle input. It doesn't matter if it sits on the track or I'm holding it in the air. I give it some throttle a couple of times, and then there is no response. I then have to turn the wheels manually to get it going again.
The motor and ESC is not getting too hot and my FDR is 4.34:1
Is it a firmware issue?
Motor issue?
Sensor issue?
Something else?
I am totally lost, and so was the people I had looking at it last night.
I hope you can give some advice on how to solve this problem
Xray-shop.dk - Xray T4'17 - Xray X1'17 - #PHUB
sgp-chris is offline   Reply With Quote
Hobbywing Xerun 120 V2 ESC for 1/10 cjtamu Electric Off-Road 289 09-15-2014 03:52 PM
HobbyWing XERUN 13.5T( V3 ) YZFAndy Electric On-Road 6 03-04-2011 04:48 PM
