Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 11-16-2012, 09:55 AM   #151
John Doucakis's Avatar
Default V3 for sale
Hi guys,
I am selling my HB/HPI Flux pro which is virtually exact the same as the HW V3.
details here:
FOR SALE
John Doucakis is offline   Reply With Quote
Old 12-11-2012, 12:14 AM   #152
Monsta's Avatar
Hi guys, got a very noob question here...
Ive moving into stock(17.5t boosted) and have swapped out the old Novak GTB for the Hobbywing XERUN V3 120a. The only Program box's i can find all say;
The Professional Program Box is suitable for the following ESC's:
1. XERUN Series Car ESC (Version 2.0)
2. EZRUN Series Car ESC (Version 2.0)
3. PLATINUM Series Helicopter/Aircraft ESC's
Is this the correct one and will i just need to upgrade the firmware to work with my V3?
Thanks!
BD7 '14 / Trinity / LRP / SANWA
F1R2 / Reedy / Hobbywing / SANWA
1:1 racer
HR31 Skyline - 350Kw RB30DET, 1130kg and 255 wide R comp tyres... needs more traction!
Monsta is offline   Reply With Quote
Old 12-11-2012, 11:31 AM   #153
Warren Weaver's Avatar
Trader Rating: 46 (100%+)
Still the best speed control to date i have ever run
Warren Weaver is offline   Reply With Quote
Old 12-17-2012, 12:10 PM   #154
From looking at the positive responses, most of you are using this ESC for modified classes.
Has anyone compared this ESC to Tekin RS in the "blinky" mode? Please provide some feedback.
Thanks.
Yellowtaro is offline   Reply With Quote
Old 12-17-2012, 12:24 PM   #155
Jon Williams's Avatar
Thanks.
The speedo runs extremely well in 17.5T for me and a number of other on road drivers. As you've already heard it has buttery smooth throttle response. I have the blinky/no-timing settings set for maximum punch and have plenty of rip as the Weavernator can testify.
Jon Williams is offline   Reply With Quote
Old 12-17-2012, 03:27 PM   #156
S.Stew's Avatar
I like mine quite a bit however this weekend noticed that it really is lacking in terms of brakes.
The layout had two high entry speed tight corners where I really needed more braking power.
I had drag brake at 20%, brake force at 100%.
- Steven Stewart - Kawada USA
www.Kawada-USA.com
S.Stew is offline   Reply With Quote
Old 12-17-2012, 04:27 PM   #157
I do agree with you. It was a trade off for me in terms of some loss of braking force for stronger punch and better throttle response.
I would be curious if there's plan for a fix. A lot of guys have complained about the same thing.
Old 12-18-2012, 02:14 PM   #158
+ 1 I too feel the brakes are very weak in boosted 13.5
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 12-18-2012, 02:38 PM   #159
Someone post your settings my brakes are extremly strong infact i thought my lrp was the most brake until i used my v3 when it first came out i have gone through all of the firmware updates and they are always strong
Old 12-18-2012, 02:45 PM   #160
I think the motor being run can play a large part in the strength of the brakes
Old 12-21-2012, 12:06 PM   #161
lochness42's Avatar
Anyone had issue with their v3 loosing power on full throttle but also sometimes during acceleration? It's doing randomly and receiver is still powered. If I release throttle and punch it again it seem to regain power again for a while.
Pavel Balint
| Schumacher racing-cars.com | RCSGraphicWorx.co.uk | Cat K1 | Cougar SV2 & SVR |
Schumacher cars build videos http://www.youtube.com/view_play_list?p=9780E62C20A0EC4F
lochness42 is offline   Reply With Quote
Old 12-21-2012, 02:27 PM   #162
ByteStream's Avatar
Sounds like a bad sensor wire ... did you try with another wire?
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 12-21-2012, 04:48 PM   #163
hana166's Avatar
Yes. Haven't got the bottom of it yet but may have something to do with LVC
hana166 is offline   Reply With Quote
Old 12-21-2012, 09:04 PM   #164
TryHard's Avatar
Agreed, if it's not the usuals (sensor related), check the LVC. The LVC is pretty sensative, and if you pull too much load out of weak batteries, it can cause the LVC to kcik in. I had this a number of times when running it on auto, so now always manually set the LVC to either off (and time the runs) or 3.0v.
HiH
Ed
Old 12-22-2012, 12:39 AM   #165
lochness42's Avatar
Well, yes I did - I used speedo in my modified buggy and then tried it in stock TC and as they use different length of sensor wire I had to use different one.
As for LVC - I guess it shouldn't happen with fully charged batteries and especially not with 17.5T motor in TC and with zero boost mode.
Pavel Balint
Hobbywing Xerun 120 V2 ESC for 1/10 cjtamu Electric Off-Road 289 09-15-2014 03:52 PM
HobbyWing XERUN 13.5T( V3 ) YZFAndy Electric On-Road 6 03-04-2011 04:48 PM
