Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 04-15-2013, 11:54 AM   #256
kempower2000's Avatar
Before racing her again next weekend, I will install a new sensor cable.
I'll let you know the outcome...
Originally Posted by kempower2000 View Post
Have used the esc 1 weekend now. Works great but for some reason the
data recordings are not complete anymore.
It does record esc temp, battery voltage and rpm, BUT motor temp is not measured anymore since the last 2 runs. In the beginning it did and it was a very handy feature...
Any idea?
kempower2000 is offline   Reply With Quote
Old 04-18-2013, 10:04 PM   #257
Any idea?
when you disable the motor overheat protection, it stops recording the temp
jeff_78 is offline   Reply With Quote
Old 04-19-2013, 07:20 AM   #258
Trader Rating: 57 (100%+)
What is the difference in the 120a v3 and 120a v3.1? I know the 3.1 has an aluminum lower case but is that the only difference? Do they run the same software/accept same updates?
PROMODVETTE is offline   Reply With Quote
Old 04-19-2013, 07:40 AM   #259
lewis110's Avatar
They both run the same firmware. The 3.1 also has rubber seals around the programing port and sensor ports. The fan is also raised up 1mm to help with better cooling.
Hobbywing of North America/FalconSekido www.falconsekido.com
Hobby-Pro USA www.hobbyprousa.com
Dialed RC Hobbies/VP Pro USA www.Dialedhobbies.com
lewis110 is offline   Reply With Quote
Old 04-22-2013, 07:35 AM   #260
Motor overheat protection was not disabled, BUT it must have been the sensor cable. I installed a different cable and he recorded again motor temps, all weekend long :-)
I ran a 6.5 Tekin gen 2, boosted and with turbo, in 4WD offroad. It's a great esc, it delivers amazing power!!!
Old 04-24-2013, 05:18 AM   #261
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
Not much of a change.
KREATOR1 is offline   Reply With Quote
Old 05-05-2013, 12:53 PM   #262
StevenOlsen's Avatar
hi guys, had a really strange problem with my Hobbywing V3.1 today.
I started my day with a X12 4.5 octa, ran great for about 5 batteries, then the regulator started blinking green (ESC overheat protection) and the next batterie, when i pulled the trigger about halfway down the motor just died and and when i relist the throttle again the motor would work again. I changed the motor and sensorwire. And now the ESC startes blinking green (ESC overheat) but when i but the program box on the ESC its only 89 degrees Celsius. the overheat protection is set at 125 degrees Celcius.
what is the problem with the ESC is it dead ? or is there something else wrong ?
Steven
Steven Olsen
CAR: Awsomatix A700L.
Nosram 7000 Batteries.
Nosram Comet HD ESC.
Nosram Pure 2 evolution Motor.
StevenOlsen is offline   Reply With Quote
Old 05-05-2013, 04:17 PM   #263
COBRARACING's Avatar
5 degree c cooler with the raising of the fan for better airflow.I do have something else coming soon to lower the temp even more but it will be an upgrade not a complete new esc so the version number will not change for now.
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 05-05-2013, 04:22 PM   #264
Steven
My first question how much end bell timing are you running on that x12?
Old 05-05-2013, 09:44 PM   #265
27.5 degrees min timing
Steven Olsen
Old 05-05-2013, 09:54 PM   #266
Car Breaker's Avatar
is 1s version coming out yet? anyone tried it ?
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Old 05-06-2013, 12:03 AM   #267
Have you added any inserts to go above the 27.5 degree timing that it comes with as standard >
Old 05-06-2013, 12:07 AM   #268
only 50 units have been released so far more after the 15th of may .
Old 05-06-2013, 03:14 AM   #269
No im using the 4 dot inserat giving the motor 27.5 degrees acording to the manual
Steven Olsen
Old 05-06-2013, 07:26 AM   #270
cyba888's Avatar
Very interested please post more info or pm me details
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Hobbywing Xerun 120 V2 ESC for 1/10 cjtamu Electric Off-Road 289 09-15-2014 03:52 PM
HobbyWing XERUN 13.5T( V3 ) YZFAndy Electric On-Road 6 03-04-2011 04:48 PM
