Like Tree2Likes
Hobbywing Xerun V3
Old 12-23-2013, 01:51 AM
  #346
Thumbs up Hobbywing 3,1
We would like to thanks Angelo from Hobbywing for his big help over the weekend with set-up and instruction for the V3.1 The best ever ESC we have had and also making the fastest time on track that we have ever made.
He also send us a set-up specific for our track with the SP MMM 5,5T that we use. And we have got a very smooth and powerfull set-up.
We can only say....Go for it !!!!!
RcHouse Racing Team.
Team Schumacher Denmark,
KILDK is offline
Old 12-23-2013, 07:12 AM
  #347
sgp-chris's Avatar
Anyone have some quick tips on the best way to shorten the long wire that goes from the esc to the reciever?
Is it best to cut the wire and clamp on a new connector, or open up the esc and solder the wire off, cutting it, and solder it back on?
Just asking because I have never done it before, but this wire is sooo long.
Sorry for any spelling mistakes
sgp-chris is offline
Old 12-23-2013, 07:53 AM
  #348
morgoth's Avatar
Do want to share it? I'm also running the Speed Passion MMM (4.5t - 5.5t) motors.
morgoth is offline
Old 12-23-2013, 01:20 PM
  #349
I am running the V3.1 in zero timing mode with an SP 13.5T. I was using the Tekin RS Pro before on the same motor, and think the Hobbywing is missing a lot of braking power ??
When I go through the set up on the esc, the brake power is set to 100%.
Any good advise how to get more braking power ?
Shock Tower is offline
Old 12-23-2013, 01:44 PM
  #350
Yes off course. Here you are. This is our starting point and we have increased step by step:
v3.0
Device
[Mode:]
Profile5
[Name:]
Stock 5.5T
[Running Mode]
Forward/Brake
[Reverse Speed]
25%
[Voltage Cutoff]
Auto
[ESC Overheat Protection]
125 degree Celsius
[Motor Overheat Protection]
125 degree Celsius
[Punch Rate Switch Point]
51%
[1st Stage Punch Rate]
20
[2nd Stage Punch Rate]
15
[TH Input Curve]
Linear
[Drag Brake]
4%
[Brake Strength] 75%
[Initial Brake]
=Drag Brake 0%
[Brake Rate ]
51%
[1st Stage Brake Rate]
Val:20.0
[2nd Stage Brake Rate]
Val:10.0
[Brake Input Curve]
Linear
[Boost timing]
14deg
[Boost Start RPM ]
14000rpm
[Boost End RPM]
25000rpm
[Boost Slope]
Linear
[Boost Controlled by TH]
Yes
[Turbo Timing]
12deg
[Turbo Activation Method]
Full TH
[Turbo delay]
0.3S
[Turbo Start RPM]
26000rpm
[Turbo Engage slope]
18deg/0.1S
[Turbo Disengage slope]
18deg/0.1S
KILDK is offline
Old 12-23-2013, 07:40 PM
  #351
FastPete's Avatar
Trader Rating: 44 (100%+)
Great job! And he is the best!
FastPete is offline
Old 12-24-2013, 02:58 AM
  #352
COBRARACING's Avatar
Merry xmas gents and thank you for the kind words .
COBRARACING is offline
Old 12-24-2013, 06:07 AM
  #353
Thumbs up
Yes, you are so right :-)
KILDK is offline
Old 12-24-2013, 06:12 AM
  #354
KELVIN KHNG's Avatar
Trader Rating: 15 (100%+)
Hi everyone
I have a hobbywing v3.1 and am
Currently using. 13.5t Revtec. I have tried using the titc
Set up on the hw website but it seems not appropriate for
My 40m straight. I was wondering if any of you have a good
Baseline 13.5 set up that I can use?
KELVIN KHNG is offline
Old 12-27-2013, 01:55 PM
  #355
Trying again and hoping someone has a hint.
Old 12-27-2013, 02:02 PM
  #356
Trader Rating: 28 (100%+)
I have seem some people suggest running the reverse power at 100% as well even if you are using forward / brake only. I have never had a braking issue with any of my Hobbywings (Justock, Xtreme Stock, StockSpec 3.1, 120a v3.1 or SCT Pro), however I have always had the reverse at 100% even if not using it.
treys1 is offline
Old 12-27-2013, 04:06 PM
  #357
bluef250's Avatar
i changed out the single cap with a 4 cap unit from an old speed passion esc and changed the reverse to 100% stops on a dime and gives u a nickle back
bluef250 is offline
Old 12-28-2013, 04:35 AM
  #358
Make sure that your motor rotor is shimmed to be as close to your hall sensors of your motor sensor as possible the you will see you braking power will rise
Old 12-30-2013, 08:47 PM
  #359
I'm looking at getting the XERUN-120A-1S V3.1 and would like to know if it roar approved or not.
Friulimotosport is offline
Old 12-30-2013, 11:13 PM
  #360
v3.0
Device
[Mode:]
Profile5
[Name:]
Stock 5.5T
[Running Mode]
Forward/Brake
[Reverse Speed]
25%
[Voltage Cutoff]
Auto
125 degree Celsius
125 degree Celsius
51%
20
15
[TH Input Curve]
Linear
[Drag Brake]
4%
[Initial Brake]
=Drag Brake 0%
[Brake Rate ]
51%
Val:20.0
Val:10.0
[Brake Input Curve]
Linear
[Boost timing]
14deg
[Boost Start RPM ]
14000rpm
[Boost End RPM]
25000rpm
[Boost Slope]
Linear
Yes
[Turbo Timing]
12deg
Full TH
[Turbo delay]
0.3S
[Turbo Start RPM]
26000rpm
18deg/0.1S
18deg/0.1S
are you really using 20 punch 1st and then 15? must be a handful to control the bottom end power ?! dont your motors get hot when using 5.5T and such high punch settings?
vitomon is offline
