Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 04-08-2012, 09:09 PM   #1
petevette's Avatar
Send a message via Yahoo to petevette
Default Charger for DX3R
Hi guys, I have a DX3R with standard AA rechargeable Nimh batteries. What brand wall charger works with the connector on the DX3R?
Thanks.
petevette is offline   Reply With Quote
Old 04-08-2012, 10:00 PM   #2
Radio should have come with a wall charger
Doesnt need to be anything special (6v @ 200mah or so)
If you have a multi-chemistry charger you can use it, you just need the correct adapter
Grab some Sanyo Eneloop LSD (Low Self Discharge) Nimh cells
Cheers
Slash Platinum
Xerun 150, Tenshock SC401 3500kv
Gensace 40c
crusey_aus is offline   Reply With Quote
Old 04-09-2012, 05:48 AM   #3
Cheers
This does not come with a charger since it is intended to use alkaline AA batteries.
I have rechargable AAs but use an external fast charger I purchased from Radio Shack. It takes about 2 hours to fully charge my 2,200mah batteries. I also use an Eveready charger but that one takes about 6 to 8 hours.
You can use the trickle charger that Spektrum sells for their DX6i for an overnight charge without removing the batteries from the radio.
AreCee is offline   Reply With Quote
