Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 04-10-2012, 09:19 PM   #1
Default futba 3pm 2.4 fasst
I have a futaba 3pm 2.4 system. I recently got 3 Rx to run all 3 car to my same radio. I can get them to bind just find and evrything seem to work after adjusting the radio for car. My question is when i have it set the radio to car number 1 but i turn on car number 2 why does it still control number two when i have it set for number one on the radio? Is this normal did i do it right i followed the book and got solid green light on all cars.
Team Argus
Team Rw- Mods |www.rw-Rw mods.com|
Hotbodies D8T Argus .23 | tb - 1 pipe|
Hotbodies D812
Hotbodies ve8 Tekin 2050
imrob is offline   Reply With Quote
Old 04-11-2012, 08:09 AM   #2
Moderator
MarkA's Avatar
Trader Rating: 21 (100%+)
Your radio doesn't change the way it id'd itself to your rx's during the bind process by changing the model so all your cars, even with different receivers, will see the tx the same. The only change from model to model on Futaba's stuff is the actual tx adjustment settings. All your cars should work fine and if you have any issues, just turn the tx on/off and that should fix it.
MarkA is offline   Reply With Quote
Old 04-11-2012, 09:37 AM   #3
Ok great thanks just wanted to makes sure.
Team Argus
Hotbodies D812
